- 积分
- 995
- 明经币
- 个
- 注册时间
- 2019-5-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(defun c:dz () ;批量替换牙样式
(vl-load-com)
(setq myacad (vlax-get-acad-object))
(setq mydoc (vla-get-ActiveDocument myacad))
(setq myms (vla-get-ModelSpace mydoc))
(setq os (getvar "osmode"))
(setq n1 (getvar "DIMTXT"))
(setq n2 (getvar "DIMSCALE"))
(setq v2 (getvar "cmdecho")) ;获取当前的普通命令提示状态,将其赋值给V2
(setq v3 (getvar "blipmode")) ;获取当前的光标痕迹显示状态,将其赋值给变量V3
(setvar "cmdecho" 0) ;不显示普通命令的提示
(setvar "blipmode" 0)
(command "_.undo" "be")
(setq n3 (* n1 n2))
(setvar "osmode" 0)
(setq ucs (getvar "UCSORG"))
(setq gs 0)
(prompt "\n选择范围: ")
(setq ss (ssget)) ;创建一个选择集
(setq n (sslength ss)) ;计算出此选择集的字符
(setq e9 (entsel "选择过滤对象: "))
(setq tk (car e9))
(setq e10 (vlax-ename->vla-object tk))
(setq s1 (vla-get-ObjectName e10)) ;获取对象是块还是圆特征
(if (= s1 "AcDbBlockReference") ;判断是否为块
(setq mk1 (vla-get-EffectiveName e10))
(if (= s1 "AcDbCircle")
(setq s2 (vla-get-Radius e10))
;圆的半径
(setq s3 (vla-get-Linetype e10))
;圆的线性
(setq s4 (vla-get-PlotStyleName e10))
;圆的线的颜色
(alert "请选择圆或者块")
(quit) ;退出运算
(prompt "\n选择插入对象: ")
(setq sp (ssget))
(setq nn (sslength sp))
(setq k 0)
(setq kk 0)
(while (< kk nn)
(setq cha1 (ssname sp kk)) ;获取插入对象集中的单个元素的图元名
(setq cha2 (vlax-ename->vla-object cha1)) ;将图元名转换成VLA对象
(setq cc1 (vla-get-ObjectName cha2)) ;获取对象类型
(if (= cc1 "AcDbBlockReference") ;判断是否为块
(setq cc2 (vla-get-InsertionPoint cha2))
(setq cc3 (vlax-safearray->list (vlax-variant-value cc2)))
;圆孔坐标
(setq x1 (car ucs))
(setq y1 (cadr ucs))
(setq xx2 (car cc3))
(setq yy2 (cadr cc3))
(setq xx (- xx2 x1)) ;X坐标值
(setq yy (- yy2 y1)) ;圆孔的Y坐标值
(setq cc4 '(0))
(setq cc5 (cons YY cc4))
(setq cc6 (cons XX cc5))
(setq kk nn)
(if (= cc1 "AcDbCircle")
(setq cc2 (vla-get-Center cha2))
;圆孔坐标
(setq x1 (car ucs))
(setq yy (- yy2 y1)) ;Y坐标值
(setq cc4 '(0))
(setq kk nn)
(setq kk (+ 1 kk))
(IF (= KK NN)
(setvar "osmode" 16383)
(setq cc6 (getpoint "指定插入点:"))
(setvar "osmode" 0)
(while (< k N) ;循环语句开头
(setq ent1 (ssname ss k))
;获取第一个选择集的图元名
(setq sus (vlax-ename->vla-object ent1))
(setq e3 (vla-get-ObjectName sus))
;对象的类型特征
(if (= e3 s1)
(if (= e3 "AcDbCircle") ;判断是否为圆
(setq e4 (vla-get-Radius sus)) ;圆的半径
(setq e5 (vla-get-Linetype sus))
;圆的线性
(setq e8 (vla-get-PlotStyleName sus))
; 圆的线的颜色
(if (= e4 s2) ;判断是圆半径
(if (= e5 s3) ;判断是圆线型
(if (= e8 s4) ;判断是圆颜色
(setq e1 (vla-get-Center sus))
(setq
e2 (vlax-safearray->list
(vlax-variant-value e1)
) ;圆孔坐标
(setq x1 (car ucs))
(setq x2 (car e2))
(setq y2 (cadr e2))
(setq x (- x2 x1)) ;圆孔的X坐标值
(setq y (- y2 y1)) ;圆孔的Y坐标值
(setq P13 '(0))
(setq P14 (cons Y P13))
(setq P15 (cons X P14)) ;圆孔坐标
(COMMAND "COPY" sp "" cc6 p15)
(entdel ent1)
(setq gs (+ gs 1))
(if (= e3 "AcDbBlockReference")
(setq mk2 (vla-get-EffectiveName sus))
(if (= mk2 mk1)
(setq e1 (vla-get-InsertionPoint sus))
(setq
e2
(vlax-safearray->list (vlax-variant-value e1))
;块的插入坐标
(setq x1 (car ucs))
(setq x2 (car e2))
(setq y2 (cadr e2))
(setq x (- x2 x1)) ;块的插入的X坐标值
(setq y (- y2 y1)) ;块的插入的Y坐标值
(setq P13 '(0))
(setq P15 (cons X P14)) ;块的插入坐标
(entdel ent1)
(setq gs (+ gs 1))
(setq K (+ 1 K))
) ;结束循环语句
(setq ww 0)
(while (< ww nn)
(setq cha1 (ssname sp ww)) ;获取插入对象集中的单个元素的图元名
(entdel cha1)
(setq ww (+ 1 ww))
(setvar "osmode" OS) ;恢复目标捕捉的原来的状态
(setvar "blipmode" v3) ;恢复光标痕迹原来的显示状态
(setvar "osmode" 16383) ;捕捉对象设置
(setq gs1 "\n替换完成 替换:")
(setq gs2 (rtos gs 2 2))
(setq gs4 "个")
(setq gs3 (strcat gs1 gs2 gs4))
(alert gs3)
(command "_.undo" "e")
(setvar "cmdecho" v2) ;恢复普通命令提示原来的显示状态
; (aaa '("AL2" "AL2" "AL3" "AL2" "AL1" "AL1" "AL1"));删除重复文字并排序
(defun aaa (lst / lst1)
(foreach a lst
(if (not (member a lst1))
(setq lst1 (cons a lst1))
(vl-sort lst1 '<)
(defun delsame(l1 rcz / l2);;带容差去重(重复过的取第一次出现),有时处理坐标点需要考虑容差
(while l1
(setq l2(cons(car l1)l2)l1(vl-remove-if'(lambda (x)(equal(car l1)x rcz))(cdr l1))))
(reverse l2))
(defun c:dx () ;预定代码自动填写
(vl-load-com)
(setq kbwb0 (list (list 0))) ;创建空白表
(setq b '(0)) ;b是建立一个空表
(setq b1 '(0)) ;b1是建立一个空表
(setq gs 0)
(setq gs1 "添加个数:")
(setq n3 (* n1 n2))
(setvar "osmode" 0)
(prompt "\n选择范围: ")
(setq k 0)
(while (< k N)
(setq wz1 (ssname ss k))
(setq wz2 (entget wz1))
(setq wz3 (vlax-ename->vla-object wz1))
(setq wz4 (vla-get-ObjectName wz3))
(if (= wz4 "AcDbMText")
(setq wz5 (vla-get-TextString wz3))
(setq kbwb0 (cons wz5 kbwb0))
(setq k (+ 1 k))
(setq kbwb1 (cdr (reverse kbwb0))) ;所有文字表
(setq kbwb2 (aaa kbwb1))
(setq e9 (entsel "请选择一个对象: "))
(setq tk (car e9))
;圆特征
;圆的半径
;圆的线性
;圆的线的颜色
(setq sp (getstring "\n请确认输入的代码:"))
(setq k 0)
(setq wn (length kbwb2))
(while (< k wn)
(setq kbwb3 (nth k kbwb2))
(if (= kbwb3 sp)
(initget 1 "Yes No")
(setq x (getkword "代码重复是否继续使用此代码[是(Y)/否(N)]: "))
(if (= x "Yes")
(setq k wn)
(setq sp (getstring "\n请重新输入的代码:"))
(setq k 0)
(setq k (+ 1 k))
(setq jj (getstring "\n请输入颜色数值[读取对象(S):"))
(if (= jj "S")
(setq ee (entsel "\n颜色读取对象: "))
(setq ee1 (car ee))
(setq ee2 (entget ee1))
(setq ee3 (assoc 62 ee2))
(setq ee4 (cdr ee3))
(setq s (strcase sp)) ;小写变成大写
(setq k 0)
(setq ent2 (entget ent1))
;获取第一个选择集的图元名
;圆特征
;;圆的线性
; 圆的线的颜色
(if (= e3 s1) ;判断是否为圆
(setq
e2
) ;圆孔坐标
(setq x1 (car ucs))
(setq x2 (car e2))
(setq y2 (cadr e2))
(setq e6 (vla-get-Radius sus)) ;获取圆孔直径
(command "chprop" ent1 "" "C" ee4 "")
(setq e7 (+ 3 E6))
(setq P13 '(0))
(setq P12 (polar P15 (* 0.25 pi) E7))
;字码位置坐标
;(setq P12 (reverse (cdr (reverse P12))))
(setq b (cons P12 b))
;在表对的前面添加字码位置内容
(setq gs (+ gs 1))
(setq K (+ 1 K))
) ;结束循环语句
(if (= jj "s")
(setq ee1 (car ee))
(setq k 0)
;获取第一个选择集的图元名
;圆特征
;;圆的线性
; 圆的线的颜色
(setq
e2
) ;圆孔坐标
(setq x1 (car ucs))
(setq x2 (car e2))
(setq y2 (cadr e2))
;获取圆孔直径
(setq e7 (+ 3 E6))
(setq P13 '(0))
;字码位置坐标
;在表对的前面添加字码位置内容
(setq gs (+ gs 1))
(setq K (+ 1 K))
(setq k 0)
;获取第一个选择集的图元名
;圆特征
;;圆的线性
; 圆的线的颜色
(setq
e2
) ;圆孔坐标
(setq x1 (car ucs))
(setq x2 (car e2))
(setq y2 (cadr e2))
;获取圆孔直径
(command "chprop" ent1 "" "C" jj "")
(setq e7 (+ 3 E6))
(setq P13 '(0))
;字码位置坐标
;在表对的前面添加字码位置内容
(setq gs (+ gs 1))
(setq K (+ 1 K))
;(setq b (cdr (reverse b)))
(setq k 0)
(setq b (vl-remove 0 b));去除表里面的0元素
(setq b1 (delsame b 0.0001));调用子函数DELSAME删除重复元素
(setq k 0)
(setq n (length b1))
(while (< k n) ;n是表元素的数目
(setq P12 (nth K b1))
(COMMAND "MTEXT" P12 "H" n3 P12 S "")
(setq K (+ 1 K))
(setq gs4 (- gs n)) ;重复的个数
(setq gs4 (rtos gs4 2 2))
(setq n (rtos n 2 2))
(setq gs5 "已删除重复文字:")
(setq gs3 (strcat gs1 n gs5 gs4))
(alert gs3)
(command "_.undo" "E")
(setvar "cmdecho" v2) ;恢复普通命令提示原来的显示状态显示状态
(defun c:NN () ;计算相同的文字在选定范围内有多少个!
(vl-load-com)
(setq v1 (getvar "osmode"))
(setvar "osmode" 0)
(setq n3 (* n1 n2))
(prompt "\n选择范围: ")
(setq ss (ssget '((0 . "MTEXT")))) ;获取选取范围内的文字
(setq NN1 (entsel "\n请选择一个参考对象: "))
(setq NN2 (car NN1))
(setq NN3 (entget NN2))
(setq NN4 (assoc '1 NN3))
(setq NN5 (cdr NN4)) ;获取文字
(setq NN6 (assoc '0 NN3))
(setq NN7 (cdr NN6)) ;获取文字类型
(if (= NN7 "MTEXT")
(setq r3 "你选择的不是文字")
(alert r3)
(prin1)
(quit)
(setq BZ (entsel "\n请选择侧面标注: "))
(setq BZ1 (car BZ))
(setq BZ2 (vlax-ename->vla-object BZ1)) ;图元名转换为VLA对象
(setq KS (vla-get-ObjectName BZ2))
(if (= KS "AcDbMText")
(setq m1 (vla-get-TextString BZ2))
(setq m1 (vla-get-TextOverride BZ2))
(if (= m1 "")
(setq r4 "数据前面Ф或M")
(alert r4)
(prin1)
(quit)
(setq p (getpoint "\n选取代码放置位置:"))
(setq k 0)
(setq TJ 0)
(while (< k n)
(setq ent3 (assoc '1 ent2))
(setq ent4 (cdr ent3)) ;获取文字
(if (= NN5 ent4)
(setq TJ (+ TJ 1))
(setq ent2 (subst (cons 62 1) (assoc 62 ent2) ent2))
(entmod ent2)
(setq K (+ 1 K))
(COMMAND "MTEXT" p "h" n3 p NN5 "")
(setq TJ1 (rtos TJ 2 2))
(setq e8 (strcat TJ1 "-" m1))
(setq TJ2 (strcat TJ1 "X"))
(setq mzls (vl-string-search "2X" M1)) ;判断字符串里面有没有“2X”
(if (= MZLS nil)
(vlax-put-property BZ2 'TextString e8)
(setq e8 (vl-string-subst TJ2 "2X" M1));寻找字符串里面的“2”替换成计算个数
(if (= MZLS nil)
(command "DIMEDIT" "n" e8 BZ "")
(setvar "osmode" v1) ;恢复目标捕捉的原来的状态
以上插件有三个功能,替换图,放代码,统计代码数量.执行命令时程序会关闭捕捉,按ESC中断操作,捕捉状态不能还原.我是小白,不知道怎么修改代码,求大神帮忙修改一下,使中断操作时捕捉状态能够还原,谢谢
