查看: 1091|回复: 9
[提问] 勾选窗口如何制作
发表于 2018-12-4 10:43:51 | 显示全部楼层 |阅读模式
①输入命令:xxx
②弹出窗口
      □ 块1
      □ 块2
      □ 块3
③勾选 1项 执行插入块命令
我想请教一下各位
我想做这个弹出的窗口
要找那些相关知识呢
或者有简单的例子 能否提供一下参考
发表于 2018-12-4 11:40:50 | 显示全部楼层
 楼主| 发表于 2018-12-4 13:10:45 | 显示全部楼层
tile_button:
     dialog{
     label="测试" ;
   : button {
     label="块1";
     width=20;
     height=2;
     alignment=centered;
现在能 能调出来了 我想点击 块1 按钮
执行(command "-insert" "块1" pause "" "" "")
用什么函数执行 有人直到嘛。。。
 楼主| 发表于 2018-12-4 13:11:40 | 显示全部楼层
Andyhon 发表于 2018-12-4 11:40
Ref:
https://www.afralisp.net/dialog-control-language/tutorials/index.php?category_id=12
3Q 这都是知识啊
发表于 2018-12-4 16:41:04 | 显示全部楼层
https://wiki.mcneel.com/doslib/home
实务上可选用
dos_checklist
or
dos_listbox
发表于 2018-12-7 20:41:06 | 显示全部楼层
张大锤 发表于 2018-12-4 13:10
tile_button:
     dialog{
     label="测试" ;
DCL代码:
tile_button:dialog{label="测试";
:row{
:button{
label="块1";
key="k1";
width=20;
height=2;
alignment=centered;
is_cancel=true;
:button{
label="块2";
key="k2";
width=20;
height=2;
alignment=centered;
is_cancel=true;
:button{
label="块3";
key="k3";
width=20;
height=2;
alignment=centered;
is_cancel=true;
lsp调用代码:
(defun c:tt(/ dcl_id jz)
  (setq jz nil)
  (defun ck()
    (cond
      ((= jz 1)(command "-insert" "块1" pause "" "" ""))
      ((= jz 2)(command "-insert" "块2" pause "" "" ""))
      ((= jz 3)(command "-insert" "块3" pause "" "" ""))
  (setq dcl_id (load_dialog "tile_button.dcl"))
  (if (not (new_dialog "tile_button" dcl_id))(exit))
  (action_tile "k1" "(setq jz 1)")
  (action_tile "k2" "(setq jz 2)")
  (action_tile "k3" "(setq jz 3)")
  (start_dialog)
  (unload_dialog dcl_id)
  (ck)
 楼主| 发表于 2019-2-1 08:49:22 | 显示全部楼层
ljfdjjj 发表于 2018-12-7 20:41
DCL代码:
:row{
十分感谢
发表于 2019-2-1 10:23:22 | 显示全部楼层
  1. ;; tt(插块dcl)
  2. (defun c:tt ()
  3.   (defun ak1 () (command "-insert" "块1" pause 1 1 0))
  4.   (defun ak2 () (command "-insert" "块2" pause 1 1 0))
  5.   (defun ak3 () (command "-insert" "块3" pause 1 1 0))
  6.   (defun ak4 () (command "-insert" "块4" pause 1 1 0))
  7.   (setq        Dlst '(":row{"
  8.                ("k1" "" "i6" "-15" "3" "blank" "(ak1)")
  9.                ("t1" "块1" "textpart")
  10.                ("k2" "" "i6" "-15" "3" "blank" "(ak2)")
  11.                ("t2" "块2" "textpart")
  12.                ("k3" "" "i6" "-15" "3" "blank" "(ak3)")
  13.                ("t3" "块3" "textpart")
  14.                ("k4" "" "i6" "-15" "3" "blank" "(ak4)")
  15.                ("t4" "块4" "textpart")
  16.                "}"
  17.               )
  18.   )
  19.   (xyp-Dcl-Init Dlst "【插图块】" t)
  20.   (princ)
  21. )
 楼主| 发表于 2019-2-1 10:52:58 | 显示全部楼层
这个是用lisp 直接调用dcl 嘛
不需要再多创建一个dcl文件了  炫酷
 楼主| 发表于 2019-2-1 10:59:01 | 显示全部楼层
xyp-Dcl-Init
这个能发出来嘛~~~~ 嘿嘿
GMT+8, 2025-5-19 02:49 , Processed in 0.169570 second(s), 25 queries , Gzip On.
