查看: 9005|回复: 28
[提问] 图层颜色修改
发表于 2019-2-13 13:06:17 | 显示全部楼层 |阅读模式
图层原有颜色与当前视口图层替代颜色修改    bylayer(VR)
求高手们编程对话框模式的源码提供学习
 楼主| 发表于 2019-5-25 16:17:54 | 显示全部楼层
wudechao 发表于 2019-5-25 12:39
(defun c:vc (/ ss index lay ent ffg colour)
  (setvar "cmdecho" 0)
  (setq ffg (getvar "TILEMODE") ...
请教一下,如果图层替代颜色修改后,怎样才能改回来原有的随层颜色呢
 楼主| 发表于 2019-2-16 16:13:38 | 显示全部楼层
lingduwx 发表于 2019-2-15 11:29
再加上修改图层名就更好了
快捷键  de  图层重命名
(defun c:de (/ *error*  name name1 dclname tempname filen stream dcl_re dlg new)
        (defun *error* ( msg )
                (if (wcmatch (strcase msg t) "*break,*cancel*,*exit*")
                                (unload_dialog dcl_re)
                                (vl-file-delete dclname)
                                (princ "\nError:图层0不可更改!" )
  (setq key
                        (initget "D  " )
                        (entsel "\n选择需改图层名的对象[改当前图层名(D)]:")
        (cond
                ((= key "D")
                        (setq name (getvar "CLAYER"))        ;获取当前图层
                ((= (type key) 'LIST)
                        (setq name (cdr (assoc 8 (entget (car key)))))
                (t nil) ;什么也不做
        (setq dclname
                (cond
                                (setq tempname (vl-filename-mktemp "re-dcl-tmp.dcl") filen (open tempname "w"))
                                (foreach stream '(
        "\n"
        "RENAME:dialog {\n"
        "    label = \"图层重命名\" ;\n"
        "    :row {\n"
        "        :edit_box {\n"
        "            key = \"dcl_edit_name\" ;\n"
        "            width = 30 ;\n"
        "        }\n"
        "    }\n"
        "    :row {\n"
        "        :button {\n"
        "            key = \"btn_ok\" ;\n"
        "            label = \"确认\" ;\n"
        "        }\n"
        "        :button {\n"
        "            is_cancel = true ;\n"
        "            key = \"btn_cancle\" ;\n"
        "            label = \"取消\" ;\n"
        "        }\n"
        "    }\n"
        "}\n"
                                        (princ stream filen)
                                (close filen)
                                tempname
        (setq dcl_re (load_dialog dclname))
        (if (not (new_dialog "RENAME" dcl_re)) (exit))
        (set_tile "dcl_edit_name" name)
        (mode_tile "dcl_edit_name" 2)
        (action_tile "dcl_edit_name" "(setq name1 $value)")
        (action_tile "btn_ok"
                                                         "(if (= name \"0\")
        (alert (strcat \"图层: \" name \" 不可更改!\"))
        (exit)
        (if (tblsearch \"layer\" name1)
        (alert (strcat \"图层: \" name1 \" 已经存在.\"))
        (if (not (snvalid name1))
        (alert (strcat \"错误的图层名: \" name1))
        (done_dialog 1)
        (setq dlg (start_dialog))
        (cond
                ((= dlg 1)
                        (command "_.rename" "_layer" name name1)
                        (princ (strcat "\n图层 \"" name "\" 重命名为 \"" name1 "\""))
                (t nil
  (prin1)
发表于 2019-2-13 13:32:34 | 显示全部楼层
  1. ;; vpco 设置视口图层颜色 (vpco co颜色号 la图层名称)
  2. ;; (vpco 3 "0")
  3. (defun vpco (co la) (command "vplayer" "c" co la "A" ""))
 楼主| 发表于 2019-2-13 13:46:03 | 显示全部楼层
请求:能发来全码吗
发表于 2019-2-15 10:45:04 | 显示全部楼层
VPlayer命令在2010以上版本才有 颜色c 这个选项
发表于 2019-2-15 11:29:41 | 显示全部楼层
再加上修改图层名就更好了
发表于 2019-2-18 14:42:25 | 显示全部楼层
“”图层重命名“”应该保留原来的图层只改修改的对象的图层吧
发表于 2019-4-14 22:34:37 | 显示全部楼层
(defun c:bb ()(setq yanse (acad_colordlg 1))(gtcys yanse)(princ))(defun gtcys (yanse / acaddoc acadobj en i lay layobj obj ss vlay vlay1)
(setq AcadObj (vlax-get-Acad-object)  AcadDoc (vla-get-ActiveDocument AcadObj) LayObj (vla-get-layers AcadDoc))
(if (setq ss (ssget))(progn(setq i 0)(repeat (sslength ss)(setq en (ssname ss i) obj (vlax-ename->vla-object en) lay (vla-get-layer obj)  vlay (vla-item LayObj lay))
(if (= (equal vlay vlay1) nil)(progn(vla-put-color vlay yanse)(setq vlay1 vlay)))(setq i (1+ i)))))(princ))
 楼主| 发表于 2019-4-15 00:37:50 | 显示全部楼层
1291500406 发表于 2019-4-14 22:34
(defun c:bb ()(setq yanse (acad_colordlg 1))(gtcys yanse)(princ))(defun gtcys (yanse / acaddoc acado ...
快捷键  cd  改图层颜色
(defun c:cd()
(setq lay(cdr (assoc 8 (entget (car (entsel "\n 请选取要修改颜色的图层对象:"))))))
;(setq ss (ssget))
;(if ss (progn
(setq colour (getstring "\n请输入颜色号<1-255>:"))
(command "-layer" "c" colour lay ""))
(setvar "cmdecho" 1)
必强大师你的程序是修改图层颜色和我上面的差不多,这里说到的是替代图层的颜色修改,原有图层颜色不变,只是如何添加替代图层颜色
发表于 2019-4-15 09:31:45 来自手机 | 显示全部楼层
可以的,学习了
GMT+8, 2025-5-11 14:22 , Processed in 0.180648 second(s), 28 queries , Gzip On.
