查看: 2207|回复: 9
[源码] 直线偏移联动
发表于 2018-11-4 00:02:36 | 显示全部楼层 |阅读模式
类似于edata发布的程序“直线偏移连动~偏移后修改与其相接触的直线”
和他不同的是
edata的程序需要先指定偏移距离,再选择直线,最后指定偏移方向
而我的程序是
先选择参照直线,再选择偏移目标点,直接计算出偏移距离
如果两头都有【同层】线相连,那么参照直线执行偏移
如果仅一头有线相连,那么偏移同时,改变直线到偏移目标点
由于我的应用环境,需要进行如上操作的都是互相垂直的线,所以没加入斜角相交延伸的功能
(vl-load-com)
;;命令是OLL        ————话说,论坛能设置成屏蔽“字母组合自动转表情”吗????
(defun c:oll()
(if (setq ss (ssget":E:S" '((0 . "line"))))
   (command "undo" "g")
   (ssdraw ss 3)
   (setq pickpt (last (last (car (ssnamex ss)))))  ;;选取点
   (setq line (ssname ss 0))
   (setq lay (dxf 8 line))
   (setq p10 (dxf 10 line))
   (setq p11 (dxf 11 line))
   (if (< (distance p10 pickpt) (distance p11 pickpt))
    (setq pa p10  pb p11)
    (setq pa p11  pb p10)
   (zooment line 2)
   (setq ss1 (ssget "F" (list p10 p11) (list '(0 . "line") (cons 8 lay))))
   (setq ss1 (ss2list ss1))
   (setq ss1 (vl-remove line ss1))
       (command "_.zoom" "p")
       (ssdraw ss1 3)
       (if (setq pc (getpoint pa "\n指定偏移点: "))
         (setq yn (vl-remove-if-not ''((one) (or (equal (distance (dxf 10 one) pa) 0 5) (equal (distance (dxf 11 one) pa) 0 5))) ss1))
         (do_offset)
       (ssdraw ss  4)
       (ssdraw ss1 4)
       (command "undo" "e")
       (c:oll)
(defun do_offset()
(setq ang (angle pa pc))
(setq dist (distance pa pc))
(setq pd (polar pb ang dist))
(setq pd (per_po pb pc pd))
(if yn
  (setq pc (per_po pa pc pd))
(entmodone line 10 pc)
(entmodone line 11 pd)
(setq pa (list (car pa) (cadr pa)))
(setq pb (list (car pb) (cadr pb)))
(setq pc (list (car pc) (cadr pc)))
(setq pd (list (car pd) (cadr pd)))
(foreach linef ss1
  (setq pm (dxf 10 linef)
    pn (dxf 11 linef)
  ;;(setq pm (list (car pm) (cadr pm)))
  ;;(setq pn (list (car pn) (cadr pn)))
  (setq px (inters pa pb pm pn NIL))
  (cond
   ((equal (distance pm px) 0 5)  (setq dxfnm 10))
   ((equal (distance pn px) 0 5)  (setq dxfnm 11))
   ( T (setq dxfnm NIL))
  (setq px (inters pc pd pm pn NIL))
  (if (and px dxfnm)
   (entmodone linef dxfnm px)
;;公共函数
;999获取图元某个dxf组码
(defun dxf( ent n / temp )
(if (and (= (type ent) 'int) (= (type n) 'ename))
  (setq temp  ent
    ent n
    n  temp
(cdr (assoc n (entget ent)))
;999按指定的模式重画一个选择集的全部物体<改模式时,需要先反绘。1-2 3-4.(1->4=1->2->4)>    【支持模型多视口,支持布局中视口】
;;  1:显示  2:消隐  3:高亮  4:低亮
(defun ssdraw( ss mode / i ent )
(if (= (strcase (getvar "ctab")) "MODEL")
  (if (member mode '(1 2 3 4))
   (foreach vp (reverse (vports))
    (setvar "cvport" (car vp))
    (cond
     ((= (type ss) 'PICKSET)
      (foreach ent (ss2list ss)
       (redraw ent mode)
     ((= (type ss) 'list)
      (foreach ent ss
       (redraw ent mode)
     ((= (type ss) 'ename)
      (redraw ss mode)
  (cond
     (redraw ent mode)
    (foreach ent ss
     (redraw ent mode)
    (redraw ss mode)
;999以指定图元缩放窗口
(defun zooment( ent sc / box x midpo )
(setq *acad*      (vlax-get-acad-object))
(setq box (entbox ent))
(setq midpo (getmidpo box))
(setq box (mapcar '(lambda (x) (p0_sc_p1 midpo x sc)) box))
(vla-zoomwindow *acad* (vlax-3d-point (car box)) (vlax-3d-point (cadr box)))
box
;999以基点p0缩放p1————P0为缩放基点
(defun p0_sc_p1 (p0 p1 sc )
  (polar p0 (angle p0 p1) (* sc (distance p0 p1)))
;999修改一个图元的某个数据   ——————不是所有的图元都适用此方式
(defun entmodone( ent dxfnum data )
(entmod (list (cons -1 ent)(cons dxfnum data)))
;999一点到另两点形成直线的垂足
(defun per_po( p1 p2 p3 / ang ptemp )
(setq ang (angle p2 p3))
(setq ang (+ ang (/ PI 2)))
(setq ptemp (polar p1 ang 1000))
(inters p1 ptemp p2 p3 nil)
漏了一些子函数见7楼
用编辑栏的<> 插入代码,或者自己加 [code=lisp]lisp代码段[/code] 这样才能显示代码段,  发表于 2018-11-4 11:34
发表于 2018-11-4 08:50:04 | 显示全部楼层
谢谢! masterlong 分享程序!!!!!
发表于 2018-11-4 11:43:47 | 显示全部楼层
建议发压缩文件包
 楼主| 发表于 2018-11-4 13:31:54 | 显示全部楼层
知道edata说的方法
但是论坛以前还好
点“复制代码”
整个代码就复制下来了
粘贴也很正常
现在操作就全部变成了一行
所以就很不喜欢用这个功能了
不过后来发现
可以先点“普通浏览”
在弹出窗口里全选复制
发表于 2018-11-4 14:19:43 | 显示全部楼层
少了一些函数
发表于 2018-11-4 14:25:55 | 显示全部楼层
;;;选集转图元名表
;;;(ss2list (SSGET))
;;;(<图元名称: 7ef14230> <图元名称: 7ef14228> <图元名称: 7ef14220>)
(defun ss2list ( ss / i l )
    (if ss
        (repeat (setq i (sslength ss))
            (setq l (cons (ssname ss (setq i (1- i))) l))
;;By Longxin 明经通道 2005.06
;;取得实体外矩形框
;;例:(entbox 图元名)
;;返回:((x1 y1 z1)_min (x2 y2 z2)_max)
;;(entbox (CAR(ENTSEL)))
(defun entbox (e1 / obj minpoint maxpoint)
  (setq obj (vlax-ename->vla-object e1)) ;转换图元名
  (vla-GetBoundingBox obj 'minpoint 'maxpoint)
                    ;取得包容图元的最大点和最小点
  (setq minpoint (vlax-safearray->list minpoint)) ;把变体数据转化为表
  (setq maxpoint (vlax-safearray->list maxpoint)) ;把变体数据转化为表
  ;;(command "box" minpoint maxpoint 2)
  (setq obj (list minpoint maxpoint))
;;; ----------------------- getmidpo --------------------------
;;; 两点之中点
;;;方式 : (setq pt3 (getmidpo LST))
;;;LST为表,且为两个点的点表,如(528762.0 6045.65 0.0) (530541.0 8015.43 0.0))
(defun getmidpo (LST)
(list (/ (+ (CAR (NTH 0 LST)) (CAR (NTH 1 LST))) 2)
(/ (+ (cadr (NTH 0 LST)) (cadr (NTH 1 LST))) 2)
(/ (+ (caddr (NTH 0 LST)) (caddr (NTH 1 LST))) 2)
 楼主| 发表于 2018-11-4 15:05:20 | 显示全部楼层
谢谢yoyoho
贴上我的子函数
;999公共函数
;;选择集转为图元列表
(defun ss2list ( ss / n i elist )
(cond
  ((= (type ss) 'Pickset)
   (setq n  (sslength ss)
     i n
     elist '()
   (repeat n
    (setq i (1- i))
    ;;如果没有这个if,那么选择集中被删除的图元,也会被加入到列表之中————但是极其偶尔也有可能,图元不存在但是能entget(遇到过一次,原因不明,或许是CAD的BUG)
    (if (entget (ssname ss i))
     (setq elist (cons (ssname ss i) elist))
   elist
   (list ss)
   (vl-remove-if-not ''((x) (and (= (type x) 'ename) (entget x))) ss)
  ( T NIL)
;999单个物体的最小(正交)包围框---------------------------------这个程序在遇到无法显示的图元时,还是会出错的,比如形。天正图元会不会也不支持,未测试
(defun entbox ( ent / ll ur )
(vla-getboundingbox (vlax-Ename->Vla-Object ent) 'll 'ur)
(mapcar 'vlax-safearray->list (list ll ur))
;999公共函数
;;求点对中点
(defun getmidpo( pts / P1 P2 X Y )
(setq p1 (car pts) p2 (cadr pts))
(if (= (length p1) (length p2))
  nil
  (setq p1 (list (car p1) (cadr p1))
    p2 (list (car p2) (cadr p2))
(mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2)
发表于 2018-11-4 17:03:56 | 显示全部楼层
谢谢! masterlong 分享子函数!!!!
发表于 2018-11-5 11:01:19 | 显示全部楼层
masterlong 发表于 2018-11-4 13:31
知道edata说的方法
但是论坛以前还好
点“复制代码”
在代码区的第一个字符点一下,按shift点代码区最后一个字符,就能选择该区域的文字,复制粘贴就带lisp格式了。或者手动拖动选择也可以。。
GMT+8, 2025-5-19 05:23 , Processed in 0.170699 second(s), 27 queries , Gzip On.
