查看: 2223|回复: 0
调试程序检查代码着色功能
发表于 2018-11-8 09:29:35 | 显示全部楼层 |阅读模式
调试程序:
  1. (setq lst '(("RQ28" "RQ27")
  2.             ("RQ27" "RQ22")
  3.             ("RQ22" "RQ21")
  4.             ("RQ24" "RQ27")
  5.             ("RQ25" "RQ24")
  6.             ("RQ26" "RQ25")
  7.             ("RQ24" "RQ20")
  8.            )
  9. )
  10. ;; (getpath "RQ26" "RQ21")
  11. (defun getpath (start end / next PD)
  12.   (if (null path)
  13.     (setq path (list start))
  14.     (setq path (cons start path))
  15.   )
  16.   (if (= start end)
  17.     (setq lst nil)
  18.     (if        lst
  19.       (progn
  20.         (if (setq next (getnext start))
  21.           (cond
  22.             ((= 1 (length next))
  23.              (getpath (car next) end)
  24.             )
  25.             ((> (length next) 1)
  26.              (setq pd (length path))
  27.              (while next
  28.                (getpath (car next) end)
  29.
  30.                (setq next (cdr next))
  31.                ;; 路径回退到分支处
  32.                (while (and (/= end (car path)) (> (length path) pd))
  33.                  (setq path (cdr path))
  34.                )
  35.              )
  36.             )
  37.           )
  38.         )
  39.       )
  40.     )
  41.   )
  42. )
  43. ;; (getnext "RQ26")
  44. (defun getnext (s / next)
  45.   (setq next (vl-remove-if-not '(lambda (e) (member s e)) lst))
  46.   ;; 总路径表中移除查到的项防止路径返回
  47.   (setq lst (vl-remove-if '(lambda (e) (member e next)) lst))
  48.   (if next
  49.     (mapcar '(lambda (e1) (car (vl-remove-if '(lambda (e) (= s e)) e1)))
  50.             next
  51.     )
  52.   )
  53. )
  54. ;;;_$ (findpath "RQ26" "RQ21" lst)
  55. (defun findpath        (start end lst / path)
  56.   (getpath start end)
  57.   (reverse path)
  58. )
GMT+8, 2026-1-26 02:44 , Processed in 1.688676 second(s), 26 queries , Gzip On.
