查看: 2563|回复: 9
[提问] 两直线端点闭合成多段线
发表于 2019-7-13 23:34:48 来自手机 | 显示全部楼层 |阅读模式
有没有将两条直线端点连接成闭合的多段线插件
发表于 2019-7-14 09:42:48 | 显示全部楼层
 楼主| 发表于 2019-7-14 11:48:30 来自手机 | 显示全部楼层
不好意思,我没表达清楚,是将两条平行的直线的两瑞相连并闭合成四边形或矩形矩形
发表于 2019-7-14 12:07:59 | 显示全部楼层
发表于 2019-7-14 12:13:53 | 显示全部楼层
点表要怎么排序搞不定   下面这个面出来的矩形有可能要交叉
(defun c:tt (/ dxf lst name ss)
        (if (and
                                (setq ss (ssget '((0 . "line"))))
                                (= (sslength ss) 2)
                        (while (setq name (ssname ss 0))
                                (setq dxf (entget name))
                                (setq lst (append lst (list
        (cdr (assoc 10 dxf))
        (cdr (assoc 11 dxf))
                                (ssdel name ss)
                                (entdel name)
                        (entmake (append
        (list
        '(0 . "LWPOLYLINE")
        '(100 . "AcDbEntity")
        '(100 . "AcDbPolyline")
        (cons 90 (length lst))
        (cons 70 1)
        (mapcar '(lambda (pt) (cons 10 pt)) lst)
        (list (cons 210 (trans '(0.0 0.0 1.0) 1 0)))
发表于 2019-7-14 13:16:39 | 显示全部楼层
(defun c:tt (/ dxf lst lst2 name name-lst ss)
        (if (and
                                (= (sslength ss) 2)
                        (setq lst nil)
                        (setq lst2 nil)
                        (setq name-lst nil)
                                (ssdel name ss)
                                (entdel name)
                        (setq lst2 (list (nth 0 lst) (nth 2 lst) (nth 1 lst) (nth 3 lst)))
                        (setq lst3 (list (nth 1 lst) (nth 0 lst) (nth 2 lst) (nth 3 lst)))
                        (foreach x (list lst lst2 lst3)
                                (setq name-lst (append
        name-lst
        (list (progn
        (entmake (append
        (list
        '(0 . "LWPOLYLINE")
        (cons 90 (length x))
        (cons 70 1)
        (mapcar '(lambda (pt) (cons 10 pt)) x)
        (entlast)
                        (if (>
                                                (Vlax-Get (vlax-ename->vla-object (car name-lst)) 'Area);1
                                                (Vlax-Get (vlax-ename->vla-object (cadr name-lst)) 'Area);2
                                (if (>
                                                        (Vlax-Get (vlax-ename->vla-object (caddr name-lst)) 'Area);3
                                                (entdel (cadr name-lst))
                                                (entdel (caddr name-lst))
                                                (entdel (car name-lst))
                                (if (>
                                                        (Vlax-Get (vlax-ename->vla-object (cadr name-lst)) 'Area);3
发表于 2019-9-7 20:20:40 | 显示全部楼层
楼上的改的非常好!
发表于 2021-1-12 11:05:19 | 显示全部楼层
        (if (and
楼上的改的非常好!
发表于 2021-1-18 15:23:26 | 显示全部楼层
        (if (and
楼上的改的非常好!
发表于 2023-5-3 11:18:11 | 显示全部楼层
谢谢,很有用
GMT+8, 2025-7-18 08:01 , Processed in 0.194682 second(s), 26 queries , Gzip On.
