查看: 2066|回复: 8
[提问] 求大神发个这种LISP程序
发表于 2019-2-3 10:38:22 | 显示全部楼层 |阅读模式
求大神发个这种LISP程序  点连线
发表于 2019-2-11 13:45:05 | 显示全部楼层
(defun c:tt(/ ss entlst)
  (setq ss (ssget '((0 . "TEXT") (1 . "*#*"))))
  (setq entlst(gxl-Sel-SS->List ss))
  (setq entlst (vl-sort entlst '(lambda (p1 p2)(< (atof (cdr (assoc 1 (entget p1))))
                         (atof (cdr (assoc 1 (entget p2))))))))
  (LC:Make-LWPOLYLINE1(mapcar'(lambda(x)(dxf 10 (entget x)))entlst))
(defun LC:Make-LWPOLYLINE1 (lst / PT)
  (entmake (append (list '(0 . "LWPOLYLINE")
    '(100 . "AcDbEntity")
    '(100 . "AcDbPolyline")
    '(62 . 1)
    (cons 90 (length lst))
     (mapcar '(lambda (pt) (cons 10 pt)) lst)
(defun gxl-Sel-SS->List (ss / i s )
  (if ss
  (repeat (setq i (sslength ss))
  (setq s (cons (ssname ss (setq i (1- i))) s))
(defun DXF (code elist) (cdr (assoc code elist)))
发表于 2019-2-13 17:29:58 | 显示全部楼层
收藏了,谢谢!
发表于 2019-2-14 08:17:22 | 显示全部楼层
二楼是大神
发表于 2019-2-14 13:33:39 | 显示全部楼层
  1. ;; tt(高程连线)
  2. (defun c:tt (/ ss lst s1)
  3.   (if (setq ss (ssget '((0 . "insert") (66 . 1))))
  4.     (setq lst (mapcar '(lambda (x)(list (atoi (last (car (xyp-Att2list x))))(xyp-DXF 10 x))) (xyp-Ss2List ss))
  5.           lst (vl-sort lst '(lambda (x y) (< (car x) (car y))))
  6.           s1  (xyp-Pline (mapcar 'cadr lst) t)
  7.     )
  8.   )
  9.   (princ)
  10. )
发表于 2021-2-18 15:27:03 | 显示全部楼层
厉害了!!感谢!!!
发表于 2021-2-28 12:18:05 | 显示全部楼层
要是能解决编号的问题就更好了
发表于 2021-3-2 12:17:44 | 显示全部楼层
no function definition: XYP-SS2LIST
GMT+8, 2025-10-2 02:29 , Processed in 0.206255 second(s), 26 queries , Gzip On.
