查看: 959|回复: 2
[源码] 连续copy的问题
发表于 2019-4-25 02:36:16 | 显示全部楼层 |阅读模式
工作中,经常需要copy+对齐
无意中看到平衡copy,比正交更实用,但只能copy一次,改造了很长时间,也不能连续copy 下去
(defun c:mx1 ( / p1)
        (command "move" (ssget) "" (setq p1 (getpoint "\n请点取基点:")) (subst (car (getpoint "\n请点取参考点:")) (car p1) p1))
;以下能用,但结果不是我想要的,不清楚问题在那?
;我的目的是,连续copy,且copy的物体不需要正交,点选任何一点也能平衡x轴,copy下去
(defun c:cx1 ( / p1)
         (setq obj (entsel "\n选择点选一个块<退出>:"))
         (setq p1 (cdr (assoc 10 (entget (car obj)))));获取基点座标
         (while (setq p2 (getpoint p1 "\n指定位移的第二点: "))
           (setq s0 (entlast))
           (command "copy" obj "" p1 "non" p2 (car p1) p1))
           (setq ss2 (ssadd))
           (while (setq s0 (entnext s0))
           (ssadd s0 ss2)
请有能力的坛友帮忙改造一下,谢谢
发表于 2019-4-25 09:15:49 | 显示全部楼层
        (setq p2 (list (car p2) (cadr p1) (caddr p2)))
        (command "copy" obj "" "non" p1 "non" p2)
(c:cx1)
alexmai + 1 很给力!
 楼主| 发表于 2019-4-25 09:45:50 | 显示全部楼层
    (setq obj (entsel "\n选择点选一个块:"))
    (setq p1 (cdr (assoc 10 (entg ...
大大大感谢
GMT+8, 2025-5-19 04:54 , Processed in 0.257905 second(s), 28 queries , Gzip On.
