查看: 903|回复: 2
关于monochrome.ctb打印的问题
发表于 2019-5-9 10:16:45 | 显示全部楼层 |阅读模式
  1.     Const NewFile = "monochrome.ctb"
  2.     Na = ThisDrawing.ActiveLayout.Name
  3.     ThisDrawing.ActiveLayout.StyleSheet = NewFile
复制代码
已经通过代码设置了"monochrome.ctb"的打印样式 ,但是打出来以后有颜色的线条还是虚的,这是什么问题?
发表于 2019-5-31 19:46:53 | 显示全部楼层
With Me.Thisdrawing.ActiveLayout
                .ConfigName = "DWG To PDF.pc3"
                .UseStandardScale = True
                .PaperUnits = AcPlotPaperUnits.acMillimeters
                .StandardScale = AcPlotScale.acScaleToFit
                .SetWindowToPlot(leftdownPnt, rightUpPnt)
                .PlotHidden = False
                .CenterPlot = True
                .PlotWithLineweights() = False
                .StyleSheet = "monochrome.ctb"
            End With
 楼主| 发表于 2019-6-26 11:01:23 | 显示全部楼层
                .U ...
Thanks♪(・ω・)ノ学习了
GMT+8, 2025-5-23 04:29 , Processed in 0.156743 second(s), 22 queries , Gzip On.
