查看: 1795|回复: 7
[提问] 一下程序是黄大师的画多边形,没有捕捉功能,求增加
发表于 2018-9-25 19:34:17 | 显示全部楼层 |阅读模式
;;[功能] 画封闭多边形----------脱了裤子放屁
(defun C:w1 (/ PTS)
  (cond ((setq pts (HH::getPoints)) (MakeXLWPOLYLINE pts)))
;;[功能] 取点函数
(defun HH::getPoints (/ CODE FLAG P0 PT PT1 X Y)
  (while (and (setq code (grread T 8)) (or (= (car code) 3) (= (car code) 5)))
    (cond ((= (car code) 3) (setq pt (cons (cadr code) pt))))
    (redraw)
    (cond
      ((> (length pt) 1)
       (setq pt1 (cons (cadr code) pt))
       (setq pt1 (cons p0 pt1))
       (mapcar '(lambda (x y) (grdraw x y 1)) pt1 (cdr pt1))
      ((equal (length pt) 1) (setq p0 (car pt)) (grdraw p0 (cadr code) 1))
      (T
       (cond ((not Flag) (setq Flag T) (princ "\n 点取起点")))
  (redraw)
  (cond ((> (length pt) 2) (reverse pt)))
;;http://bbs.xdcad.net/thread-673261-1-1.html
;;167.3 [功能] Entmake点表生成多段线
(defun MakeXLWPOLYLINE (lst / PT)
  (entmakeX
    (append
      (list '(0 . "LWPOLYLINE")
            '(100 . "AcDbEntity")
            '(100 . "AcDbPolyline")
            (cons 90 (length lst))
            '(70 . 1)
      (mapcar '(lambda (pt) (cons 10 pt)) lst)
发表于 2018-9-26 00:35:12 | 显示全部楼层
在论坛上找出GU版的GRREAD函数,然后替换进去就行了,应该不难的。
 楼主| 发表于 2018-9-26 09:08:44 | 显示全部楼层
你好大师能帮忙弄下吗
 楼主| 发表于 2022-3-20 14:52:10 | 显示全部楼层
大神你好可以帮忙看下不
发表于 2022-3-20 19:50:16 | 显示全部楼层
怎么应用啊?
发表于 2024-2-15 19:30:34 | 显示全部楼层
谁来弄下,想看看
发表于 2024-2-15 20:16:32 | 显示全部楼层
要啥GRREAD,直接(command "PLINE")
  1. (defun c:tt (/ e p s)
  2.         (if (and (setq p (getpoint))
  3.                                 (setq s (list p))
  4.                         )
  5.                 (while (setq p (getpoint p))
  6.                         (setq s (append s (list p)))
  7.                         (if e (entdel e))
  8.                         (command "PLINE")
  9.                         (foreach x s (command "non" x))
  10.                         (command "c" )
  11.                         (setq e (entlast))
  12.                 )
  13.         )
  14. )
GMT+8, 2025-5-12 07:30 , Processed in 0.161183 second(s), 25 queries , Gzip On.
