查看: 10671|回复: 32
[讨论] 手工反编译一个fas小程序实验
发表于 2018-10-9 15:58:59 | 显示全部楼层 |阅读模式
这个小程序的作者是:updoc,
下载连接是:http://bbs.mjtd.com/plugin.php?id=imc_attachplug:attachad&aid=MTAxNjc5fDUwZTliMDAxfDE1MzkwNjM3MDd8NzMwMjUyMHwxNzgzMTM%3D
解码后是这样的:
Offset      0  1  2  3  4  5  6  7   8  9  A  B  C  D  E  F
00000000   0D 0A 20 46 41 53 34 2D  46 49 4C 45 20 3B 20 44      FAS4-FILE ; D
00000010   6F 20 6E 6F 74 20 63 68  61 6E 67 65 20 69 74 21   o not change it!
00000020   0D 0A 31 36 30 0D 0A 32  31 20 24 14 00 00 00 00     160  21 $
00000030   35 00 14 00 03 0A 09 13  00 35 01 12 00 03 35 01   5        5    5
00000040   11 00 03 35 01 10 00 03  06 0F 00 03 0F 00 33 16      5          3
00000050   C9 33 01 35 02 0E 00 03  67 57 00 00 00 09 0D 00   ? 5    gW
00000060   35 01 0C 00 03 32 0E 33  10 27 00 00 09 13 00 35   5    2 3 '     5
00000070   01 12 00 03 35 02 0B 00  03 35 01 11 00 03 35 01       5    5    5
00000080   0A 00 03 35 02 09 00 03  35 02 08 00 03 67 0E 00      5    5    g
00000090   00 00 09 07 00 35 01 06  00 03 0A 57 0F 00 00 00        5     W
000000A0   09 05 00 35 01 06 00 03  0A 35 00 04 00 03 0A 57      5     5     W
000000B0   0F 00 00 00 09 03 00 35  01 06 00 03 0A 35 00 04          5     5
000000C0   00 03 0A 09 02 00 0B 06  01 00 16 24 0D 0A 33 31              $  31
000000D0   37 20 35 20 24 14 01 01  01 00 32 00 32 21 2A 39   7 5 $     2 2!*9
000000E0   01 00 56 76 6C 2D 41 43  41 44 2D 64 65 66 75 6E     Vvl-ACAD-defun
000000F0   00 00 5B 43 3A 54 54 00  00 01 01 43 00 00 04 00     [C:TT    C
00000100   0A 32 00 33 A0 00 00 00  2A 39 01 00 5B 41 00 00    2 3?  *9  [A
00000110   55 02 00 08 00 B3 CC D0  F2 D6 B4 D0 D0 1C 00 0A   U    程序执行
00000120   20 20 20 B3 CC D0 F2 D2  D1 B9 FD C6 DA 0A 20 20      程序已过期
00000130   20 C7 EB C1 AA CF B5 D7  F7 D5 DF 5B 45 58 49 54    请联系作者[EXIT
00000140   00 00 55 01 00 1A 00 0A  20 20 20 B3 CC D0 F2 B9     U        程序
00000150   FD C6 DA 0A 20 20 20 C7  EB C1 AA CF B5 D7 F7 D5   ?   请联系作
00000160   DF 5B 41 4C 45 52 54 00  00 55 01 00 0D 00 0A 20   遊ALERT  U
00000170   20 20 D6 B4 D0 D0 B3 CC  D0 F2 41 5B 3E 00 4E 54     执行程序A[> NT
00000180   48 00 56 4C 2D 53 54 52  49 4E 47 2D 3E 4C 49 53   H VL-STRING->LIS
00000190   54 00 2A 00 41 53 43 49  49 00 00 55 01 00 01 00   T * ASCII  U
000001A0   33 5B 3C 3D 00 43 44 41  54 00 41 54 4F 49 00 52   3[<= CDAT ATOI R
000001B0   54 4F 53 00 47 45 54 56  41 52 00 00 55 01 00 05   TOS GETVAR  U
000001C0   00 63 64 61 74 65 5B 56  4C 2D 4C 4F 41 44 2D 43    cdate[VL-LOAD-C
000001D0   4F 4D 00 00 5C 00 00 43  00 00 15 00 0A 5C 00 00   OM  \  C     \
000001E0   32 00 5B 43 3A 54 54 00  00 3A 01 43 04 00 01 00   2 [C:TT  : C
000001F0   1C 14 01 00 00 00 09 03  00 0A 57 00 00 00 00 09             W
00000200   04 00 06 02 00 09 02 00  35 01 01 00 01 0A 09 02           5
00000210   00 16 18 00 E8 7E 4F 8F  80 75 04 8A 0A 3B 66 61       鑯O
 楼主| 发表于 2018-10-9 16:11:57 | 显示全部楼层
整理一下字符串:
编号(16进制) 字符串内容
1         A
2         程序执行
3           程序已过期 请联系作者
4         EXIT
5         程序过期 请联系作者
6         ALERT
7         执行程序A
8         >
9         NTH
A         VL-STRING->LIST
B         *
C         ASCII
D         3
E         <=
F         CDAT
10        ATOI
11        RTOS
12        GETVAR
13        cdate
14        VL-LOAD-COM
15        C:TT
把程序代码按指令切开,每行一个指令,分析如下:
14 00 00 00 00      ;函数开始,参数个数为0
35 00 14 00 03 0A   ;执行14号字符串,参数个数为0,VL-LOAD-COM ;(VL-LOAD-COM)
09 13 00            ;将13号字符串压入堆栈,cdate
35 01 12 00 03      ;执行12号字符串,1个参数,GETVAR ;(GETVAR “cdate”)
35 01 11 00 03      ;执行11号字符串,1个参数 RTOS;  ; (RTOS
35 01 10 00 03      ;执行10号字符串,1个参数 ATOI;  ;  (ATOI
06 0F 00            ;对F号字符串赋值 CDAT ;(setq CDAT (ATOI (RTOS (GETVAR “cdate”))))
03 0F 00            ;压入堆栈0Fh号字符串,CDAT
33 16 C9 33 01      ;压入堆栈一个数字133C916h,十进制是20171030
35 02 0E 00 03      ;执行E号字符串,<=               ;(<= CDAT 20171030)
67 57 00 00 00      ;判断,如果成立,跳过57H个字符串 ;(IF (<= CDAT 20171030) )()())
09 0D 00            ;将D号字符串压入堆栈,"3"
35 01 0C 00 03      ;执行C号字符串,1个参数,ASCII  ;(ASCII “3”)
32 0E               ;将数字0eh压入堆栈,也就是十进制14
33 10 27 00 00      ;将数字2710h压入堆栈,也就是十进制10000
35 02 0B 00  03     ;执行B号字符串,2个参数,* ; (* (GETVAR “cdate”)10000 )
35 01 11 00 03      ;执行11号字符串,1个参数,RTOS  ;(RTOS (* (GETVAR “cdate”)10000))
35 01 0A 00 03      ;执行A号字符串,1个参数,VL-STRING->LIST ;(VL-STRING->LIST (RTOS (* (GETVAR “cdate”)10000)))
35 02 09 00 03      ;执行9号字符串,2个参数,NTH ;(NTH 14(VL-STRING->LIST (RTOS (* (GETVAR “cdate”)10000))))
35 02 08 00 03      ;执行8号字符串,2个参数,>     (> (ASCII “3”)(NTH 14(VL-STRING->LIST (RTOS (* (GETVAR “cdate”)10000)))))
67 0E 00 00 00    ;判断,如果成立,跳过0EH个字符串,(iF (> (ASCII “3”)(NTH 14(VL-STRING->LIST (RTOS (* (GETVAR “cdate”)10000)))))(ALERT “执行程序A”)(ALERT “程序过期 请联系作者”))
09 07 00            ;将7号字符串压入堆栈
35 01 06  00 03 0A  ;执行6号字符串,1个参数,ALERT ;(ALERT “执行程序A”)
57 0F 00 00 00      ;跳过0fh个字节
09 05 00            ;将5号字符串压入堆栈,“程序过期 请联系作者”
35 01 06 00 03  0A  ;执行6号字符串,1个参数,ALERT   ;(ALERT “程序过期 请联系作者”)
35 00 04 00 03 0A   ;执行4号字符串,0个参数,;(exit)
09 03 00            ;将3号字符串压入堆栈,“  程序已过期 请联系作者”
35 01 06 00 03 0A   ;执行6号字符串,1个参数,ALERT;(ALERT “  程序已过期 请联系作者” )
09 02 00            ;将2号字符串压入堆栈,"程序执行"
0B 06  01 00        ;对1号字符串赋值,(setq A "程序执行")
16                  ;函数结束
总结一下上面的内容,源代码如下:
(defun C:TT()
(VL-LOAD-COM)
(IF (<= CDAT 20171030) )(iF (> (ASCII “3”)(NTH 14(VL-STRING->LIST (RTOS (* (GETVAR “cdate”)10000)))))(ALERT “执行程序A”)(progn(ALERT “程序过期 请联系作者”)(exit)))(PROGN(ALERT “  程序已过期 请联系作者”
)(exit)))(setq A "程序执行")
参与人数 3明经币 +3 收起 理由
hhh454 + 1 很给力!
USER2128 + 1 很给力!
vectra + 1 很给力!
回复 支持 3 反对 0
发表于 2018-10-10 13:09:32 来自手机 | 显示全部楼层
网上十年前就有参考资料吧,只是把半成品放出来。我也搞了很久,一直没搞定,后来有人搞出来了,卖3k,我嫌贵没买,因为我觉得lisp还是个性化比较强的东西,我想实现的别人都没有做过或者说做得非常好,没有注释,也没有文档,小程序还好,大程序读起来能让你吐血。个人比较喜欢明经和晓东分享的有说明的源码。而且,lisp能实现的基本都是很有限的功能,只有依托其它语言、其它程序才能更强大。
发表于 2018-10-9 16:12:53 | 显示全部楼层
什么叫做反编译???
 楼主| 发表于 2018-10-9 16:13:23 | 显示全部楼层
mikewolf2k 发表于 2018-10-9 16:12
什么叫做反编译???
就是把编译后的fas文件变回lsp源码
发表于 2018-10-9 16:29:16 | 显示全部楼层
baitang36 发表于 2018-10-9 16:13
就是把编译后的fas文件变回lsp源码
发帖时候没看到第二个帖子。
话说回来,研究这个有什么意义?就算真的能反编译,花的时间也比重新写要多。
 楼主| 发表于 2018-10-9 16:33:06 | 显示全部楼层
mikewolf2k 发表于 2018-10-9 16:29
发帖时候没看到第二个帖子。
话说回来,研究这个有什么意义?就算真的能反编译,花的时间也比重新写要多 ...
意义在于学习别人的代码。
特殊的技巧,特殊功能等。
有时候想知道别人是怎么实现的。
这个也是不违反著作权法和软件保护条例的。用于学习、研究目的,不存在盗版的问题。
只有你用别人的软件来赚钱,这才算盗版。
《计算机软件保护条例第十七条 为了学习和研究软件内含的设计思想和原理,通过安装、显示、传输或者存储软件等方式使用软件的,可以不经软件著作权人许可,不向其支付报酬。
发表于 2018-10-9 16:40:33 | 显示全部楼层
要不随便找个没有源代码的fas来反编译试试?acad自带的就行。
 楼主| 发表于 2018-10-9 16:41:44 | 显示全部楼层
主要是太麻烦,手工操作,程序大了会累死人的
 楼主| 发表于 2018-10-9 16:55:09 | 显示全部楼层
这是作者提供的源代码:
(DEFUN C:TT()
(vl-load-com)
(setq cdat (atoi (rtos (getvar "cdate"))))
(if (<= cdat 20171030)
(if (> (ascii "3") (NTH 14 (vl-string->list  (rtos (* 10000 (getvar "cdate"))))))
         (alert "\n   执行程序A")
(alert "\n   程序过期\n   请联系作者")
(exit)
           (alert "\n   程序已过期\n   请联系作者")
           (exit)
(setq a "程序执行")
看来我处理progn还有问题
发表于 2018-10-9 17:11:41 | 显示全部楼层
琢磨一下可能没结果,但也没坏处,专研的精神可嘉。
GMT+8, 2025-5-18 23:09 , Processed in 0.201511 second(s), 29 queries , Gzip On.
