查看: 1052|回复: 0
[源码] 分享 -- 使用vbs语言加载 当前目录下的 lsp
发表于 2019-1-19 22:07:58 | 显示全部楼层 |阅读模式
Public Sub Setup()
    On Error Resume Next
    Set objCAD = GetObject(, "AutoCAD.Application")
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set ws = CreateObject("WScript.Shell")
    path = fs.GetParentFolderName(wsh.ScriptFullName)
    menuPath = path + "\Sys\zhl.mns"
    ws.RegWrite "HKEY_LOCAL_MACHINE\Software\ZHL_SOFT\" _
            & "zhlpath", path
    Err.Clear
    Set app = GetObject(, "autocad.Application")
    If app.Documents.Count = 0 Then
        app.Documents.Add
    End If
    If Err.Number <> 0 Then
        MsgBox "必强提示您,没有发现正在运行中的AutoCAD,请先启动AutoCAD软件!", vbInformation, "必强提示您,请先启动AutoCAD软件!"
        CreateObject ("SAPI.SpVoice").Speak"必强提示您,请先启动AutoCAD软件"
        wsh.quit
    End If
    Set mgrp = app.MenuGroups
    Err.Clear
    Set ThisDrawing = objCAD.activedocument
    path = replace (path , "\" ,"/")
    ThisDrawing.SendCommand ("(load """ & path & "/必强工具箱.lsp"")" & vbCr)
                CreateObject ("SAPI.SpVoice").Speak"必强工具箱成功加载,谢谢使用"
End Sub
Setup
GMT+8, 2025-5-18 23:11 , Processed in 0.158382 second(s), 25 queries , Gzip On.
