查看: 1205|回复: 9
三点画圆函数
发表于 2019-7-4 23:03:04 | 显示全部楼层 |阅读模式
路过的老师,下边的XY、XYSM、XYSE是设的什么为未知数?是什么方程,我好像没学过。
'三点创建圆
Public Function AddCircle3P(ByVal pt1 As Variant, ByVal pt2 As Variant, ByVal pt3 As Variant) As AcadCircle
    Dim xysm, xyse, xy As Double
    Dim ptCen(0 To 2) As Double
    Dim radius As Double
    Dim objCir As AcadCircle
    xy = pt1(0) ^ 2 + pt1(1) ^ 2
    xyse = xy - pt3(0) ^ 2 - pt3(1) ^ 2
    xysm = xy - pt2(0) ^ 2 - pt2(1) ^ 2
    xy = (pt1(0) - pt2(0)) * (pt1(1) - pt3(1)) - (pt1(0) - pt3(0)) * (pt1(1) - pt2(1))
    '判断参数有效性
    If Abs(xy) < 0.000001 Then
        MsgBox "所输入的参数无法创建圆形"
        Exit Function
    End If
    '获得圆心和半径
    ptCen(0) = (xysm * (pt1(1) - pt3(1)) - xyse * (pt1(1) - pt2(1))) / (2 * xy)
    ptCen(1) = (xyse * (pt1(0) - pt2(0)) - xysm * (pt1(0) - pt3(0))) / (2 * xy)
    ptCen(2) = 0
    radius = Sqr((pt1(0) - ptCen(0)) ^ 2 + (pt1(1) - ptCen(1)) ^ 2)
    '判断参数有效性
        Exit Function
    End If
    Set objCir = ThisDrawing.ModelSpace.AddCircle(ptCen, radius)
    '由于返回值是对象,必须加上set
    Set AddCircle3P = objCir
End Function
Acad 提供了很多几何函数,不需要自己去求解的。Win10这输入时光标乱跑乱动的问题实在是...  发表于 2019-7-5 21:45
Acad 提供了很多几何函数,自己去求解的。  发表于 2019-7-5 21:43
运算过程懒得看。就程序来说,直接用AddCircle3P就可以了,没必要再用obCir中转一下,可以省一个变量。  发表于 2019-7-5 10:01
发表于 2019-7-5 14:36:03 | 显示全部楼层
xyse=xy-pt3(0)^2-pt3(1)^2,即 (pt1(0) ^ 2 + pt1(1) ^ 2) - (pt3(0) ^ 2 + pt3(1) ^ 2),为啥很接近0?
已经推导出:
X=(gb-cf)/(eb-af)
Y=(ag-ce)/(af-be)
以Y为例:
=(ag-ce) / (af-be)
=((2x3-2x1)*(x22-x12+y22-y12) - (2x2-2x1)*(x32-x12+y32-y12)) / ((2x3-2x1)*(2y2-2y1) - (2y3-2y1)*(2x2-2x1))
=(((x22+ y22) - ( x12+ y12))*(2x3-2x1)) - ((x32+ y32) - ( x12+ y12))*(2x2-2x1) / 2*((x3-x1)*(y2-y1) - (y3-y1)*(x2-x1))
=(-xysm * (2x3-2x1)) - (-xyse * (2x2-2x1)) / 2*((x3-x1)*(y2-y1) - (y3-y1)*(x2-x1))
=2*(xyse * (x2-x1) - xysm * (x3-x1)) / 2*((x3-x1)*(y2-y1) - (y3-y1)*(x2-x1))
=(xyse * (pt2(0)-pt1(0)) - xysm * (pt3(0)-pt1(0))) / ((pt3(0) - pt1(0))*(pt2(1) - pt1(1)) - ((pt3(1) - pt1(1))*(pt2(0) - pt1(0))))
分子分母同时乘以-1
=(xyse * (pt1(0)-pt2(0)) - xysm * (pt1(0)-pt3(0))) / (((pt3(1) - pt1(1))*(pt2(0) - pt1(0))) - (pt3(0) - pt1(0))*(pt2(1) - pt1(1)))
=(xyse * (pt1(0)-pt2(0)) - xysm * (pt1(0)-pt3(0))) / ((pt1(1) - pt3(1)) * (pt1(0) - pt2(0))) - ((pt1(1) - pt2(1))*(pt1(0) - pt3(0)))
=(xyse * (pt1(0)-pt2(0)) - xysm * (pt1(0)-pt3(0))) / xy
再除以2,不就是ptCen(1)吗?
X同理。
发表于 2019-7-5 08:44:56 | 显示全部楼层
pt1(0) ^ 2 + pt1(1) ^ 2表示pt1到原点的距离的平方(记为var1)
pt2(0) ^ 2 + pt2(1) ^ 2表示pt2到原点的距离的平方(记为var2)
pt3(0) ^ 2 + pt3(1) ^ 2表示pt3到原点的距离的平方(记为var3)
xyse是var1减去var3,xysm是var1减去var2,var参数求圆心和半径时候会用到
下面的公式成立时表示pt1、pt2、pt3三点共线,三点共线不能构成圆。
把公式变形成(pt1(0) - pt2(0)) * (pt1(1) - pt3(1)) -(pt1(0) - pt3(0)) * (pt1(1) - pt2(1))的形式,当差值小于0.000001,就近似的认为三点共线,不能构成圆。
 楼主| 发表于 2019-7-5 11:47:32 | 显示全部楼层
牛皮,明白了,谢谢老师
 楼主| 发表于 2019-7-5 11:53:29 | 显示全部楼层
pt2(0) ^ 2 + pt2(1) ^ 2表示pt2到原点的 ...
老师那ptCen的计算方法能给讲讲吗
xyse=xy-pt3(0)^2-pt3(1)^2 很接近等于0了呀
 楼主| 发表于 2019-7-5 11:58:40 | 显示全部楼层
@mikewolf2k 好的
 楼主| 发表于 2019-7-5 23:24:23 | 显示全部楼层
太难了
GMT+8, 2025-5-23 04:22 , Processed in 0.161160 second(s), 26 queries , Gzip On.
