查看: 1503|回复: 0
怎样为Block用SetXData设置延伸数据(请帮忙看看我的程序错在哪里)
发表于 2004-3-16 11:09:00 | 显示全部楼层 |阅读模式
通过下面的代码用SetXData怎么也为块加不上延伸数据,请高手帮帮忙,不胜感激 Private Sub Command6_Click() Dim acadDoc As AcadDocument
Dim acadapp As AcadApplication Dim blockObj As AcadBlock
Dim startPoint(0 To 2) As Double
Dim endPoint(0 To 2) As Double Dim AppName As String
Dim XData(0 To 1) As Variant
Dim XDType(0 To 1) As Integer
Dim insertionPnt(0 To 2) As Double On Error Resume Next
Set acadapp = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set acadapp = CreateObject("AutoCAD.Application")
End If
acadapp.Visible = 1
Set acadDoc = acadapp.ActiveDocument insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = acadDoc.Blocks.Add(insertionPnt, "New_Block") startPoint(0) = 1
startPoint(1) = 1
startPoint(2) = 0
endPoint(0) = 5
endPoint(1) = 5
endPoint(2) = 0 Call blockObj.AddLine(startPoint, endPoint) AppName = "Pline"
XDType(0) = 1001
XData(0) = AppName
XDType(1) = 1000
XData(1) = "wo hui cheng gong" Call blockObj.SetXData(XDType, XData)
End Sub
GMT+8, 2025-5-25 17:17 , Processed in 0.162568 second(s), 24 queries , Gzip On.
