查看: 1384|回复: 5
[提问] 线长统计计算价格
发表于 2019-1-17 11:30:26 | 显示全部楼层 |阅读模式
这是选线计算加工价格,其中红线有错误,水平有限没找到原因,望改正。
(vl-load-com)
(defun C:999 (/)
     (setq LST '(("LINE" "直线")
   ("ARC" "圆弧")
   ("CIRCLE" "圆")
   ("LWPOLYLINE" "多段线")
   ("ELLIPSE" "椭圆")
   ("SPLINE" "样条线")
     (if (setq SS (ssget '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,ELLIPSE,SPLINE"))
      ;;1.逐个统计
      (setq I 0)
      (repeat (sslength SS)
   (setq EN  (ssname SS I)
         ENT (entget EN)
         STR (cdr (assoc 0 ENT))
   (if (setq TMP (assoc STR LST))
       (setq LEN (vlax-curve-getdistatparam
       EN
       (vlax-curve-getendparam EN)
      LST (subst (append TMP (list LEN)) TMP LST)
   (setq I (1+ I))
      ;;2.显示
      (setq PRTXT
        "线条长度分类统计\n\n类型\t根数\t长度\n----------------------"
      (foreach N LST
   (if (> (length N) 2)
       (setq LEN (apply '+ (cddr N))
      PRTXT (strcat PRTXT
      "\n"
      (cadr N)
      "\t"
      (itoa (- (length N) 2))
      "\t"
      (rtos LEN 2 3)
    (setq LL   (rtos (apply '+ (apply 'append (mapcar 'cddr LST))) 2 2))
    (setq HD (getreal "\n请输入零件高度<30>:"))
;;;    (setq JJ (* LL HD 0.0043))           ;;;   修改这一行
    (setq PRTXT (strcat PRTXT "\n\n总数:"   (itoa (- (length (apply 'append LST)) (* 2 (length LST))))
                                "  总长度:"  LL
;;;                           "  总价格:"  JJ      ;;;   修改这一行
      (princ PRTXT)
      (alert PRTXT)
发表于 2019-1-17 13:22:43 | 显示全部楼层
LL是字符串,你这字符串怎么能进行数学运算啊
JJ是实数类型,你却又把他强行与字符串组合
                                "  总长度:"  LL
发表于 2019-1-18 01:18:30 | 显示全部楼层
楼主快丝专业....
发表于 2019-1-22 18:53:33 | 显示全部楼层
(vl-load-com)
(defun C:999 (/)
   ("ARC" "圆弧")
   ("CIRCLE" "圆")
   ("ELLIPSE" "椭圆")
   ("SPLINE" "样条线")
      ;;1.逐个统计
      (setq I 0)
         ENT (entget EN)
       EN
   (setq I (1+ I))
      ;;2.显示
      (setq PRTXT
      (foreach N LST
      PRTXT (strcat PRTXT
      "\n"
      (cadr N)
      "\t"
      "\t"
      (rtos LEN 2 3)
    (setq LL    (apply '+ (apply 'append (mapcar 'cddr LST))) )
    (setq JJ (* ll(* HD(* 0.0043)))  )         ;;;   修改这一行
                                "  总长度:" (rtos LL  2 2)
                           "  总价格:"  (rtos JJ  2 2)    ;;;   修改这一行
      (princ PRTXT)
      (alert PRTXT)
发表于 2024-7-17 22:27:49 | 显示全部楼层
雷雨线割报价软件
发表于 2024-7-18 05:18:54 来自手机 | 显示全部楼层
flfcegu168 发表于 2024-7-17 22:27
雷雨线割报价软件
牛逼。现在这个多少钱
GMT+8, 2025-5-7 16:09 , Processed in 0.261569 second(s), 26 queries , Gzip On.
