查看: 716|回复: 6
[提问] 求大神帮忙修改下程序,改成直接插入,而不用选1 2
发表于 2018-8-28 11:11:34 | 显示全部楼层 |阅读模式
(DEFUN C:sum()
  (setvar "cmdecho" 0)
  (setq jd (getint "input 精度<0>:"))
  (if (= jd nil) (setq jd 3))
        (setq s (ssget '((1 . "*[0-9]*")))) ;选择含数字文本
  (setq k -1 mm 0.0 numdb '())
        (setq h2(cdr(assoc 40 (entget (ssname s 0)))))
  (repeat (sslength s)
      (setq a (entget (ssname s (setq k(1+ k)))))
      (setq tx (cdr (assoc '1 a)))
                  (setq b (StrType tx)k2 -1)
                (repeat (length b)
                        (setq txt2(nth (setq k2(1+ k2))b))
                        (if (numberp (read txt2))
      (setq mm (+ (atof txt2) mm) numdb (cons txt2 numdb)))
        (setq numdb(reverse numdb))
        (setq mm (strcat (strcat (car numdb) (apply 'strcat (mapcar '(lambda (x) (strcat "+" x)) (cdr numdb)))) "=" (rtos mm 2 jd)))
;  (setq mm (rtos mm 2 jd))  ;仅显示计算结果
  (initget "1 2")
  (setq fs(getkword "\n(1)新建文本 (2)覆盖文本<1>:"))
  (cond
          ((or(= fs "1")(= fs nil))
     (setq po (getpoint "\n指定计算结果的写入点:"))
                 (entmake (list '(0 . "TEXT") (cons 1 mm)(cons 8 "0")(cons 10 po)(cons 40 h2)(cons 62 7)))
          ((= fs "2")
                  (while(/= (cdr(assoc 0 (setq en (entget(car (entsel "\n请选择要覆盖的文本: ")))))) "TEXT"))
                  (entmod (subst (cons 1 mm) (assoc 1 en) en))
  (setvar "cmdecho" 1)
(defun StrType(a / b c d e);;字符串分离全角、符号、字母、数字,存在问题:连续小数点与数字相连不能精确分离数字和小数点
  (setq b(vl-string->list a))
  (while b
    (setq a(car b)b(cdr b)c(last d))
    (if(or(not d)
               (and(< 0 a 32)(< 0 c 32));;非打印字符
               (or(= 46 a)(= 46 c)(and(< 47 a 58)(< 47 c 58)));数字和小数点
                           (vl-every'(lambda(x)(vl-some'(lambda(y)(<(car y)x(cadr y)))'((31 48)(57 65)(90 98)(122 129))))(list a c));其它字符包括小数点
               (vl-every'(lambda(x)(vl-some'(lambda(y)(<(car y)x(cadr y)))'((64 91)(96 123))))(list a c));;字母
             (and(> a 128)(> c 128)));;全角字符
       (if(> a 128)(setq d(vl-list*(car b)a d)b(cdr b))(setq d(cons a d)))
       (setq e(cons(reverse d)e)d(if(> a 128)(list(car b)a)(List a))b(if(> a 128)(cdr b)b))
  (mapcar'vl-list->string(reverse(cons(reverse d)e)))
发表于 2018-8-30 18:31:54 | 显示全部楼层
(defun c:sum ()
  (if (= jd nil) (setq jd 0))
                (repeat (length b)
  (while b
    (if(or(not d)
原先的默认精度是3不是0,改过来了
发表于 2018-8-31 10:46:07 | 显示全部楼层
(defun c:tt( / var_bak jd ss n zg sum date txt sz zs sumstr sumlst m mlst mstr pt)
        (setq var_bak (getvar"OSMODE"))
        (setvar "OSMODE" 16384)
        (setq ss (ssget'((1 . "*[0-9]*"))))
        (setq n 0)
        (setq zg (cdr(assoc 40 (entget (ssname ss 0)))));获得字高
        (setq sum 0)
        (repeat (sslength ss)
                (setq date (entget(ssname ss n)))
                (setq txt (cdr (assoc 1 date)))
                (setq sz (hdsz txt))
          (setq sum (+ sz sum))
    (setq n (1+ n))
        (setq sumstr (vl-princ-to-string sum))
        (setq sumlst (vl-string->list sumstr))
        (setq mlst (member 46 sumlst))
        (if mlst
                        (setq mstr (vl-list->string mlst))
                        (setq cz (- (length sumlst) (length mlst)))
                        (setq m (substr mstr 1 (+ jd 1)))
                        (setq zs (substr sumstr 1 cz))
      (setq sz (strcat zs m))
                (setq sz (vl-princ-to-string sz))
        (setq pt (getpoint"点击求和标注位置"))
        (if (= (tblobjname "layer" "SUM") nil) (command "._-layer"  "n" "SUM" ""))
        (entmake (list (cons 0 "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText") (cons 8 "SUM") (cons 10 pt) (cons 40 zg) (cons 1 sz)))
(defun hdsz(txt / zfb a   )
        (setq zfb (vl-string->list txt))
        (foreach x zfb (setq a (mapcar'(lambda(x) (if (and (>= x 45) (<= x 58)) (setq a  x)(setq a nil))) zfb)))
        (foreach x a (setq a (vl-remove nil a)))
        (setq a (distof (vl-list->string a) 2))
感觉他的好复杂,自己写了一个
 楼主| 发表于 2018-8-31 10:55:02 | 显示全部楼层
        (setq var_bak ( ...
需要一个表达式,能否修改下,而不是直接放结果
 楼主| 发表于 2018-8-31 11:01:21 | 显示全部楼层
start4444 发表于 2018-8-30 18:31
(defun c:sum ()
  (setq jd (getint "input 精度:"))
你好能否修改一个乘法出结果的,如果可以的话吧除法和减法也高一下,谢谢大神
 楼主| 发表于 2018-8-31 11:07:03 | 显示全部楼层
(defun c:sum ()
发表于 2018-8-31 17:57:26 | 显示全部楼层
(defun c:tt5 ()
  (setq k -1 mm 1.0 numdb '())
                (repeat (length b)
      (setq mm (* (atof txt2) mm) numdb (cons txt2 numdb)))
        (setq mm (strcat (strcat (car numdb) (apply 'strcat (mapcar '(lambda (x) (strcat "*" x)) (cdr numdb)))) "=" (rtos mm 2 jd)))
  (while b
    (if(or(not d)
这个是乘法的,没有详细测试你自己看吧,减法和除法涉及顺序问题,水平有限等其他大神吧
GMT+8, 2025-5-19 07:15 , Processed in 0.252248 second(s), 26 queries , Gzip On.
