查看: 672|回复: 2
[提问] leader引线时,如何自动在在段落里开启段落行距
发表于 2019-3-5 10:58:52 | 显示全部楼层 |阅读模式
请教一个leader引线问题:
如何自动在在段落里开启段落行距,并设置值为0.7
[size=15.05455pt]
  • (defun c:13(/ o s)
  •   (if (setq o(getpoint"\n 请指定坐标原点(右键为之前的原点): "))
  •     (command "qleader" "non" o "\\" "" "" 0 "" "ucs" o "")
  •     (command "ucs" "p")
  •   (while
  •     (setq o (getpoint"\n 请指定坐标点:"))
  •     (if (setq s (ssget "c" o o '((0 . "circle,arc"))) )
  •       (progn
  •         (setq s (entget (ssname s 0)))
  •         (setq o (trans (cdr (assoc 10 s)) 0 1)) ;trans坐标转换
  •     ) ;如果选中的是圆或圆弧,则自动移到圆心
  •     (princ (strcat "\n 请指定 "(strcat"X "(rtos(car o)2 2))"   "(strcat"Y "(rtos(cadr o)2 2))" 的文字位置"))
  •     (command "leader" "non"o"\\" ""(strcat"X "(rtos(car o)2 2))(strcat"Y "(rtos(cadr o)2 2))"")
  •   ) ;while
  •   (command "ucs" "")
  •   (setq o nil s nil)
  •   (princ))
file:///D:\Documents\Tencent Files\669423907\Image\Group\Image3\6ZKCB0C`~0`RQG}UW}I$Y$I.png
 楼主| 发表于 2019-3-21 11:25:02 | 显示全部楼层
(defun c:zb(/ o s)
(Y引线设置)
  (if (setq o (getpoint"\n 请指定坐标原点(右键为之前的原点): "))
    (command "qleader" "non" o "\\" "" "" "{\\C6;0" "" "ucs" o "")
    (command "ucs" "p")
  (while
    (command "qleader" "non" o "\\" "" "" (strcat "{\\C201;X {\\C2" "\\pxsm0.7;"(rtos(car o)2 2) "\\P" "{\\C181;Y {\\C2" "\\psm0.6;" (rtos(cadr o)2 2)) "") ;leader
  ) ;while
  (command "ucs" "")
  (setq o nil s nil)
  (princ))
;设置 Qleader 命令“引线设置”对话框的相关参数
;注:<font color="red">引线的箭头跟DIMSTYLE使用同一设置,可以直接修改DIMLDRBLK系统变量
;caoyin 2011.5.5 http://bbs.mjtd.com/forum.php?mo ... =qleader&page=1
(defun Y引线设置(/ DICEN)
  (setq DICEN (namedobjdict))
  (if (dictsearch DICEN "AcadDim")
    (dictremove DICEN "AcadDim")
  (dictadd DICEN
           "AcadDim"
            (entmakex '((0 . "XRECORD")
                        (100 . "AcDbXrecord")
                        (280 . 1)
                        (90 . 990106)
                        (3 . "") ;引线和箭头-〉箭头[用户箭头的缺省块名,""则表示未设置]
                        (60 . 0) ;注释-〉注释类型[0,1,2,3,4]
                        (61 . 0) ;注释-〉重复使用注释[0,1,2]
                        (62 . 2) ;附着-〉文字在右边[0,1,2,3,4]
                        (63 . 2) ;附着-〉文字在左边[0,1,2,3,4]
                        (64 . 0) ;附着-〉最后一行加下划线[0,1]
                        (65 . 0) ;引线和箭头-〉引线[0,1]
                        (66 . 0) ;引线和箭头-〉点数-〉无限制[0,1]
                        (67 . 4) ;引线和箭头-〉点数[任意正整数]
                        (68 . 1) ;注释-〉多行文字选项-〉提示输入宽度[0,1]
                        (69 . 0) ;注释-〉多行文字选项-〉始终左对齐[0,1]
                        (70 . 0) ;引线和箭头-〉角度约束->第一段[0,1,2,3,4,5]
                        (71 . 0) ;引线和箭头-〉角度约束->第二段[0,1,2,3,4,5]
                        (72 . 0) ;注释-〉多行文字选项-〉文字边框[0,1]
                        (40 . 0.0) ;字高
                        (41 . 0) ;自定义宽度
                        (46 . 0) ;自定义高度
                        (170 . 2) ;控制“引线设置”对话框的缺省选项卡[0,1,2]
                     ;(340 . 图元名)
                      ;当DXF组码60的值为3,且已经设定了块参照的块名,则340组码才会出现
                      ;格式为(340 . 上次使用块参照作为注释对象,实际插入的块实例的图元名)
发表于 2019-3-21 19:37:51 | 显示全部楼层
建议做个属性文字块,修改比较方便
GMT+8, 2025-5-19 01:28 , Processed in 0.161853 second(s), 28 queries , Gzip On.
