查看: 1362|回复: 5
[源码] 在论坛前辈基础上修改了一下实现框选输出面积和周长至Excel
发表于 2019-7-7 07:54:57 | 显示全部楼层 |阅读模式
源码来自于论坛,感谢原作者!
原源码统计单位是mm和mm2,略加修饰调整为输出单位是m和m2,。
源码如下:
(defun c:mjsc (/ d ent f i lst m2 obj pt ss txt x y)
        (setq TextHeight (getdist "\n输入标注文字高度:")
                Textbh (getstring "\n输入编号前缀:"))
  (defun maketext (txt pt)             ; 生成文字子函数
    (entmake (list '(0 . "TEXT") (cons 62 1) (cons 10 pt) (cons 40 TextHeight) (cons 1 txt) '(41 . 0.8)))
  (setvar "cmdecho" 0)
  (vl-load-com)
  (setq ss (ssget) ent (entlast))
  (command ".region" ss "")
  (setq ss (ssadd)  lst nil)
  (while (setq ent (entnext ent))
    (if (= (cdr (assoc 0 (entget ent))) "REGION")
      (setq obj (vlax-ename->vla-object ent) pt (vlax-safearray->list (vlax-variant-value (vla-get-centroid obj)))
                                m2 (rtos (/ (vla-get-area obj) 1000000.0) 2 3)  d (rtos (/ (vla-get-perimeter obj) 1000.0) 2 3)  lst (cons (list pt m2 d) lst)
  (command ".undo" "")
  (setq lst (vl-sort lst (function (lambda (x y)(< (car (car x)) (car (car y)))))))
  (setq lst (vl-sort lst (function (lambda (x y)(> (cadr (car x)) (cadr (car y)))))))
  (setq f (getfiled "指定输出文件路径" "" "xls" 1) f (open f "a"))
  (write-line "编号\t周长(m)\t面积(m2)" f)
  (setq i 1)
  (foreach x lst
    (setq pt (car x) m2 (cadr x) d (caddr x))
    (maketext (strcat Textbh (itoa i)) (list (car pt) (+ (cadr pt) (* 1.2 TextHeight))))
    (maketext (strcat "L=" d "m") pt)
    (maketext (strcat "S=" m2 "m2") (list (car pt) (- (cadr pt) (* 1.2 TextHeight))))
    (write-line (strcat (strcat Textbh (itoa i)) "\t" d "\t" m2) f)
    (setq i (1+ i))
  (close f)
发表于 2019-7-7 17:13:18 | 显示全部楼层
谢谢分享程序!!!!!
发表于 2019-7-7 17:44:43 | 显示全部楼层
你这是生成Tab分隔的csv文件,不是excel的xls或xlsx啊。
其实csv就可以了,表格软件应该都支持的,也没有必要非要去生成xlsx。
另外如果只是要提取对象的这些参数,你可以直接用 data extration来获取数据并生成xls文件与AutoCAD Table。
 楼主| 发表于 2019-8-17 09:05:55 | 显示全部楼层
其实csv就可以了,表格软件应该都支持的,也没 ...
感谢版本点评与指导,受益匪浅
GMT+8, 2025-5-18 18:56 , Processed in 0.185524 second(s), 25 queries , Gzip On.
