查看: 1253|回复: 4
[提问] 求画矩形对角线
发表于 2019-6-18 14:26:41 | 显示全部楼层 |阅读模式
怎么求P5  P6 P7 P8 这四个点,然后四个点对角相连,有无大神帮帮忙
(defun c:tt (/ p1 p2 p3 p4)
(setvar "cmdecho" 0)
(setq p1 (getpoint "\r第一点:"))
(setq p2 (getcorner p1 "\r下一点:"))
       (setq p3 (list (car p1) (cadr p2))
             p4 (list (car p2) (cadr p1))
      (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity")
                      '(100 . "AcDbPolyline")  (cons 90 4)
                      (cons 10 p1) (cons 10 p3) (cons 10 p2) (cons 10 p4)
                      (cons 70 1)  )  )
(vla-offset (vlax-ename->vla-object (entlast)) 10)
发表于 2019-6-18 22:03:19 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (and (setq p1 (getpoint "\n第一点: "))
  3.            (setq p2 (getcorner p1 "\n下一点: "))
  4.       )
  5.     (progn
  6.       (setvar "osmode" 0)
  7.       (command "rectang" p1 p2)
  8.       (vla-offset (vlax-ename->vla-object (entlast)) -10)
  9.       (setq ptn        (vl-remove-if-not
  10.                   '(lambda (x) (= (car x) 10))
  11.                   (entget (entlast))
  12.                 )
  13.             ptn        (mapcar 'cdr ptn)
  14.       )
  15.       (command "line" (nth 0 ptn) (nth 2 ptn) "")
  16.       (command "line" (nth 1 ptn) (nth 3 ptn) "")
  17.     )
  18.   )
  19.   (princ)
  20. )
发表于 2019-6-18 22:23:43 | 显示全部楼层
例:p5=(polar p1 (* 0.25 pi) (sqrt (+ (expt 10 2) (expt 10 2)))) ,其他自己算
 楼主| 发表于 2019-6-19 08:20:48 | 显示全部楼层
 楼主| 发表于 2019-6-19 08:21:02 | 显示全部楼层
谢谢
GMT+8, 2025-10-24 04:12 , Processed in 0.232194 second(s), 26 queries , Gzip On.
