查看: 663|回复: 1
[提问] 【已解决】只需要用命令默认让属性文字反转180,该怎么改一下呀
发表于 2019-6-14 19:24:31 | 显示全部楼层 |阅读模式
  1. (defun c:BAChg (/ key an hi cset)
  2.   (initget 128 "R A")
  3.   (setq key (getdist "\n字高[A - 旋转角/R - 反向修复]: "))
  4.   (cond
  5.     ((= (type key) 'STR)
  6.       (if (= (strcase key) "R")
  7.         (setq key "Recover")
  8.         (setq an (getangle "\n旋转角: "))
  9.       ) ;_ 结束if
  10.     )
  11.     ((= (type key) 'REAL)
  12.       (setq hi key)
  13.     )
  14.     (t)
  15.   )
  16.   (if (not (vl-catch-all-error-p
  17.              (setq cset
  18.                (vl-catch-all-apply
  19.                  'vla-item
  20.                  (list
  21.                    (vlax-get-property
  22.                      (vlax-get-property
  23.                        (vlax-get-acad-object)
  24.                        'activedocument
  25.                      )
  26.                      'selectionsets
  27.                    )
  28.                    "CURRENT"
  29.                  )
  30.                )
  31.              )
  32.            )
  33.       )
  34.     (vla-delete cset)
  35.   )
  36.   (if (or an hi key)
  37.     (if    (ssget '((0 . "insert")))
  38.       (vlax-map-collection
  39.         (vlax-get-property
  40.           (vlax-get-property (vlax-get-acad-object) 'activedocument)
  41.           'activeselectionset
  42.         )
  43.         '(lambda (x / attlst)
  44.            (if (= (vla-get-hasattributes x) :vlax-true)
  45.              (progn
  46.                (setq
  47.                  attlst    (safearray-value
  48.                              (vlax-variant-value (vla-getattributes x))
  49.                            )
  50.                )
  51.                (mapcar '(lambda    (a)
  52.                           (if hi
  53.                             (vla-put-height a hi)
  54.                           )
  55.                           (if an
  56.                             (vla-put-rotation a an)
  57.                           )
  58.                           (if (= key "Recover")
  59.                             (vla-put-Backward a :vlax-false)
  60.                           )
  61.                         )
  62.                  attlst
  63.                )
  64.              )
  65.            )
  66.          )
  67.       )
  68.     )
  69.   )
  70.   (princ)
  71. )
发表于 2019-6-16 00:30:02 | 显示全部楼层
torient 这个命令可以帮到你,需安装cad工具
GMT+8, 2025-10-24 04:05 , Processed in 0.136082 second(s), 26 queries , Gzip On.
