查看: 9063|回复: 41
[源码] 判断两图元是否相交,相交则无任何操作,不相交则判断两图元是否延伸相交,如延伸...
发表于 2018-10-8 08:39:09 | 显示全部楼层 |阅读模式
其实很简单,用延伸也可以达到这种效果!
  1. ;;说明:判断两图元是否相交,相交则无任何操作,不相交则判断两图元是否延伸相交,如延伸相交,则延伸entname1至entname2最近点
  2. ;;返回:相交则提示相交,不相交且延伸相交则返回延伸相交点,否则则提示图元无相交点
  3. (defun C:ifcro(/ bf-list-split data enpt ent1 ent2 extendpt lst ptlst var);BY-忘霄-qq:702099480(2018.10.8)
  4.   (defun BF-list-split (lst x / lst2);BY 落魄山人-qq:403009819
  5.     (foreach n lst
  6.       (if  (and lst2 (/= x (length (car lst2))))
  7.         (setq lst2 (cons (append (car lst2) (list n)) (cdr lst2)))
  8.         (setq lst2 (cons (list n) lst2))
  9.       )
  10.     )
  11.     (reverse lst2)
  12.   )
  13.   (setq
  14.     ent1 (vlax-ename->vla-object (car (entsel "\n选择对象1或延伸对象:")))
  15.     ent2 (vlax-ename->vla-object (car (entsel "\n选择对象2或被延伸对象:")))
  16.   )
  17.   (if (not (> (vlax-safearray-get-u-bound (vlax-variant-value (vla-IntersectWith ent1 ent2 acExtendNone)) 1) 1));判断两图元是否相交
  18.     (if (> (vlax-safearray-get-u-bound (setq var (vlax-variant-value (vla-IntersectWith ent1 ent2 acExtendBoth))) 1) 1);判断两图元是否延伸相交
  19.       (progn
  20.         (setq
  21.           lst (BF-list-split (vlax-safearray->list var) 3)
  22.           enpt (car lst)
  23.           ptlst (mapcar '(lambda(x) (cdr x)) (vl-remove-if-not '(lambda(x) (= (car x) 10)) (setq data (entget (vlax-vla-object->ename ent1)))))
  24.         )
  25.         (if (equal (angle (nth 1 ptlst) (nth 0 ptlst)) (angle (nth 0 ptlst) enpt) 1e-8)
  26.           (progn
  27.             (setq
  28.               extendpt (cdr (assoc 10 data))
  29.               lst (vl-sort lst '(lambda(a b) (< (distance extendpt a) (distance extendpt b))))
  30.               enpt (car lst)
  31.             )
  32.             (entmod (setq data (subst (cons 10 enpt) (assoc 10 data) data)))
  33.           )
  34.           (progn
  35.             (setq
  36.               extendpt (cdr (assoc 10 data))
  37.               lst (vl-sort lst '(lambda(a b) (< (distance extendpt a) (distance extendpt b))))
  38.               enpt (car lst)
  39.               data (reverse data)
  40.               data (reverse (subst (cons 10 enpt) (assoc 10 data) data))
  41.             )
  42.             (entmod data)
  43.           )
  44.         )
  45.         (prompt (strcat "\n两图元延伸后最近相交于点" (vl-prin1-to-string enpt) "!"))
  46.       )
  47.       (prompt "\n两图元无相交点!")
  48.     )
  49.     (prompt "\n两图元相交!")
  50.   )
  51.   (prin1)
  52. )
谢谢分享  发表于 2018-10-8 08:59
669423907 + 1 赞一个!
 楼主| 发表于 2018-10-10 08:05:06 | 显示全部楼层
烟盒迷唇 发表于 2018-10-9 20:08
不符合我的需要,我想框选智能识别,这样点选的话我直接用延伸就可以了
少年,我承认是看到你发的帖子才写的代码,但是你需要明白,我这不是为你特意定制的,OK???不符合你的要求,你可以根据自己的需要,自己修改,如果不想修改的话,可以找别人在我的基础上去定制,ok?!
 楼主| 发表于 2018-10-10 08:12:47 | 显示全部楼层
lifuq1979 发表于 2018-10-9 18:47
看大神动图方框内点第二条线时出错了,原线没有了,只有延伸的部分
这点需要做个判断,我只是简单的写了一下,因为相对而言两个延伸的焦点,那个距离比较近,就会把坐标改变到那个位置!没有做判断,只要再加个判断就好了!
发表于 2018-10-25 19:51:22 | 显示全部楼层
fangmin723 发表于 2018-10-11 08:12
你是来打酱油的吧
sorry,因为回复了才能看到。因为是那种那种压缩的vlx文件或者fas。现在知道了。是lsp
发表于 2018-10-8 08:59:42 | 显示全部楼层
谢谢fangmin723大师分享
发表于 2018-10-8 19:58:17 | 显示全部楼层
先选中了被延伸对象就会出错,不过也很好了
 楼主| 发表于 2018-10-9 10:42:55 | 显示全部楼层
这个如果你需要无视顺序,你自己可以改一下
发表于 2018-10-9 18:47:57 | 显示全部楼层
发表于 2018-10-9 20:08:47 | 显示全部楼层
发表于 2018-10-10 08:34:44 | 显示全部楼层
谢谢楼主分享
发表于 2018-10-10 08:49:17 | 显示全部楼层
正好需要这方面资料,谢谢楼主分享。
GMT+8, 2025-5-19 15:59 , Processed in 0.241477 second(s), 29 queries , Gzip On.
