查看: 1562|回复: 10
[源码] 文字平行被选直线
发表于 2018-8-27 17:52:07 | 显示全部楼层 |阅读模式
(defun C:TT (/        x y laa        lin lab        pt1 pt2        v1 slin        ang tex        name index nang        oang b)
  (setvar "cmdecho" 0)
  (while (= y nil)
      (setq laa        (entsel        "\nselect the source obj. [or specify 2 point(2p)] "
      (if (/= laa nil)
          (setq lin (entget (car laa)))
          (setq x (cdr (assoc 0 lin)))
          (setq        y (or (= x "LWPOLYLINE")
                      (= x "LINE")
                      (= x "TEXT")
                      (= x "MTEXT")
        ) ;progn
          (setq y 2)
          (setq pt1 (getpoint ":\nspecify first point"))
          (setq pt2 (getpoint pt1 ":\nspecify second point"))
          (coang)
        ) ;progn
      ) ;if
    ) ;progn
  ) ;while
  (cond        ((= (cdr (assoc 0 lin)) "LWPOLYLINE")
           (setq pt1 (cdr (assoc 10 lin)))
           (setq v1 (cons 10 pt1))
           (setq slin (cdr (member v1 lin)))
           (setq pt2 (cdr (assoc 10 slin)))
           (coang)
  (cond        ((= (cdr (assoc 0 lin)) "LINE")
           (setq pt2 (cdr (assoc 11 lin)))
           (coang)
  (cond        ((= (cdr (assoc 0 lin)) "TEXT")
           (setq ang (cdr (assoc 50 lin)))
  (cond        ((= (cdr (assoc 0 lin)) "MTEXT")
  (prompt "\nselect the words to be turned: ")
  (while (= lab nil)
    (setq lab (ssget
                '((-4 . "<OR") (0 . "TEXT") (0 . "MTEXT") (-4 . "OR>"))
  ) ;while
  (setq index 0)
  (setq n (sslength lab))
  (repeat n
    (setq name (ssname lab index))
    (setq tex (entget name))
    (setq index (+ index 1))
    (setq nang (cons 50 ang))
    (setq oang (assoc 50 tex))
    (setq b (subst nang oang tex))
    (entmod b)
  (setvar "cmdecho" 1)
(defun coang ()
  (setq ang (angle pt1 pt2))
  (if (and (> ang (/ pi 2)) (<= ang (* pi 1.5)))
      (setq ang (+ ang pi))
自贡黄明儒 + 1 很给力!
发表于 2018-8-27 18:11:05 | 显示全部楼层
可以加点内容[img][/img],运行块中曲线就更实用了。
发表于 2018-8-27 18:50:38 | 显示全部楼层
黄大大,好牛逼,上源码
发表于 2018-8-27 22:14:35 | 显示全部楼层
自贡黄明儒 发表于 2018-8-27 18:11
可以加点内容[/img],运行块中曲线就更实用了。
可以再增加点内容吗   不仅仅是文字 图块 属性块 线 实体 等 都可以平行于被选的直线或者曲线
 楼主| 发表于 2018-8-28 11:24:52 | 显示全部楼层
留给大神们来改进吧。
发表于 2018-8-28 12:30:29 | 显示全部楼层
用不了的呢
 楼主| 发表于 2018-8-28 13:53:27 | 显示全部楼层
不会吧,先点线,再点文字就行了
发表于 2018-8-28 14:11:05 | 显示全部楼层
哦 我先选的文字 怪不得
 楼主| 发表于 2018-8-28 14:19:09 | 显示全部楼层
纵横八方 发表于 2018-8-28 14:11
哦 我先选的文字 怪不得
能用了就好
发表于 2018-8-30 16:59:01 | 显示全部楼层
黄大大,好牛逼,上源码
GMT+8, 2025-5-19 07:02 , Processed in 0.198985 second(s), 27 queries , Gzip On.
