查看: 1289|回复: 0
[源码] lwpolyline使用vla-put-coordinate
发表于 2019-6-27 09:42:28 | 显示全部楼层 |阅读模式
Lwpolyline使用vla-put-coordinate修改端点时,传入的点应只包括2维数据。即:(vla-put-coordinate enobj para ptob)语句中,ptob不能使用vlax-3d-point生成。而应先(setq ptob (vlax-make-safearray vlax-vbDouble '(0 . 1))),并用vlax-safearray-fill完成赋值。代码片段如下:
  1.   (( = typ "LWPOLYLINE")
  2.   (setq en1 (car en) pt (cadr en) enobj (vlax-ename->vla-object en1) )
  3.   (setq pt1 (get_pline_closest1 en1 pt)
  4.    para (fix (vlax-curve-getParamAtPoint en1 pt1)))
  5.   (setq pt2 (utow (getpoint (wtou pt1) "\n输入新端点:")))
  6.   ;(setq ptob (vlax-variant-value ( vla-get-coordinate enobj para)))
  7.   (setq ptob (vlax-make-safearray vlax-vbDouble '(0 . 1)))
  8.   ;用vlax-make-safearray创建一个数组,包括两个元素
  9.
  10.     ;(vla-put-coordinate enobj para (vlax-3D-point  (list (car pt2) (cadr pt2))))
  11.   ;不能使用vlax-3d-point 返回值有3个元素。
  12.
  13.   (vlax-safearray-fill ptob (list (car pt2) (cadr pt2)))
  14.   (vla-put-coordinate enobj para ptob)
  15.     ;(vlax-safearray->list (vlax-variant-value pt))
  16.   (vla-Update enobj )
  17.   );cond lwpolyline
GMT+8, 2025-11-26 10:45 , Processed in 0.177140 second(s), 30 queries , Gzip On.
