查看: 1655|回复: 4
[提问] 【已解决】【求助】图层名称去前缀
发表于 2019-5-31 16:33:13 | 显示全部楼层 |阅读模式
  1. ;http://bbs.mjtd.com/forum.php?mod=viewthread&tid=100184&highlight=%CD%BC%B2%E3%2B%C7%B0%D7%BA
  2. ;!!!全部图层加前缀<除0,Defpoints>
  3. (defun c:tt ( / YY_QIANZ *doc* LAY LAYERS OLDMING)
  4.   (vl-load-com)
  5.   (setq YY_QIANZ (getstring "\n输入图层要加的前缀:"))
  6.   (if YY_QIANZ
  7.     (progn
  8.   (setq *doc* (vla-get-activedocument (vlax-get-acad-object))
  9.         layers (vla-get-layers *doc*)
  10.   )
  11.   (vlax-for lay layers (setq OLDMING (vla-get-name lay))
  12.             (if (not (member OLDMING '("0" "Defpoints")))
  13.               (vla-put-Name lay (strcat YY_QIANZ OLDMING))
  14.             )
  15.   )
  16.     )
  17.   )
  18. )
上面是给图层名称加前缀的代码,请问如果需要反向操作,去掉已经加上去的前缀改怎么改呀
发表于 2019-5-31 16:37:25 | 显示全部楼层
还是这个程序,只不过对OLDMING字符串要处理,比如在它前面剪切掉什么东西
 楼主| 发表于 2019-5-31 20:58:42 | 显示全部楼层
你那边有程序可以处理吗?
发表于 2019-5-31 21:36:32 | 显示全部楼层
  1. ;; 图层去前缀
  2. (defun c:tt ()
  3.   (if (setq qz (getstring "\n输入图层要删除的前缀: "))
  4.     (vlax-for la (vla-get-layers(vla-get-activedocument (vlax-get-acad-object)))
  5.       (setq tx (vla-get-name la))
  6.       (if (and (not (member tx '("0" "Defpoints")))(vl-string-search qz tx))
  7.         (vla-put-Name la (substr tx (1+ (strlen qz))))
  8.       )
  9.     )
  10.   )
  11.   (princ)
  12. )
 楼主| 发表于 2019-5-31 22:02:24 | 显示全部楼层
感谢院长,院长厉害啊
GMT+8, 2025-10-24 04:13 , Processed in 0.155305 second(s), 26 queries , Gzip On.
