查看: 1789|回复: 3
[讨论] 隔壁论坛淘来的好东西,希望大神完善~~~
发表于 2019-4-10 12:59:48 | 显示全部楼层 |阅读模式
;;;适用于天正给排水的,布局关视口By FireflyButler
(defun c:sk (/ tuceng)
  (command "_.undo" "be")
  (setvar "cmdecho" 0)
  (setq tuceng (getvar "clayer"))
  (foreach n '("zll-废水" "zll-给水" "zll-通气" "zll-热水" "zll-雨水" "zll-回水" "zll-消防" "zll-中水" "zll-喷淋" "zll-地漏" "zll-消火栓" "zll-灭火器")(xjtc n))
  (setvar "clayer" tuceng)
  (setq layer1 "*喷淋*,*喷头*,*雨水*,*喷头*,*中水*,*污水*,*废水*,*通气*,*地漏*")
  ;;保留给水及消火栓,关掉喷淋
  (setq        layer2
         "*给水*,*消防*,*回水*,*消火栓*,*灭火器*,*喷淋*,*喷头*,*中水*"
  ;;保留排水
  (setq        layer3
         "*给水*,*回水*,*污水*,*废水*,*消防*,*消火栓*,*灭火器*,*中水*,*雨水*,*通气*,*地漏*"
  ;;保留喷淋
  (initget "GS PS ZP R")
  (if (not
        (setq kword
               (getkword
                 "\n输入保留的图层:冷热水消防(GS),排水(PS),自动喷淋(ZP),重置视口(R)"
    (setq kword "GS")
  (cond
    ((= kword "GS") (command "vplayer" "f" layer1 "c" ""))
    ((= kword "PS") (command "vplayer" "f" layer2 "c" ""))
    ((= kword "ZP") (command "vplayer" "f" layer3 "c" ""))
   ((= kword "R") (command "vplayer" "r" "*" "c" ""))
  (command "-purge" "la" "zll-*" "n")
  (command "_.undo" "end")
  (setvar "cmdecho" 1)
(defun xjtc (xtcm)                        ;创建图层函数,可以先判断是否存在
  (if
    (null (tblsearch "layer" xtcm))
     (entmake (list '(0 . "LAYER")
                    '(100 . "AcDbSymbolTableRecord")
                    '(100 . "AcDbLayerTableRecord")
                    '(6 . "continuous")
                    '(62 . 7)
                    '(370 . 0)
                    '(70 . 0)
                    '(290 . 1)
                    (cons 2 xtcm)
                                        ;6组码【线型】,62组码【颜色】,370组码【线宽】,70组码【可见】,290组码【打印】,2组码【图层名称】
  (prin1)
希望大神完善   不同的视口  可以关闭自己想关闭的图层  而不影响其他视口
发表于 2019-4-10 15:05:29 | 显示全部楼层
(command "vplayer" "f" 图层名 "" "")
 楼主| 发表于 2020-11-18 08:56:15 | 显示全部楼层
有完整的代码 吗  我是小白啥都不懂
 楼主| 发表于 2023-6-4 11:29:35 | 显示全部楼层
希望有大神能解决
GMT+8, 2025-5-14 20:04 , Processed in 0.155653 second(s), 26 queries , Gzip On.
