查看: 688|回复: 0
[提问] 求修改这个程序,新建一个文件夹
发表于 2019-1-27 16:13:20 | 显示全部楼层 |阅读模式
如下程序,求修改一下,在目录下新建一个分图的文件夹,吧分图保存到分图文件夹下
(defun C:KMFT (/ ANSWER EN FLAG FLAG1 INITDIR NEWDNAME NEWDNAME1 SS)
  (command "undo" "be")
  (if (setq Initdir (getvar "dwgprefix"))
      nil
      (progn (princ "\n 文件未保存,不能分图") (exit))
  (setq flag1 T)
  (while (and flag1
              (setq en0 (entsel "\n >拾取文件名 "))
              (setq en (nentselp (cadr en0)))
              (setq NewDName (cdr (assoc 1 (entget (car en)))))
              (equal (type NewDName) 'STR)
    (if  (findfile (strcat Initdir NewDName ".DWG"))
      (progn(setq flag T)(setq i 1))
  (while flag
         (setq ii (rtos i 2 0))
       (setq NewDName1 (strcat NewDName "_" ii ))
        (if (findfile (strcat Initdir NewDName1 ".DWG"))
          nil
           (progn (setq flag nil)(setq NewDName NewDName1))
      (setq i (+ i 1 ))
  (setq q (entsel"\n对象图框:"))
  (setq sel (car q))
  (command "zoom" "o" sel "")
  (vl-load-com)
  (setq minPt (vlax-make-safearray vlax-vbdouble '(0 . 2)))
  (setq maxPt (vlax-make-safearray vlax-vbdouble '(0 . 2)))
  (setq obj (vlax-ename->vla-object sel))
  (vla-GetBoundingBox obj 'minpt 'maxpt)
  (setq minPt1 (vlax-safearray->list minPt))
  (setq maxPt1 (vlax-safearray->list maxPt))
  (Setq SS (ssget "_C"  maxPt1 minPt1 ))
  (command "_.WBLOCK" (strcat Initdir NewDName) ""  "0,0" ss "" )
  (command "undo" "e")
GMT+8, 2025-5-19 01:06 , Processed in 0.145982 second(s), 26 queries , Gzip On.
