- 积分
- 8031
- 明经币
- 个
- 注册时间
- 2008-1-5
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(defun c:ncb()
(setvar "CMDECHO" 0)
(if (setq ss(ssget "X" (list '(0 . "circle") (cons 8 "0")))) (progn
(command ".UNDO" "BE")
(setq i -1 cirlst (list))
(repeat (sslength ss)
(setq r (cdr (assoc 40 (entget (setq en (ssname ss (setq i (1+ i))))))))
(if (assoc r cirlst)
(setq cirlst (subst (cons r (1+ (cdr (assoc r cirlst)))) (assoc r cirlst) cirlst))
(setq cirlst (cons (cons r 1) cirlst))
(setq i -1 cirlst (reverse cirlst) cclist (list))
(setq cirlst (vl-sort cirlst (function (lambda (e1 e2) (> (car e1) (car e2))))))
(repeat (length cirlst)
(setq r (car (nth (setq i (1+ i)) cirlst)))
(command "select" ss "")
; (setq ss1 (ssget "P" (list (cons 0 "CIRCLE") (cons 40 r))))
(setq ss1(ssget "X" (list '(0 . "circle") (cons 8 "0"))))
(setq j 0 clist (list r))
(repeat (sslength ss1)
(setq ent (entget(ssname ss1 j)))
(setq j (1+ j))
(setq pc (cdr(assoc 10 ent)))
(setq clist (append clist (list (list (car pc) (cadr pc)))))
(setq cclist (cons clist cclist))
(setq nm (if nm nm ""))
(if (setq nm (getfiled "输入文件名" nm "drl" 1)) (progn
(setq i 0)
(setq fp (open nm "w"))
(princ "M48\nMETRIC\nVER,1\nFMAT,2\n" fp)
(repeat (length cclist)
(setq r (car(nth i cclist)))
(setq i (1+ i))
(princ (strcat "T" (if (< i 10) "0" "") (itoa i) "C" (rtos (+ r r) 2 3) "F423B423S6H1800\n") fp)
(princ "DETECT,ON\nATC,ON\n%\n" fp)
(setq i 0)
(setq clist (nth i cclist) i (1+ i))
(princ (strcat "T" (if (< i 10) "0" "") (itoa i) "\n") fp)
(setq j 0 clist (cdr clist))
(repeat (length clist)
(setq pc (nth j clist) j (1+ j))
(princ (strcat "X" (rtos (car pc) 2 3) "Y" (rtos (cadr pc) 2 3) "\n") fp)
(princ "M30\n%\n" fp)
(close fp)
(command ".UNDO" "E")
(setvar "CMDECHO" 1)
