查看: 3561|回复: 19
[提问] 文字加框问题(用于结构设计)
发表于 2019-7-9 01:21:05 | 显示全部楼层 |阅读模式
最近在论坛上看到一个程序,可以给文字加框。主要是对特定的计算数据加一个标识。不过对于水平的文字,可以完美的加上框,对于竖向的文字,这个框也是画成了水平的,请高手给修改一下程序。也对原来该程序的作者表示敬意。
本程序首先按图层找到文字,然后检查该文字是否含有“G”标志,然后对"G"后两个数字与设定数值进行比较,只要两个数字中有一个大于设定值,就给该文字加框。
现将该程序与图纸上传,请论坛各位同仁修改一下。
(defun c:cgj (/ bb cc en en_data fjm hh i jm k os p1 p11 p2 p22 pc ss str txt DD)
        (setvar "CMDECHO" 0)
        (setq os (getvar "OSMODE"))
        (setvar "OSMODE" 0)
        (setq str (getstring "\n缺省配箍值<G1.0-0.5(#8@100200)>:"))
        (if (= str "") (setq str "G1.0-0.5"))
        (setq jm (atof (substr str 2 3)) fjm (atof (substr str 6 3)))
        (setq ss (ssget '((0 . "text") (8 . "Pkpm_层15220"))))
        (setq i 0 k 0)
        (command "LAYER" "m" "CGJ" "C" 1 "CGJ" "")
        (repeat (sslength ss)
        (setq en (ssname ss i))
        (setq en_data (entget en))
        (setq txt (cdr (assoc 1 en_data)))
        (setq bb (substr txt 2 3) cc (substr txt 6 3) DD (substr txt 1 1))
        (if (AND (= DD "G") (or (> (atof bb) jm) (> (atof cc ) fjm)))
                        (setq p1 (cdr (assoc 10 en_data)) ang (cdr (assoc 50 en_data)) hh (cdr (assoc 40 en_data)))
                        (setq pc (cadr (textbox en_data)))
                        (setq p2 (mapcar '+ p1 pc))
                        (setq hh (* 0.1 hh))
                        (setq p11 (mapcar '- p1 (list hh hh)) p22 (mapcar '+ p2 (list hh hh)))
                        (command "rectangle" p11 p22)
                        (if (= ang (/ pi 2)) (command "rotate" (entlast)  p1 (/ pi 2)))
                        (setq k (+ 1 k))
        (setq i (+ 1 i))
        (princ (strcat "\n共找到超过缺省配箍值<" str "> " (itoa k)" 项。 "))
        (setvar "OSMODE" os)
希望图4的文字框变成如图5的样子。wpj3文件是测试图。
发表于 2022-12-7 07:14:44 | 显示全部楼层
;;;  文字边框
(defun get-mtextbox
       (en txtsize BoxType / txtEntData PtTL xWidth xHeight xAngle Pt_TC PtTR PtTR Pt_BL Pt_BC Pt_BR Pt_MC)
  (setq txtEntData (entget en))
  (setq        PtTL        (cdr (assoc 10 txtEntData))
        xWidth        (cdr (assoc 42 txtEntData))
        xHeight        (cdr (assoc 43 txtEntData))
        xAngle        (cdr (assoc 50 txtEntData))
        Pt_TC        (polar PtTL xAngle (* xWidth 0.5))
        PtTR        (polar PtTL xAngle xWidth)
        Pt_BL        (polar PtTL (- xAngle (/ PI 2.0)) xHeight)
        Pt_BC        (polar Pt_BL xAngle (* xWidth 0.5))
        Pt_BR        (polar Pt_BL xAngle xWidth)
        Pt_MC        (polar Pt_BL
                       (angle Pt_BL PtTR)
                       (/ (distance Pt_BL PtTR) 2.0)
  )                                        ;endsetq
  ;(setq xAngle (cdr (assoc 50 txtEntData)))
  (setq Pt_BL (polar Pt_BL xAngle (- txtsize)))
  (setq Pt_BL (polar Pt_BL (+ xAngle (/ PI 2.0)) (- txtsize)))
  (setq Pt_BR (polar Pt_BR xAngle txtsize))
  (setq Pt_BR (polar Pt_BR (+ xAngle (/ PI 2.0)) (- txtsize)))
  (setq PtTL (polar PtTL xAngle (- txtsize)))
  (setq PtTL (polar PtTL (+ xAngle (/ PI 2.0)) txtsize))
  (setq PtTR (polar PtTR xAngle txtsize))
  (setq PtTR (polar PtTR (+ xAngle (/ PI 2.0)) txtsize))
  (cond
    ;((= BoxType "C")(vl-cmdf "_Circle" Pt_MC (+ (/ (max (cadadr pt)(caadr pt)) 2.0) txtsize)))
    ((= BoxType "C")(vl-cmdf "_Circle" Pt_MC (/ (distance Pt_BL PtTR) 2.0)))
    ((= BoxType "R")(vl-cmdf "_PLine" Pt_BL Pt_BR PtTR PtTL "C"))
    ((= BoxType "S")(vl-cmdf "_PLine" Pt_BL Pt_BR "a" PtTR "l" PtTL "a""Cl"))
    );COND
;text
(defun get-textbox (en offset / pt1 pt2 pt3 pt4 a b c d PT pts end pt_mc)
  ;(setq en (car (entsel)))
  ;(setq offset 1)
  (setq end (entget en))
  (setq pts (cdr (assoc 10 end)))
  (setq a (cdr (assoc 50 end)))
  (setq b (* (/ PI 180) 225))
  (SETQ C (+ A B))
  (setq d (sqrt (+ (* offset offset) (* offset offset))))
  (setq pt (textbox end))
  (setq pt1 (polar pts c d))
  (setq b (* (/ PI 180) 45))
  (SETQ C (+ A B))
  (setq pt2 (polar pt1 a (+ (caadr pt) offset offset)))
  (setq pt3 (polar pt2 (+ a (* pi 0.5)) (+ (cadadr pt) offset offset)))
  (setq pt4 (polar pt1 (+ a (* pi 0.5)) (+ (cadadr pt) offset offset)))
  (setq pt_mc (polar pt1 (angle Pt1 Pt3) (/ (distance Pt1 Pt3) 2.0)))
  (cond
    ((= BoxType "C")(vl-cmdf "_Circle" Pt_MC (/ (distance Pt1 Pt3) 2.0)))
    ((= BoxType "R")(command "pline" pt1 pt2 pt3 pt4 "c"))
    ((= BoxType "S")(command "pline" pt1 pt2"A" pt3"L" pt4 "A""cL"))
    );COND
(princ "\n 使用命令: wzbk")
(defun c:wzbk (/ cmd0 osmode0 ss s seconds s n nn en endata txtEntType txtsize)
     (PRINC "\n【阳羡刚刚好CAD外挂<文字边框功能>】---给所选文字加上圆框/椭圆框/矩形框")(PRINC)
  (setq cmd0 (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq osmode0 (getvar "OSMODE"));捕捉
  (setvar "OSMODE" 0);捕捉
  (vl-cmdf "_.undo" "_be")
  (if (not #AY_TBOXBOXTYPE)(setq #AY_TBOXBOXTYPE "S"))
  (initget "C S R")
  (setq BoxType (getkword (strcat "\n边框类型 [圆形(C)/圆矩形(S)/矩形(R)]<" #AY_TBOXBOXTYPE ">: ")))
  (if (= BoxType nil) (setq BoxType #AY_TBOXBOXTYPE) (setq #AY_TBOXBOXTYPE BoxType))
  (if (setq ss (ssget '((0 . "*TEXT"))))
      (setq s (getvar "DATE"))
      (setq seconds (* 86400.0 (- s (fix s))))
      (setq n 0);setq
      (setq nn (sslength ss))
      (repeat nn
        (setq en (ssname ss n));setq
        (setq endata (entget en))
        (setq txtEntType (cdr (assoc 0 endata)))
        (setq txtsize (cdr (assoc 40 endata)))
        (setq txtsize (* (/ txtsize 2.5) 0.6))
        (if (= txtEntType "TEXT")(get-textbox en txtsize));IF
        (if (= txtEntType "MTEXT")(get-mtextbox en txtsize BoxType));IF
        (setq n (1+ n))
        (SETVAR "MODEMACRO" (strcat "** 已完成 "(rtos (* 100 (/ (+ 0.01 n) nn)) 2 0) "% **"))
        );repeat
      (setq seconds2 (* 86400.0 (- s (fix s))))
      (princ (strcat "\n 文字加框完成  共耗时" (rtos (- seconds2 seconds) 2 3)"秒"))
      );progn
    (princ "\n没有选定有效的对象.")
    );if
  (vl-cmdf "_.undo" "_e")
  (SETVAR "MODEMACRO" "")
  (setvar "cmdecho" cmd0)
  (setvar "OSMODE" osmode0)
借花献佛
发表于 2019-7-9 08:58:33 | 显示全部楼层
;;简单改了下
;;涉及到旋转角度,可能会受某些系统变量值的影响,比如ANGBASE或者ANGDIR,不严谨
;;可以考虑下用多行文字,多行文字本身有加框的选项
;;还有一些细节的地方你自己再看看
  1. (defun c:cgj (/        ANG BB CC DD EN EN_DATA FJM HH I JM K P1 P11 P2 P22 PC SS STR TXT)
  2.   (setvar "CMDECHO" 0)
  3.   (setq str (getstring "\n缺省配箍值<G1.0-0.5(#8@100200)>:"))
  4.   (if (= str "")
  5.     (setq str "G1.0-0.5")
  6.   )
  7.   (setq        jm  (atof (substr str 2 3))
  8.         fjm (atof (substr str 6 3))
  9.   )
  10.   (setq ss (ssget '((0 . "text") (8 . "Pkpm_层15220"))))
  11.   (setq        i 0
  12.         k 0
  13.   )
  14.   (vl-cmdf "LAYER" "m" "CGJ" "C" 1 "CGJ" "")
  15.   (repeat (sslength ss)
  16.     (setq en (ssname ss i))
  17.     (setq en_data (entget en))
  18.     (setq txt (cdr (assoc 1 en_data)))
  19.     (setq bb (substr txt 2 3)
  20.           cc (substr txt 6 3)
  21.           DD (substr txt 1 1)
  22.     )
  23.     (if        (AND (= DD "G") (or (> (atof bb) jm) (> (atof cc) fjm)))
  24.       (progn
  25.         (setq pc (textbox en_data)
  26.               p1 (cdr (assoc 10 en_data))
  27.               p2 (mapcar '+ p1 (cadr pc))
  28.               hh (cdr (assoc 40 en_data))
  29.               hh (* 0.1 hh)
  30.               ang (cdr (assoc 50 en_data))
  31.         )
  32.         (setq p11 (mapcar '- p1 (list hh hh))
  33.               p22 (mapcar '+ p2 (list hh hh))
  34.         )
  35.         (vl-cmdf "_.rectang" "_non" p11 p22)
  36.         (if (equal ang (/ pi 2) 1e-5) (vl-cmdf "_.rotate" (entlast) "" "_non" p1 -90))
  37.         (setq k (+ 1 k))
  38.       )
  39.     )
  40.     (setq i (+ 1 i))
  41.   )
  42.   (princ (strcat "\n共找到超过缺省配箍值<" str "> " (itoa k) " 项。 "))
  43. )
发表于 2019-7-10 10:11:00 | 显示全部楼层
涛涛_1048 发表于 2019-7-9 18:41
6楼的必强同学,在论坛里看到你写了好多程序,尤其是在工具箱方面,请必强同学也写一下吧。
(defun c:bb( / bbset bb b bb5 bb4 bb2  ss i en max maxa min mina  )(vl-load-com)
(setq bbset(getreal"\n必强提示输入设定值")  bb(ssget ":s" '((0 . "text")(1 . "G*-*"))) b -1 i -1 bb5 (ssadd))
(repeat (sslength bb)(setq b (1+ b) bb4 (ssname bb b) bb2 (cdr(assoc 1 (entget bb4))))
(if(or(< bbset (atof(substr bb2 2 3)))(< bbset (atof(substr bb2 7 2))))(setq ss (ssadd bb4 bb5))))
(repeat (sslength ss) (setq en (ssname ss (setq i(+ i 1))))(vla-getboundingbox (vlax-ename->vla-object en) 'a 'b)
(setq max (vlax-safearray->list a) min (vlax-safearray->list b))(setq maxa (list (car max)(cadr min)) mina (list (car min)(cadr max)))
(entmakex (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity")  '(100 . "AcDbPolyline") '(62 . 7) '(90 . 12) (cons 10 max) '(40 . 0) '(41 . 0)
(cons 10 max)(cons 62 2)(cons 8 "文字框")(cons 10 maxa)(cons 10 min)(cons 10 mina)(cons 10 max))))(princ))
发表于 2019-7-9 09:49:52 | 显示全部楼层
ssget 中可以设定过滤字符为 "G*-*"
用textbox函数获得text的边框数据,然后绘制外框即可。
可能还有任意角度的,按text的rotate angle旋转。
还有考虑UCS,对这些数据进行坐标系转换。
发表于 2019-7-9 10:13:15 | 显示全部楼层
希望能增加一个功能 文字加圆框
发表于 2019-7-9 13:19:08 | 显示全部楼层
依然小小鸟 发表于 2019-7-9 10:13
希望能增加一个功能 文字加圆框
用文字的最小包围盒坐标画框不是很简单么?横竖都行。
发表于 2019-7-9 15:46:37 | 显示全部楼层
希望能增加一个功能 文字加圆框
计算中心,半径,画圆
 楼主| 发表于 2019-7-9 18:39:08 | 显示全部楼层
2楼和5楼的同仁给写一下吧,直接用文字边框的数据的。
 楼主| 发表于 2019-7-9 18:39:55 | 显示全部楼层
非常感谢二楼的这位同仁,在百忙中回复了帖子。不过就是程序还是运行不正常。
 楼主| 发表于 2019-7-9 18:41:20 | 显示全部楼层
发表于 2019-7-10 08:28:07 | 显示全部楼层
没搞懂这样加框有什么好处
GMT+8, 2025-8-23 04:20 , Processed in 0.212914 second(s), 28 queries , Gzip On.
