查看: 745|回复: 4
[提问] 求助~把文字高度放大1.25倍。怎么修改可以只输一次ttt,连续对不同对象操作呢?
发表于 2019-5-3 10:36:48 | 显示全部楼层 |阅读模式
(defun C:ttt ()
(princ "\n 选择源:")
(setq e (ssget "_+.:E:S" '((0 . "*TEXT,*DIMENSION"))))
     (setq e (ssname e 0))
     (setq en (entget e))
            (setq TextW (cdr (assoc 40 en)))
(princ TextW)
(setq TextW (/ TextW 0.8))
(princ TextW)
(setq h40 (cons 40 TextW))
(setq b (assoc '0 en))
(setq b (cdr b))
(if (= b "TEXT")
(setq h (assoc '40 en))
(setq en (subst h40 h en))
(entmod en)    (princ)
发表于 2019-5-3 11:36:30 | 显示全部楼层
Try this:
(defun C:ttt ()
   (princ "\n 选择源:")
   (while (setq e (ssget "_+.:E:S" '((0 . "*TEXT,*DIMENSION"))))
     (princ TextW)
     (princ TextW)
     (setq b (cdr b))
     (if (= b "TEXT")
         (entmod en)
发表于 2019-5-3 11:54:15 | 显示全部楼层
    • ;文字批量缩放
    • (defun c:tt (/ en n ss textw)
    •   (princ "\n 选择源:")
    •   (while (setq ss (ssget '((0 . "*TEXT"))))
    •     (repeat (setq n (sslength ss))
    •       (setq en (entget (ssname ss (setq n (1- n)))));每个文字
    •       (setq TextW (cdr (assoc 40 en)));文字高度
    •       (setq TextW (/ TextW 0.8));计算新文字高度
    •       (entmod (subst (cons 40 TextW) (assoc 40 en) en));更新组码
    •   (princ)
 楼主| 发表于 2019-5-3 22:37:18 | 显示全部楼层
感谢感谢感谢感谢~
 楼主| 发表于 2019-5-3 22:37:39 | 显示全部楼层
Andyhon 发表于 2019-5-3 11:36
Try this:
(defun C:ttt ()
Thank you very much~
GMT+8, 2025-5-18 23:06 , Processed in 0.175107 second(s), 26 queries , Gzip On.
