查看: 28877|回复: 56
[源码] 迈迈面板优化
发表于 2019-3-15 00:43:24 | 显示全部楼层 |阅读模式
迈迈面板优化2,记忆测试查不出来错在哪,偶尔会响应两次
BaoWSE + 1 赞一个!
本帖被以下淘专辑推荐:
  • · 学习|主题: 24, 订阅: 0
发表于 2019-5-28 00:19:45 | 显示全部楼层
(defun c:bb () (bbdig0) (princ))
(defun bbdig0 ()
  (mai_make_panel
    (list
      (list "网页"
                                (list "批量打印" "aa1")        ;(list  按钮标签  运行的命令)
                                (list "统计设置" "aa2")
                                (list "统计长度" "aa3")
                                (list "面积统计" "AT")
                                (list "系统算器" "aa4")
                                (list "查vlxkey" "aa5")
                                (list "地址收藏" "aa6")
                                (list "花堂文学" "aa7")
                                (list "爱图论坛" "aa8")
                                (list "Itellyou" "aa9")
      ) ;_ 结束list
      (list "绘图"
                                (list "管道截面" "gdjm")
                                (list "管道截断" "gdjd")
                                (list "绘制螺栓" "sd")
                                (list "绘制螺丝" "bls")
                                (list "螺栓连接" "aa10")
                                (list "绘制管道" "aa11")
                                (list "上下弯头" "aa12")
                                (list "表格 C2E" "aa13")
                                (list "字上下标" "zsxb")
                                (list "日期日历" "Calendar")
      ) ;_ 结束list
      (list "图块"
                                (list "查找图块" "Count")
                                (list "查块连线" "bb2")
                                (list "图块替换" "bb3")
                                (list "圆心插块" "bb4")
                                (list "图块编号" "EACE-BN")
                                (list "递增复制" "xcc")
                                (list "X to cad" "x2c")
                                (list "转ACAD表" "cot")
                                (list "表格导出" "te")
                                (list "文本导出" "wr")
      ) ;_ 结束list
      (list "工具"
                                (list "递增刷子" "dz")
                                (list "相同刷子" "xts")
                                (list "做中心线" "ce")
                                (list "表格居中" "tabm")
                                (list "字居中①" "cc1")
                                (list "字居中②" "cc2")
                                (list "引线标注" "cc5")
                                (list "增减数字" "cc6")
                                (list "局部放大" "fd")
                                (list "自助修剪" "trxx")
      ) ;_ 结束list
      (list "文字"
                                (list "文本加圆" "dd1")
                                (list "加下划线" "jbtx")
                                (list "字定位①" "czdw1")
                                (list "字定位②" "czdw2")
                                (list "拆分文字" "exstr")
                                (list "合并文字" "dd5")
                                (list "字对齐①" "wzqx")
                                (list "字对齐②" "dd7")
                                (list "文字加框" "wzbk")
                                (list "加圈递增" "NumInc")
      ) ;_ 结束list
    ) ;_ 结束list
  ) ;_ 结束mai_mak_panel
(defun bbdig1 ()
  (mai_make_panel
    (list
      (list "网页"
                                (list "统计设置" "aa2")
                                (list "统计长度" "aa3")
                                (list "面积统计" "AT")
                                (list "系统算器" "aa4")
                                (list "地址收藏" "aa6")
                                (list "花堂文学" "aa7")
                                (list "爱图论坛" "aa8")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig2 ()
  (mai_make_panel
    (list
      (list "绘图"
                                (list "绘制螺栓" "sd")
                                (list "绘制螺丝" "bls")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig3 ()
  (mai_make_panel
    (list
      (list "图块"
                                (list "查块连线" "bb2")
                                (list "图块替换" "bb3")
                                (list "圆心插块" "bb4")
                                (list "递增复制" "xcc")
                                (list "表格导出" "te")
                                (list "文本导出" "wr")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig4 ()
  (mai_make_panel
    (list
      (list "工具"
                                (list "递增刷子" "dz")
                                (list "相同刷子" "xts")
                                (list "做中心线" "ce")
                                (list "字居中①" "cc1")
                                (list "字居中②" "cc2")
                                (list "引线标注" "cc5")
                                (list "增减数字" "cc6")
                                (list "局部放大" "fd")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig5 ()
  (mai_make_panel
    (list
      (list "文字"
                                (list "文本加圆" "dd1")
                                (list "合并文字" "dd5")
                                (list "字对齐②" "dd7")
      ) ;_ 结束list
    ) ;_ 结束list
(defun c:bbdig6        ()
  (alert "问君能有几多愁,恰似一江春水向东流")
(defun mai_make_panel (menulist          /             n                num_nobut
        num_button nn             nnn        menuname
        val_lst          add_dclrow tt                order_lst
        in          num_image
  (defun add_dclrow (dstr /)
    (if        dstr
      (setq val_lst (cons dstr val_lst))
        (defun LM:PadBetween ( s1 s2 ch ln )
                (if (< (+ (strlen s1) (strlen s2)) ln)
                        (LM:PadBetween (strcat s1 ch) s2 ch ln)
                        (strcat s1 s2)
  (setq menuname (strcat (vl-filename-mktemp) "temp_pannel.dcl"))
  (add_dclrow
    "curbutton:button{width=10;vertical_margin=none;vertical_margin=none;}"
  (add_dclrow
    "curimage:image{width=10;height=0.2;vertical_margin=none;vertical_margin=none;}"
  (add_dclrow
    "curpanel:dialog{key=\"bbtimexx\";alignment=centered;vertical_margin=none;horizontal_margin=none;"
  (add_dclrow ":row{")
  (setq        len           (apply 'max (mapcar 'length menulist))
                order_lst  (apply 'append (mapcar 'cdr menulist))
                num_button 0
                num_nobut  0
                in           0
                num_image  0
  (foreach nn menulist
    (setq in 0)
    (add_dclrow
      (strcat " : column{label=\""
              (car nn)
              "\";vertical_margin=none; horizontal_margin=none;"
    (foreach nnn (cdr nn)
                        (setq tt (car nnn));三级列表,文字提示
                        (setq tt (if tt tt ""))
                        (setq tt-ml (cadr nnn));;获取命令***注意表中位置,第2个元素)
                        (setq tt-ml (if tt-ml tt-ml ""))
                        (setq str-n (strlen (strcat tt "  " tt-ml)))
                        (setq str-n-lst (cons str-n str-n-lst))
                );;;控制 String1..String2
                (setq str-n-max(apply 'max str-n-lst))
                        (setq num_button (1+ num_button);二级列表,按钮编号
                                in (1+ in)
                                num_image (1+ num_image)
                                tt (car nnn);三级列表,文字提示
                                tt (if tt tt "")
                        (if (and(setq tt-ml (cadr nnn));;获取命令***注意表中位置,第2个元素)
                                                (/= tt-ml "")
                                                (/= tt "")
                                (setq tt (LM:PadBetween tt tt-ml "." str-n-max))
      (add_dclrow
                                (strcat
                                        ":curbutton{label=\""
                                        tt
                                        "\";horizontal_margin = none;vertical_margin = none;key=\"but"
                                        (itoa num_button)
      (if (= 30 in)
                                (progn (add_dclrow
        (strcat ":curimage{key=\"ima"
        (itoa num_image)
        "\";color=18;}"
                                        (setq in 0)
    (repeat (- len (length nn))
      (setq num_nobut (1+ num_nobut)
                                in              (1+ in)
      (add_dclrow
                                (strcat        " : curbutton{key=\"butno"
                                        (itoa num_nobut)
                                        "\";color=-2;}"
      (if (= 10 in)
                                (progn (add_dclrow
        (strcat ":curimage{key=\"ima" (itoa num_image) "\";}")
                                        (setq in 0)
    (add_dclrow "spacer;}")
  (add_dclrow
    "} :row{:button{label =\"主页\" ; key=\"bbzydig\" ; horizontal_margin = none;vertical_margin = none;} :button{label =\"网页\" ; key=\"bbwydig\" ; horizontal_margin = none;vertical_margin = none;} :button{label =\"绘图\" ; key=\"bbhtdig\" ; horizontal_margin = none;vertical_margin = none;}  :button{label =\"图块\" ; key=\"bbtkdig\" ;horizontal_margin = none;vertical_margin = none; } :button{label =\"工具\" ; key=\"bbgjdig\" ; horizontal_margin = none;vertical_margin = none;}   :button{label =\"文字\" ; key=\"bbwenzidig\" ;horizontal_margin = none;vertical_margin = none; }:button{label =\"关闭\" ; key=\"cancel\" ; is_cancel = true;horizontal_margin = none;vertical_margin = none;}:button{label =\"关于\" ; key=\"findhelp\" ; horizontal_margin = none;vertical_margin = none;}}}"
  (vl-file-delete menuname)
  (setq nn (open menuname "w"))
  (foreach n (reverse val_lst) (write-line n nn))
  (close nn)
  (setq nnn (load_dialog menuname))
  (if (not (new_dialog "curpanel" nnn))
    (exit)
  (set_tile
    "bbtimexx"
    (strcat
      (menucmd
                                "M=$(edtime,$(getvar,date), 迷你工具箱              必强提示现在时间是:YYYY/MO/DD DDDD HH:MM )"
  (action_tile "bbzydig" "(done_dialog -29999)")
  (action_tile "bbwydig" "(done_dialog -30000)")
  (action_tile "bbhtdig" "(done_dialog -30001)")
  (action_tile "bbtkdig" "(done_dialog -30002)")
  (action_tile "bbgjdig" "(done_dialog -30003)")
  (action_tile "bbwenzidig" "(done_dialog -30004)")
  (action_tile "findhelp" "(c:bbdig6)")
  (setq n 0)
  (repeat num_nobut
    (mode_tile (strcat "butno" (itoa num_nobut)) 1)
    (setq num_nobut (1- num_nobut))
      (setq n  (1+ n)
                                tt (car nnn)
                                tt (if tt
                                                 tt
                                tt order_lst
      (if (= tt "")
                                (mode_tile (strcat "but" (itoa n)) 1)
                                (action_tile
                                        (strcat "\(done_dialog " (itoa n) "\)")
  (setq nn (start_dialog))
  (unload_dialog nnn)
  (if (= nn -29999)
    (bbdig0)
  (if (= nn -30000)
    (bbdig1)
  (if (= nn -30001)
    (bbdig2)
  (if (= nn -30002)
    (bbdig3)
  (if (= nn -30003)
    (bbdig4)
  (if (= nn -30004)
    (bbdig5)
  (if (> nn 0)
    (progn (setq tt (cadr (nth (1- nn) order_lst)))
                        (princ "\n")
                        (if (= (eval (read (strcat "(type c:" tt ")"))) 'SUBR)
                                (eval (read (strcat "(c:" tt ")")))
                                (vl-cmdf tt)
发表于 2021-2-2 09:54:35 | 显示全部楼层
谢谢群主,回馈本帖,记忆这个是同一个命令下面IF函数用得过多造成的,我的解决方案是将IF函数拆分,就不会出现“在主页,进去其他菜单(如网页),,要点两次关闭才能关闭”这个问题了,,,伸手党本来想收一个币来着(折腾了几个小时才搞定的),好像系统出问题了,传不上来附件,,算了,!!!希望还有更简便的解决方案!!
(defun c:bb ()
(if (null bbdigopen) (setq bbdigopen -1))
(if (= bbdigopen -1) (bbdig0) (c:bb01))
(princ))
(defun c:bb01 ()
(if (= bbdigopen -2) (bbdig1) (c:bb02))
(princ))
(defun c:bb02 ()
(if (= bbdigopen -3) (bbdig2) (c:bb03))
(princ))
(defun c:bb03 ()
(if (= bbdigopen -4) (bbdig3) (c:bb04))
(princ))
(defun c:bb04 ()
(if (= bbdigopen -5) (bbdig4) (bbdig5))
(princ))
(defun bbdig0 ()
(setq bbdigopen -1)
  (mai_make_panel
    (list
      (list "网页"
            (list "批量打印" "aa1")
            (list "统计设置" "aa2")
            (list "统计长度" "aa3")
            (list "面积统计" "AT")
            (list "系统算器" "aa4")
            (list "地址收藏" "aa6")
            (list "花堂文学" "aa7")
            (list "爱图论坛" "aa8")
      ) ;_ 结束list
      (list "绘图"
            (list "绘制螺栓" "sd")
            (list "绘制螺丝" "bls")
      ) ;_ 结束list
      (list "图块"
            (list "查块连线" "bb2")
            (list "图块替换" "bb3")
            (list "圆心插块" "bb4")
            (list "图块编号" "PEACE-BN")
            (list "递增复制" "xcc")
            (list "表格导出" "te")
            (list "文本导出" "wr")
      ) ;_ 结束list
      (list "工具"
            (list "递增刷子" "dz")
            (list "相同刷子" "xts")
            (list "做中心线" "ce")
            (list "字居中①" "cc1")
            (list "字居中②" "cc2")
            (list "引线标注" "cc5")
            (list "增减数字" "cc6")
            (list "局部放大" "fd")
      ) ;_ 结束list
      (list "文字"
            (list "文本加圆" "dd1")
            (list "合并文字" "dd5")
            (list "字对齐②" "dd7")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig1 ()
(setq bbdigopen -2)
  (mai_make_panel
    (list
      (list "网页"
            (list "批量打印" "aa1")
            (list "统计设置" "aa2")
            (list "统计长度" "aa3")
            (list "面积统计" "AT")
            (list "系统算器" "aa4")
            (list "地址收藏" "aa6")
            (list "花堂文学" "aa7")
            (list "爱图论坛" "aa8")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig2()
(setq bbdigopen -3)
  (mai_make_panel
    (list
(list "绘图"
            (list "绘制螺栓" "sd")
            (list "绘制螺丝" "bls")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig3 ()
(setq bbdigopen -4)
  (mai_make_panel
    (list
      (list "图块"
            (list "查块连线" "bb2")
            (list "图块替换" "bb3")
            (list "圆心插块" "bb4")
            (list "递增复制" "xcc")
            (list "表格导出" "te")
            (list "文本导出" "wr")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig4()
(setq bbdigopen -5)
  (mai_make_panel
    (list
      (list "工具"
            (list "递增刷子" "dz")
            (list "相同刷子" "xts")
            (list "做中心线" "ce")
            (list "字居中①" "cc1")
            (list "字居中②" "cc2")
            (list "引线标注" "cc5")
            (list "增减数字" "cc6")
            (list "局部放大" "fd")
      ) ;_ 结束list
    ) ;_ 结束list
(defun bbdig5()
(setq bbdigopen -6)
  (mai_make_panel
    (list
      (list "文字"
            (list "文本加圆" "dd1")
            (list "合并文字" "dd5")
            (list "字对齐②" "dd7")
      ) ;_ 结束list
    ) ;_ 结束list
(defun c:bbdig6() (alert "问君能有几多愁,恰似一江春水向东流" )  (princ))
(defun mai_make_panel ( menulist / n num_nobut num_button nn nnn menuname val_lst add_dclrow tt order_lst in num_image)
(defun add_dclrow ( dstr / ) (if dstr (setq val_lst (cons dstr val_lst))))(setq menuname (strcat (vl-filename-mktemp) "temp_pannel.dcl"))
(add_dclrow "curbutton:button{width=10;vertical_margin=none;vertical_margin=none;}")(add_dclrow "curimage:image{width=10;height=0.2;vertical_margin=none;vertical_margin=none;}")
(add_dclrow "curpanel:dialog{key=\"bbtimexx\";alignment=centered;vertical_margin=none;horizontal_margin=none;")(add_dclrow ":row{")
(setq len (apply 'max (mapcar 'length menulist)) order_lst (apply 'append (mapcar 'cdr menulist)) num_button 0  num_nobut 0  in 0 num_image 0)
(foreach nn menulist(setq in 0)(add_dclrow (strcat " : column{label=\"" (car nn) "\";vertical_margin=none; horizontal_margin=none;"))
(foreach nnn (cdr nn)(setq num_button (1+ num_button) in (1+ in) num_image (1+ num_image) tt (car nnn)  tt (if tt tt ""))
(add_dclrow (strcat ":curbutton{label=\"" tt "\";horizontal_margin = none;vertical_margin = none;key=\"but" (itoa num_button) "\";}"))
(if (= 30 in)(progn (add_dclrow (strcat ":curimage{key=\"ima" (itoa num_image) "\";color=18;}"))(setq in 0))))
(repeat (- len (length nn))(setq num_nobut (1+ num_nobut) in (1+ in) num_image (1+ num_image))(add_dclrow (strcat " : curbutton{key=\"butno" (itoa num_nobut) "\";color=-2;}"))
(if (= 10 in)(progn (add_dclrow (strcat ":curimage{key=\"ima" (itoa num_image) "\";}"))(setq in 0))))(add_dclrow "spacer;}"))
(add_dclrow "} :row{:button{label =\"主页\" ; key=\"bbzydig\" ; horizontal_margin = none;vertical_margin = none;} :button{label =\"网页\" ; key=\"bbwydig\" ; horizontal_margin = none;vertical_margin = none;} :button{label =\"绘图\" ; key=\"bbhtdig\" ; horizontal_margin = none;vertical_margin = none;}  :button{label =\"图块\" ; key=\"bbtkdig\" ;horizontal_margin = none;vertical_margin = none; } :button{label =\"工具\" ; key=\"bbgjdig\" ; horizontal_margin = none;vertical_margin = none;}   :button{label =\"文字\" ; key=\"bbwenzidig\" ;horizontal_margin = none;vertical_margin = none; }:button{label =\"关闭\" ; key=\"cancel\" ; is_cancel = true;horizontal_margin = none;vertical_margin = none;}:button{label =\"关于\" ; key=\"findhelp\" ; horizontal_margin = none;vertical_margin = none;}}}")
(vl-file-delete menuname)(setq nn (open menuname "w"))(foreach n (reverse val_lst) (write-line n nn))(close nn)(setq nnn (load_dialog menuname))
(if (not (new_dialog "curpanel" nnn)) (exit))
(set_tile "bbtimexx" (strcat (menucmd "M=$(edtime,$(getvar,date), 迷你工具箱              必强提示现在时间是:YYYY/MO/DD DDDD HH:MM )")))
(action_tile "cancel"  "(done_dialog 0)")(action_tile "bbzydig"  "(done_dialog -1)")(action_tile "bbwydig"  "(done_dialog -2)")(action_tile "bbhtdig"  "(done_dialog -3)")(action_tile "bbtkdig"  "(done_dialog -4)")(action_tile "bbgjdig"  "(done_dialog -5)")(action_tile "bbwenzidig"  "(done_dialog -6)")(action_tile "findhelp"  "(c:bbdig6)")
(setq n 0)(repeat num_nobut (mode_tile (strcat "butno" (itoa num_nobut)) 1) (setq num_nobut (1- num_nobut)))(foreach nn menulist(foreach nnn (cdr nn)(setq n (1+ n) tt (car nnn) tt (if tt tt "") tt order_lst)
(if (= tt "")(mode_tile (strcat "but" (itoa n)) 1)(action_tile (strcat "but" (itoa n)) (strcat "\(done_dialog " (itoa n) "\)")))))(setq nn (start_dialog))(unload_dialog nnn)(vl-file-delete menuname)
(if (= nn -1) (bbdig0))(if (= nn -2) (bbdig1))(if (= nn -3) (bbdig2))(if (= nn -4) (bbdig3))(if (= nn -5)(bbdig4))(if (= nn -6)(bbdig5))
(if (> nn 0)(progn (setq tt (cadr (nth (1- nn) order_lst)))(princ "\n")(if (= (eval (read (strcat "(type c:" tt ")"))) 'SUBR)(eval (read (strcat "(c:" tt ")")))(vl-cmdf tt)))))
参与人数 1明经币 +2 收起 理由
xyp1964 + 2 赞一个!
发表于 2019-6-2 23:45:23 | 显示全部楼层
;;这个也能优化成带记忆那版那样的不 titl:标题; buttons:按钮列表; flag:nil先行后列T先列后行(defun Dcl-ButtonM (titl buttons flag / a b c)  (defun strsplist (str / i)    (if        (setq i (vl-string-search " " str))      (list (substr str 1 i)            (vl-string-trim " " (substr str (+ 2 i)))      )    )  )  (defun makedcl (str_lst / fileID dclHandle)    (setq dclfile (vl-filename-mktemp nil nil ".dcl")          fileID  (open dclfile "w")    )    (cond ((= (type str_lst) 'str) (write-line str_lst fileID))          ((= (type str_lst) 'list)           (foreach n str_lst (write-line n fileID))          )    )    (close fileID)    (setq dclHandle (load_dialog dclfile))  )  (setq        b (if flag            ":column{ label = \""            ":row{children_alignment = top ;\n    children_fixed_height = true ;\n label = \""          )        c (if flag            ":row{children_alignment = top ;\n    children_fixed_height = true ;\nlabel = \""            ":column{label = \""          )        d '("ESC")        a (strcat (vl-string-translate                    "$~"                    "AB"                    (vl-filename-base (vl-filename-mktemp))                  )                  ":dialog{label=\""                  titl                  "\";\n"                  b                  "\";\n"          )  )  (foreach x buttons    (if        (listp x)      (progn        (setq a (strcat a c (car x) "\";\n"))        (foreach y (last x)          (setq        b (strsplist y)                a (if b                    (strcat a                            ":button {key =\""                            (car b)                            "\";label=\""                            (last b)                            "\";}\n"                    )                    (strcat a "spacer_0;\n")                  )                d (if (/= (car b) nil)                    (cons (car b) d)                    d                  )          )        )        (setq a (strcat a "}\n"))      )      (setq a (strcat a "spacer_0;\n"))    )  )  (setq        d    (cdr (REVERSE d))        a    (strcat a                     (if flag                       "} spacer_1;:row"                       "} spacer_1;:row"                     );;;                     "{spacer_0;:button{key = \"HLP\";label = \"帮助\";}\n";;;                     ":button{key=\"ESC\";label=\"取消\";is_cancel = true;}}}";;;         "{alignment = centered ;\n fixed_width = true ; \n spacer_0;\n cancel_button; \n;;;         :text{fixed_width = true ; \n width = 2;\n } \n help_button;}}"          "{alignment = centered ; \n fixed_width = true ;\n help_button; \n :text{fixed_width = true ; \n width = 2;\n } \n cancel_button;}}"             )        dcl  (makedcl a)        lst1 '()        i    1  )  (foreach key d    (setq tx   (strcat "(action_tile \""                       key                       "\"\"(done_dialog "                       (itoa i)                       ")\")"               )          lst1 (cons tx lst1)          i    (1+ i)    )  )  (new_dialog (substr a 1 8) dcl)  ;(action_tile "ESC" "(done_dialog 0)")  (action_tile "cancel" "(done_dialog 0)")  ;(action_tile "HLP" "(alert\"通用了,还郁闷?\")")  (action_tile "help" "(alert\"通用了,还郁闷?\")")  (eval (read (strcat "(progn" (apply 'strcat lst1) ")")))  (setq ctl (start_dialog))  (UNLOAD_DIALOG dcl)  (vl-file-delete dclfile)  (if (/= ctl 0)    (progn      (setq cmds(nth (- ctl 1) d))    (cond      ((or(= (eval (read (strcat "(type c:" cmds ")"))) 'SUBR)      (= (eval (read (strcat "(type c:" cmds ")"))) 'USUBR))       (princ "\n")      (eval (read (strcat "(c:" cmds ")"))))      ((or(= (eval (read (strcat "(type " cmds ")"))) 'SUBR)      (= (eval (read (strcat "(type " cmds ")"))) 'USUBR))       (princ "\n")      (eval (read (strcat "(" cmds ")"))))      (t (princ "\n")(vl-load-com)(vl-cmdf cmds))    )      )      ))(defun c:tt (/ lst)  (setq        lst '(("钢筋、书写"               ("xyp-gjg 钢筋结钩(&G) " "lljx 另类镜像(&L) " ""        "bjcl 板筋处理(&!) " "dtbj 动态板筋 ")              )              ("注筋、标注"               ("zjpb 注筋排版(&1) " "zjzz 注筋左置 " "" "zjyw 注筋移位 " "gtcm 改图层名 ")              )              ("桩基网架"               ("zjct 桩基承台 " "zjtj 桩基统计 " "" "pbwj 平板网架 " "qxhj 曲线桁架 ")              )              ("编辑处理"               ("glbh 改粱编号 " "lkjd 梁宽校对 " "" "lzxj 梁柱修剪 " "xyp-jzl 井字梁 " "tt2 切换(&C) " "tt22 TT ")              )             )  )  (Dcl-ButtonM "【XX工具】V2014.1.21" lst t)  (princ))(defun c:tt2 (/ lst)  (setq        lst '(("钢筋、书写"               ("xyp-gjg 钢筋结钩 " "lljx 另类镜像 " ""   "bjcl 板筋处理 " "dtbj 动态板筋 ")              )              ("注筋、标注"               ("zjpb 注筋排版 " "zjzz 注筋左置 " "" "zjyw 注筋移位 " "gtcm 改图层名 ")              )              ("桩基网架"               ("zjct 桩基承台 " "zjtj 桩基统计 " "" "pbwj 平板网架 " "qxhj 曲线桁架 " "line 直线")              )              ("编辑处理"               ("glbh 改粱编号 " "lkjd 梁宽校对 " "" "lzxj 梁柱修剪 " "xyp-jzl 井字梁 "  "tt3 切换(&C) ")              )             )  )  (Dcl-ButtonM "呵呵,我是第二窗口哦" lst nil)  (princ))(defun tt3 (/ lst)  (setq        lst '(("钢筋、书写"               ("xyp-gjg 钢筋结钩 " "lljx 另类镜像 " ""   "bjcl 板筋处理 " "dtbj 动态板筋 ")              )              ("注筋、标注"               ("zjpb 注筋排版 " "zjzz 注筋左置 " "" "zjyw 注筋移位 " "gtcm 改图层名 ")              )              ("桩基网架"               ("zjct 桩基承台 " "zjtj 桩基统计 " "" "pbwj 平板网架 " "qxhj 曲线桁架 ")              )              ("编辑处理"               ("glbh 改粱编号 " "lkjd 梁宽校对 " "" "lzxj 梁柱修剪 " "xyp-jzl 井字梁 " "tt 切换(&C) ")              )             )  )  (Dcl-ButtonM "哈哈,我是第三个窗口哦" lst nil)  (princ))
发表于 2019-3-15 13:33:24 | 显示全部楼层
变成附件 上传一下吧
 楼主| 发表于 2019-3-15 15:17:09 | 显示全部楼层
依然小小鸟 发表于 2019-3-15 13:33
变成附件 上传一下吧
已上传,请查收
发表于 2019-3-15 15:20:20 | 显示全部楼层
如果其中一个命令暂停使用  怎么把按键变灰色。
 楼主| 发表于 2019-3-15 15:28:45 | 显示全部楼层
(mode_tile "key1" 0) 为亮
(mode_tile "key1" 1) 为暗
(mode_tile "key1" 2)
发表于 2019-3-15 15:31:27 | 显示全部楼层
1291500406 发表于 2019-3-15 15:28
试试
我小白   看不懂
 楼主| 发表于 2019-3-15 15:39:30 | 显示全部楼层
htlaser 发表于 2019-3-15 15:31
我小白   看不懂
暗显测试
发表于 2019-3-15 16:01:31 | 显示全部楼层
对  是这样的效果
谢谢  我参考一下
发表于 2019-3-15 16:07:05 | 显示全部楼层
(mode_tile "bbwydig" 1)
(mode_tile "bbtkdig" 1)
(mode_tile "NumInc" 1) ;(list "加圈递增" "NumInc")这句我加上没用
GMT+8, 2025-12-3 10:00 , Processed in 0.211587 second(s), 34 queries , Gzip On.
