查看: 792|回复: 4
[提问] (修改边长)水平有限,研究几天就是目前的结果,希望高手出击
发表于 2019-4-30 12:04:17 | 显示全部楼层 |阅读模式
20明经币
  1. (defun c:tt1 ()
  2.   (setq i 0)
  3.     (setq pline (car (entsel)))
  4.     (setq ent (entget pline))
  5.     (setq pts nil)
  6.     (repeat (length ent)
  7.     (if (= (car (nth i ent)) 10)
  8.         (setq pts (append pts (list (cdr (nth i ent)))))
  9.     )
  10.     (setq i (1+ i))
  11.     )
  12.     (print pts)
  13.   (nth 0 pts)
  14.   (setq pt1 (getpoint "点1:"))
  15.   (setq pt2 (getpoint pt1 "点2:"))
  16.     (setq ent(subst(cons 10 pt1)(assoc 10 ent)ent))
  17.   (entmod ent);重生成更新图元,显示到鼠标 位置
  18. )
1 修改点2位置
2 可以修改任意边长
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2019-4-30 12:04:18 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq i 0)
  4.     (setq Object (vlax-ename->vla-object pline))
  5.     (setq ent (entget pline))
  6.     (setq pts nil)
  7.     (repeat (length ent)
  8.     (if (= (car (nth i ent)) 10)
  9.         (setq pts (append pts (list (cdr (nth i ent)))))
  10.     )
  11.     (setq i (1+ i))
  12.     )
  13.     (print pts)
  14.   (nth 0 pts)
  15.   (setq pt1 (getpoint "点1:"))
  16.   (setq pt2 (getpoint pt1 "点2:"))
  17.   (setq pt1a (car (vl-sort pts (function(lambda (e1 e2)(< (distance pt1 e1) (distance pt1 e2)))))))
  18.   (setq pt2a (car (vl-sort pts (function(lambda (e1 e2)(< (distance pt2 e1) (distance pt2 e2)))))))
  19.   (setq pt1 (list (car pt1) (cadr pt1)))
  20.   (setq pt2 (list (car pt2) (cadr pt2)))
  21.   (vla-put-Coordinate Object (vlax-curve-getparamatpoint Object pt1a) (vlax-make-variant(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pt1)))) pt1 )))
  22.   (vla-put-Coordinate Object (vlax-curve-getparamatpoint Object pt2a) (vlax-make-variant(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pt2)))) pt2 )))
  23. (princ)
  24. )
 楼主| 发表于 2019-4-30 18:08:32 | 显示全部楼层
遇到问题无法确定选中那个边长 两个坐标 如果知道就很好处理了
 楼主| 发表于 2019-11-20 23:12:08 | 显示全部楼层
无法解决无法解决
 楼主| 发表于 2019-11-21 08:35:14 | 显示全部楼层
非常感谢 可以正常使用
GMT+8, 2025-5-18 13:01 , Processed in 0.175962 second(s), 25 queries , Gzip On.
