查看: 939|回复: 1
[源码] 怎么用lisp查询修改图层颜色?(已解决)
发表于 2019-6-12 17:07:25 | 显示全部楼层 |阅读模式
现在论坛里的图层改色只能修改但是不能显示原图层颜色,请问能不能修改的时候先显示原图层颜色然后再修改?请大神帮忙修改。;;AAS便捷式查看修改图层颜色
(defun c:AAS (/ e col lyr)
  (while (and (setq e (car (entsel "\nPick Entity: ")))
                                         (setq col (acad_truecolordlg '(62 . 255)))
    (setq lyr (cdr (assoc 8 (entget e))))
    (vla-put-color
      (vla-item        (vla-get-layers
        (vla-get-activedocument (vlax-get-acad-object))
                                lyr
      (cdr (assoc 62 col))
 楼主| 发表于 2019-6-14 23:24:38 | 显示全部楼层
;;AAS便捷式查看修改图层颜色
  (setq objA (entsel"\n选图形: "))
  (setq en2 (entget (car objA)))
  (setq en3 (assoc 8 en2))
  (setq en4 (cdr en3))
  (setq en5 (cdr (assoc 62 (entget (tblobjname "layer" en4)))))
  (prompt (strcat " 颜色为" (rtos en5 2 0)))
    (vla-put-color
                                lyr
GMT+8, 2025-10-24 04:08 , Processed in 0.138067 second(s), 26 queries , Gzip On.
