查看: 1199|回复: 6
[提问] 各位大神请问,是否可以写一个代码 一键锁定所有视口,谢谢
发表于 2018-10-16 06:56:54 | 显示全部楼层 |阅读模式
如题
各位大神请问,是否可以写一个代码 一键锁定所有视口,谢谢!:P
发表于 2018-10-16 18:35:47 | 显示全部楼层
;全锁
(defun c:tt4 ()
(command "MVIEW" "l" "on" "all" "")
;全解锁
(defun c:tt5 ()
(command "MVIEW" "l" "off" "all" "")
发表于 2018-10-16 09:47:19 | 显示全部楼层
(defun C:vpl (/ kw);;; Viewports lock-----VPL or unlock -----VPU
  (setq kw "LOCK")
  (vplocks kw)
  (Princ " the viewports have been locked")
(defun C:vpu (/ kw)
  (setq kw "UNLOCK")
  (vplocks kw)
  (Princ " the viewports have been unlocked")
(defun vpLocks (kw / kval doc adoc lao cnt inc cvprt blk pw)
  (vl-load-com)
  (if (= kw "LOCK")
    (setq kval :vlax-true)
    (if        (= kw "UNLOCK")
      (setq kval :vlax-false)
  (setq        doc  (vlax-get-object "AutoCad.Application")
        adoc (vla-get-ActiveDocument doc)
        lao  (vla-get-Layouts adoc)
        cnt  (vla-get-Count lao)
        inc  0
  (repeat cnt
    (setq cvprt        (vla-Item lao inc)
          inc        (+ inc 1)
          blk        (vla-get-Block cvprt)
    (vlax-for itm blk
      (if
        (vlax-property-available-p itm 'DisplayLocked)
           (vla-put-DisplayLocked itm kval)
           (vla-update itm)
发表于 2018-10-16 12:26:02 | 显示全部楼层
  1. (defun C:mvlo()
  2.     (progn
  3.         (command "mview" "l" "on")
  4.     )
  5. )
发表于 2018-10-19 18:54:29 来自手机 | 显示全部楼层
没测试,看上去还是command简洁,这个好。
发表于 2022-3-21 22:58:29 | 显示全部楼层
收下了,说不定用的上。
GMT+8, 2025-5-16 00:18 , Processed in 0.175549 second(s), 26 queries , Gzip On.
