查看: 1845|回复: 2
[提问] 怎么计算框内数据的平均值和最大最小值呢?
发表于 2019-3-21 12:30:07 | 显示全部楼层 |阅读模式
(defun C:EE ( / #g1 &kw &ss1 ent x)
(if (and
  (setq ent (entsel "\n请选择封闭的多段线"))
  (setq ent (car ent));图元
  (setq #g1 (entget ent));属性
  (= (cdr (assoc 0 #g1)) "LWPOLYLINE");分析是多段线
  (= (cdr (assoc 70 #g1)) 1);判断是封闭
  (setq &ss1 (mapcar 'cdr (vl-remove-if '(lambda (X) (/= 10 (car x))) #g1)));多段线上的点
   (if (setq &kw (ssget "wp" &ss1))
   ;框选择 包含在框内的及和框相交的被选择;如果要窗选【cp】修改为【wp】即可
    (setq &kw (ssadd ent &kw))
     (setq &kw (ssadd) &kw (ssadd ent &kw))
   (command "erase" "all" "r" &kw "")
发表于 2019-3-21 14:19:56 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (and (setq s1 (car (entsel "\n请选择封闭的多段线")))
  3.            (setq ent (entget s1))
  4.            (= (cdr (assoc 0 ent)) "LWPOLYLINE") ;分析是多段线
  5.            (or (member (cdr (assoc 70 ent)) '(1 129))
  6.                (equal (vlax-curve-getStartPoint s1)
  7.                       (vlax-curve-getEndPoint s1)
  8.                       1e-3
  9.                )
  10.            )
  11.            (setq ptn (mapcar 'cdr
  12.                              (vl-remove-if '(lambda (X) (/= (car x) 10)) ent)
  13.                      )
  14.            )
  15.            (setq ss (ssget "wp" ptn '((0 . "TEXT") (1 . "~*[~`--9]*"))))
  16.       )
  17.     (setq lst  (mapcar '(lambda (x) (distof (cdr (assoc 1 (entget x)))))
  18.                        (mapcar 'cadr (cdr (reverse (ssnamex ss))))
  19.                )
  20.           nn   (length lst)
  21.           pjz  (/ (apply '+ lst) nn 1.)        ;平均值
  22.           lst  (vl-sort lst '<)
  23.           Nmin (car lst)                ;最小值
  24.           Nmax (last lst)                ;最大值
  25.     )
  26.   )
  27.   (princ)
  28. )
发表于 2019-3-21 23:35:49 | 显示全部楼层
谢谢! xyp1964 分享程序!!!!!!
GMT+8, 2025-5-19 01:29 , Processed in 0.174036 second(s), 26 queries , Gzip On.
