查看: 1177|回复: 3
[提问] 划线 剪断多段线
发表于 2019-7-23 23:13:16 | 显示全部楼层 |阅读模式
有哪位大神 能帮忙给修改一下  这个代码   就是现在这个代码只能把与划线相交的线段给断开  ,不能自动连接和闭合 ,能修改修剪断开后,得到的图形自动连接和闭合吗, 如下图
 楼主| 发表于 2019-7-23 23:13:53 | 显示全部楼层
;;;=======================[ BreakAtObject.lsp ]=======================
;;; Author: Charles Alan Butler & Will DeLoach
;;; Version:  1.5 Feb. 22, 2006
;;; Purpose: Break lines, plines, splines, ellipse, circles & arcs
;;;          with a crossing object or user line, not blocks
;;; Sub_Routines: ssget->vla-list
;;;               list->3pair
;;; Requirements:
;;; Returns:
;;  Ignores objects on locked layers
;;  This code is still under deveopment
(defun c:Bo1 (/ ss brk_obj ents ssobjs cmd obj_erase
                      onlockedlayer ssget->vla-list list->3pair)
  (vl-load-com)
  (defun onlockedlayer (ename / entlst)
    (setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
    (= 4 (logand 4 (cdr (assoc 70 entlst))))
  (defun ssget->vla-list (ss ent / i ename lst)
    (setq i -1)
    (while (setq ename (ssname ss (setq i (1+ i))))
      ;; check for locked layer, do not use if on locked layer
      (if (and (not (onlockedlayer ename))
               (not (equal ename ent))) ; exclude break object
         (setq lst (cons (vlax-ename->vla-object ename) lst))
    lst
  (defun list->3pair (old / new)
    (while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
                 old (cdddr old)))
    (reverse new)
  (setq cmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command ".undo" "begin")
  ;;  get break line or object
  (if (and
          (prompt "\nSelect objects to break: ")
          (setq ss (ssget' ((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
        (setq p1 (getpoint "\nDraw Breaking line or press ENTER to select: "))
        (setq p2 (getpoint p1 "\nPick end of line."))
    (progn ; got points for a line
      (vl-cmdf "._line" p1 p2 "")
      (setq ent       (entlast)
            obj_erase t ; remove it when done
    (if ss
      (while
          (setq ent (car (entsel "\nSelect break entity, No blocks.")))
          (cond
            ((null ent)  nil)
            ((member (cdr (assoc 0 (entget ent)))
                    ' ("LINE" "ARC" "SPLINE" "LWPOLYLINE" "POLYLINE" "CIRCLE" "ELLIPSE"))
             nil)
            (t (prompt "\n*** Wrong object type, Try again.")
             t)
  (if (and ss ent
           (setq ssobjs (ssget->vla-list ss ent)))
      (setq brk_obj (vlax-ename->vla-object ent))
      (mapcar
       ' (lambda (obj2Break / iplist brkobjlst lastent) ; loop through list of objects to be broken
           ; get list of intersect points
           (setq iplist (vl-catch-all-apply' vlax-safearray->list
                          (list (vlax-variant-value
                             (vla-intersectwith brk_obj obj2Break acextendnone))))
           (setq brkobjlst (cons obj2Break brkobjlst)) ; collect the original object to be broken
           (if (not (vl-catch-all-error-p iplist));  error if no intersection
             (mapcar  ; loop through  intersect points
              ' (lambda (pt / cen elst maxparam minparam p1 p2 p1param p2param)
                  ;;  get last entity created via break in case multiple breaks
                     (if (and lastent (not (equal lastent (vlax-vla-object->ename brk_obj)))) ; ignore the break object
                       (progn ; new object created via break, put in list
                         (setq brkobjlst (cons (vlax-ename->vla-object (entlast)) brkobjlst))
                         ;;  if pt not on object x, switch objects
                         (if (not (vlax-curve-getdistatpoint obj2Break pt))
                           (foreach obj brkobjlst ; find the one that pt is on
                             (if (vlax-curve-getdistatpoint obj pt)
                                (setq obj2Break obj) ; switch objects
                 ;;  Handle any objects that can not be use with the Break Command
                 ;;  using one point
                 (cond
                    ((and (= "AcDbSpline" (vla-get-objectname obj2Break)) ; only closed splines
                          (vlax-curve-isClosed obj2Break)
                      (setq p1param  (vlax-curve-getparamatpoint obj2Break pt)
                            p2param  (+ p1param 0.000001)
                            p2       (vlax-curve-getPointAtParam obj2Break p2param)
                     (command "._break" (vlax-vla-object->ename obj2Break) "non" (trans pt 0 1) "non" (trans p2 0 1))
                    ((= "AcDbCircle" (vla-get-objectname obj2Break)) ; break the circle
                     (setq en (entlast))
                    ((and (= "AcDbEllipse" (vla-get-objectname obj2Break)) ; only closed ellipse
                          (vlax-curve-isClosed obj2Break))
                      ;;  Break the ellipse, code borrowed from Joe Burke  6/6/2005
                            p2param  (+ p1param 0.000001) ;(vlax-curve-getparamatpoint obj p2)
                            minparam (min p1param p2param)
                            maxparam (max p1param p2param)
                      (vlax-put obj2Break' startparameter maxparam)
                      (vlax-put obj2Break' endparameter (+ minparam (* pi 2)))
                    ;;   Objects that can be broken
                    (t
                     ;;(command "point"  "non" (trans pt 0 1))
                     ;;(command "._break" (vlax-vla-object->ename obj2Break) "non" (trans pt 0 1) "@")
                     (command "._break" (vlax-vla-object->ename obj2Break) "non" (trans pt 0 1) "non" (trans pt 0 1))
                     ;;  could not get vl-cmdf "._break" to behave
                     (setq lastent (entlast))
               (list->3pair iplist)
        ssobjs
      ;; remove the break line, if current layer is not locked
      (if obj_erase
         (vl-catch-all-apply' vla-delete (list brk_obj))
  (setvar "CMDECHO" cmd)
  (not (command ".undo" "end"))
 楼主| 发表于 2019-7-25 11:28:59 | 显示全部楼层
;;; Author: Charles Alan B ...
怎么没有大师来帮忙呢
发表于 2021-5-23 23:15:52 | 显示全部楼层
路过,顶起来
GMT+8, 2025-10-2 06:06 , Processed in 0.184333 second(s), 27 queries , Gzip On.
