查看: 644|回复: 0
[提问] 请问一下,把偏移对象改为当前图层呀
发表于 2019-6-4 10:18:30 | 显示全部楼层 |阅读模式
;;批量偏移 By Gu_xl 2013.04.01
(defun c:py (/ CLOCKWISEP OFFSET KD SS N EN kd0)
  (defun CLOCKWISEP (en / lw minp MaxP lst)
    (setq lw (vlax-ename->vla-object en))
    (vla-GetBoundingBox lw 'MinP 'MaxP)
    (setq
      minp (vlax-safearray->list minp)
      MaxP (vlax-safearray->list MaxP)
      lst  (mapcar
             (function
               (lambda (x)
                 (vlax-curve-getParamAtPoint
                   lw
                   (vlax-curve-getClosestPointTo lw x)
             (list minp
                   (list (car minp) (cadr MaxP))
                   MaxP
                   (list (car MaxP) (cadr minp))
    (if (or
          (<= (car lst) (cadr lst) (caddr lst) (cadddr lst))
          (<= (cadr lst) (caddr lst) (cadddr lst) (car lst))
          (<= (caddr lst) (cadddr lst) (car lst) (cadr lst))
          (<= (cadddr lst) (car lst) (cadr lst) (caddr lst))
      t
  (initget 7 "W N S  ")
  (setq kd0 (getkword "\n[向外偏移W/向内偏移N/双向偏移S]<W>"))
  (if (= "" kd0)
    (setq kd0 "W")
  (initget 6)
  (setq offset (getreal "\n[输入偏移距离]<0.5>"))
  (if (null offset)
    (setq offset 0.5)
  (initget 7 "Y N  ")
  (setq kd (getkword "\n[删除源对象<Y>/不删除源对象<N>]<N>:"))
  (if (= kd "")
    (setq kd "N")
  (while (setq ss (ssget '((0 . "*polyline,arc,circle"))))
    (repeat (setq n (sslength ss))
      (setq en (ssname ss (setq n (1- n))))
      (cond
        ((or (= "ARC" (cdr (assoc 0 (entget en))))
             (= "CIRCLE" (cdr (assoc 0 (entget en))))
         (cond ((= kd0 "W")
                (vla-offset (vlax-ename->vla-object en) offset)
                (vla-put-Color (vlax-ename->vla-object (entlast)) 1)
               ((= kd0 "N")
                (vla-offset (vlax-ename->vla-object en) (- offset))
               (t
        (t
         (cond ((= kd0 "W")
                (if (CLOCKWISEP en)
                  (vla-put-Color (vlax-ename->vla-object (entlast)) 4)
               ((= kd0 "N")
                (if (CLOCKWISEP en)
               (t
      (if (= kd "Y")
        (entdel en)
GMT+8, 2025-10-24 04:13 , Processed in 0.165964 second(s), 26 queries , Gzip On.
