查看: 2586|回复: 4
圆圈编号 大神们在好好完善下吧
发表于 2019-6-3 21:29:37 | 显示全部楼层 |阅读模式
  1. ;;;;;;;;;;;;;;;;;
  2. (defun insertgc ( e / e)
  3.   (cdr(assoc 10(entget e)))
  4.   )
  5. ;;;;
  6. (defun cx-ss2en
  7.   (ss / enlst)
  8.   (cond
  9.     ((= (type ss) 'PICKSET)
  10.       (vl-remove-if-not '(lambda (x) (= (type x) 'ENAME)) (mapcar 'cadr (ssnamex SS)))
  11.     )
  12.     ((= (type ss) 'LIST)
  13.       (setq enlst (ssadd))
  14.       (last (mapcar '(lambda (x) (ssadd x enlst)) ss))
  15.     )
  16.     ((='ename(type ss))
  17.       (ssadd ss)
  18.     )
  19.   )
  20. )
  21.   ;;;;;;;;;;;;;;;;;;
  22. (defun t2t (p1 p2 p3 / p1 p2 p3) ;点到直线距离1
  23.
  24.   (abs (car (trans (mapcar '- p3 p1) 0 (mapcar '- p2 p1))))
  25.
  26. )   ;;;;;;;;;;;;;;;;
  27. (defun t1t (p1 p2 p3 / p1 p2 p3) ;点到直线距离2
  28.
  29.    (car (trans (mapcar '- p3 p1) 0 (mapcar '- p2 p1)))
  30.
  31. )
  32. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  33. (defun c:szpx (/ ssa kongbiao i ii zb paixuzb p1 p2 fgjj p3 cishu kb kbb iii iiii wenzi)
  34. (setq ssa (ssget '( (0 . "circle")  (8 . "0") ) ) )
  35. (setq kongbiao '()) (setq i 0)
  36. (foreach x (cx-ss2en ssa)
  37.
  38.     (setq zb (insertgc x)) (setq kongbiao (append (list zb) kongbiao)) (setq i (1+ i))
  39.   )
  40. (setq paixuzb (vl-sort kongbiao
  41.              (function (lambda (e1 e2)      (> (cadr e1)(cadr e2 ) )
  42.               ) ) )
  43.        )
  44. (setq p1 (getpoint "\n请选择直线起点:"))
  45.   (setq p2 (getpoint "\n请选择直线第二点:"))
  46. (setq fgjj (getREAL "\n请输入方格间距(输入数):"));输入整数
  47.   (setq p3 (last paixuzb))
  48. (setq cishu (+ 2 (fix (/ (t2t p1 p2 p3) fgjj )  ) ) )
  49. (setq kb '()) (setq ii 0)
  50. (repeat cishu
  51.
  52. (setq kbb
  53. (vl-sort (vl-remove-if-not  (FUNCTION (LAMBDA (A1) (< (* -1 fgjj) (t1t (polar p1 (+ (* 0.5 pi)(angle p1 p2)) (* ii fgjj)) (polar p2 (+ (* 0.5 pi)(angle p1 p2)) (* ii fgjj)) A1) 0) ))  kongbiao)
  54.              (function (lambda (e1 e2)      (> (car e1)(car e2 ) )   (< (cadr e1)(cadr e2 ) )
  55.               ) ) )
  56. )  (print kbb)
  57.   (setq iiii 0)
  58. (FOREACH x kbb
  59.   (setq iiii (1+ iiii))
  60.   (setq wenzi (strcat (vl-prin1-to-string  ii) "-" (vl-prin1-to-string  iiii)))
  61.   (entmake (list '(0 . "TEXT") '(8 . "fgbaj")(cons 1 wenzi) (cons 10 x ) (cons 40 0.250)))
  62.   )
  63.
  64. (setq kb (append kbb kb))
  65. (setq ii (1+ ii))
  66.   )
  67.   (setq iii 0)
  68. (foreach n (reverse kb)
  69.    ;(entmake (list '(0 . "TEXT") '(8 . "fgbj")(cons 1 (rtos (+ iii 1) 2 0)) (cons 10 n ) (cons 40 0.250)))
  70.   ;(entmake (list '(0 . "circle") '(8 . "fgbj")(cons 62 3) (cons 10 n ) (cons 40 0.25)))
  71. (setq iii (1+ iii))
  72.   )
  73. (princ)
  74. )
 楼主| 发表于 2019-6-3 21:50:27 | 显示全部楼层
另外一种不同效果的
  4.   )
  5. ;;;;
  6. (defun cx-ss2en
  7.   (ss / enlst)
  8.   (cond
  11.     )
  15.     )
  17.       (ssadd ss)
  18.     )
  19.   )
  20. )
  23.
  25.
  28.
  30.
  31. )
  33. (defun c:szpx (/ ssa kongbiao i ii zb paixuzb p1 p2 fgjj p3 cishu kb kbb iii iiii wenzi x n )
  37.
  39.   )
  42.               ) ) )
  43.        )
  49. (setq kb '() ) (setq ii 0)
  50. (repeat cishu
  51.
  52. (setq kbb
  55.               ) ) )
  56. ) ; (print kbb)
  57.
  58.
  59. (setq kb (append (list kbb) kb))
  60. (setq ii (1+ ii))
  61.   )  (print (car kb))
  62.   (setq iii 0)
  63. (foreach n kb
  64. (setq iiii 0)
  65. (FOREACH x n
  66.   (setq iiii (1+ iiii))
  67.   (setq wenzi (strcat (vl-prin1-to-string  iii) "-" (vl-prin1-to-string  iiii)))
  68.   (entmake (list '(0 . "TEXT") '(8 . "fgbaj")(cons 1 wenzi) (cons 10 x ) (cons 40 0.250)))
  69.   )
  70.
  71.    ;(entmake (list '(0 . "TEXT") '(8 . "fgbj")(cons 1 (rtos (+ iii 1) 2 0)) (cons 10 n ) (cons 40 0.250)))
  72.   ;(entmake (list '(0 . "circle") '(8 . "fgbj")(cons 62 3) (cons 10 n ) (cons 40 0.25)))
  73. (setq iii (1+ iii))
  74.   )
  75. (princ)
  76. )
发表于 2019-6-4 05:35:37 来自手机 | 显示全部楼层
文字长度能否跟圆的半径扯上点关系,对正方式也改下
发表于 2019-6-4 05:38:28 来自手机 | 显示全部楼层
实际上不用画出那条线来第一排的两端的圆即可判断了
GMT+8, 2025-11-20 04:12 , Processed in 0.152740 second(s), 27 queries , Gzip On.
