- 积分
- 23445
- 明经币
- 个
- 注册时间
- 2018-11-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
Dim WshShell, REG, Path, Key, SubKey, Value
Set WshShell = WScript.CreateObject("WScript.Shell")
'HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5001:409\Profiles\<<Unnamed Profile>>\Dialogs\Appload\Startup
Boot = "HKCU\"
Key = "Software\Autodesk\AutoCAD\"
Value = WshShell.RegRead(Boot & Key & "CurVer")
Key = Key & Value & "\"
SubKey = "Profiles\"
Value = WshShell.RegRead(Boot & Key & SubKey)
SubKey = SubKey & Value & "\Dialogs\Appload\Startup\"
IF Value<>"" Then
Set REG = GetObject("winmgmts:\\.\root\default:StdRegProv")
Item = Value & "Startup"
REG.GetStringValue &H80000001, Key & SubKey, Item, Value
If IsNull(Value) Then
Value = ""
Else
Value = WshShell.RegRead(Boot & Key & SubKey & Item)
If UCase(Right(Value,9))<>"\必强工具箱.lsp" Then Value = ""
End If
End IF
IF Value<>"" Then
MsgBox "TB Tools 已在自动加载列表中!"
Else
Path = WshShell.CurrentDirectory & "\必强工具箱.lsp"
Value = WshShell.RegRead(Boot & Key & SubKey & "NumStartup")
Value = CStr(CInt(Value)+1)
WshShell.RegWrite Boot & Key & SubKey, Value, "REG_SZ"
WshShell.RegWrite Boot & Key & SubKey & "NumStartup", Value, "REG_SZ"
WshShell.RegWrite Boot & Key & SubKey & Value & "Startup", Path, "REG_SZ"
'HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5001:409\Applications\AcadAcLaunchNFW
Path = Boot & Key & "Applications\AcadAcLaunchNFW\LOADCTRLS"
Value = WshShell.RegRead(Path)
Value = Value or 2
WshShell.RegWrite Path, Value, "REG_DWORD"
MsgBox "欢迎使用必强工具箱,软件正在安装请稍后"
CreateObject ("SAPI.SpVoice").Speak"欢迎使用必强工具箱,软件正在安装请稍后"
End IF
Set objAutocadApp = Wscript.CreateObject("AutoCAD.Application")
objAutocadApp.Visible = True
Set thisdrawing=objautocadapp.activedocument
thisdrawing.SendCommand("_AP" & vbCr)
