查看: 1659|回复: 12
[提问] 问题已解决,谢谢各位!
发表于 2019-7-27 16:37:25 | 显示全部楼层 |阅读模式
(defun start00 ()
  (setq olderr *error*
*error* clerr
  (setq osnap_old (getvar "osmode"))
  (setq scmde (getvar "CMDECHO"))
  (setq clay (getvar "CLAYER"))
  (setq sblip (getvar "BLIPMODE"))
  (setq sgrid (getvar "GRIDMODE"))
  (setq shl (getvar "HIGHLIGHT"))
  (setq sucsf (getvar "UCSFOLLOW"))
  (setvar "CMDECHO" 0)
  (command "_.UNDO" "_GROUP")
  (command "_.UCS" "")
(defun c:dfg (/        selec1 selec2  point1   point2   object1
       object2  pp1 pp2  dist1   dist2    inter
       INTERX   INTERY POINT1X  POINT1Y  ptrim    pextend
       P1       p2 p3  p4   p5
  (start00)
  (setvar "osmode" 0)
  (setq n 1)
  (while (< n 2)
    (print)
    (setq selec1 (entsel "选择基准线:"))
    (if (= selec1 nil)
      (princ "无效的选择,请重选!")
      (progn (setq n 3) (princ "1 found"))
  )     ;while
  (setq n 1)
  (while (< n 2)
    (print)
    (setq selec2 (entsel "选择垂直线:"))
    (if (or (equal (cadr selec1) (cadr selec2)) (= selec2 nil))
      (progn (princ "1 found") (setq n 3))
  )     ;while
  (setq n nil)
  (IF (= HIGH1 NIL)
    (SETQ HIGH1 5)
  (PRINT)
  (prinC HIGH1)
  (PRINC ">:")
  (setq high (getreal))
  (IF (= length1 NIL)
    (SETQ length1 1.0)
  (PRINT)
  (prinC length1)
  (PRINC ">:")
  (setq length2 (getreal))
  (IF (= length2 NIL)
    (SETQ length2 length1)
  (IF (= HIGH NIL)
    (SETQ HIGH HIGH1)
  (setq point1 (CAdr selec1))
  (setq point2 (CAdr selec2))
  (command "fillet" "r" 0 "fillet" POINT1 POINT2)
  (setq object1 (ENTGET (car selec1)))
  (setq object2 (ENTGET (car selec2)))
  (setq pp1 (cdr (assoc 10 object1)))
  (setq pp2 (cdr (assoc 11 object1)))
  (setq dist1 (DISTANCE pp1 point1))
  (setq dist2 (distance pp2 point1))
  (if (> dist1 dist2)
    (setq inter pp2)
    (setq inter pp1)
  (SETQ INTERX (CAR INTER))
  (SETQ INTERY (CADR INTER))
  (SETQ POINT1X (CAR POINT1))
  (SETQ POINT1Y (CADR POINT1))
  (if (and (equal (cadr pp1) (cadr pp2) 0.001)
    (> (cadr point2) (cadr point1))
      (IF (> POINT1X INTERX)
(PROGN
   (setq ptrim (list interx (+ intery (/ high 1))))
   (setq pextend (list (- interx length2) (+ intery (/ high 1))))
   (SETQ P1 (LIST (- INTERX length2) INTERY))
   (SETQ P2 (LIST (- INTERX length2) (+ INTERY high)))
   (SETQ P3 (LIST (+ INTERX 0.2) (+ INTERY high)))
   (SETQ P4 (LIST (+ INTERX 0.2) (+ INTERY (+ high 1))))
   (SETQ P5 (LIST INTERX (+ INTERY (+ high 1))))
   (COMMAND "LINE" P1 P2 "")
   (command "EXTEND" "l" "" point1 "")
   (command "line" p2 P3 P4 P5 "")
   (command "trim" "l" "" "f" p1 p3 "" "")
(PROGN
   (setq pextend (list (+ interx length2) (+ intery (/ high 1))))
   (SETQ P1 (LIST (+ INTERX length2) INTERY))
   (SETQ P2 (LIST (+ INTERX length2) (+ INTERY high)))
   (SETQ P3 (LIST (- INTERX 0.2) (+ INTERY high)))
   (SETQ P4 (LIST (- INTERX 0.2) (+ INTERY (+ high 1))))
    (< (cadr point2) (cadr point1))
(PROGN
   (setq ptrim (list interx (- intery (/ high 1))))
   (setq pextend (list (- interx length2) (- intery (/ high 1))))
   (SETQ P2 (LIST (- INTERX length2) (- INTERY high)))
   (SETQ P3 (LIST (+ INTERX 0.2) (- INTERY high)))
   (SETQ P4 (LIST (+ INTERX 0.2) (- INTERY (+ high 1))))
   (SETQ P5 (LIST INTERX (- INTERY (+ high 1))))
(PROGN
   (setq pextend (list (+ interx length2) (- intery (/ high 1))))
   (SETQ P2 (LIST (+ INTERX length2) (- INTERY high)))
   (SETQ P3 (LIST (- INTERX 0.2) (- INTERY high)))
   (SETQ P4 (LIST (- INTERX 0.2) (- INTERY (+ high 1))))
  (if (and (equal (car pp1) (car pp2) 0.001)
    (> (car point2) (car point1))
      (IF (> POINT1y INTERy)
(PROGN
   (setq ptrim (list (+ interx (/ high 1)) intery))
   (setq pextend (list (+ interx (/ high 1)) (- intery length2)))
   (SETQ P1 (LIST INTERX (- INTERY length2)))
   (SETQ P2 (LIST (+ INTERX high) (- INTERY length2)))
   (SETQ P3 (LIST (+ INTERX high) (+ INTERY 0.2)))
   (SETQ P4 (LIST (+ INTERX (+ high 1)) (+ INTERY 0.2)))
   (SETQ P5 (LIST (+ INTERX (+ high 1)) INTERY))
(PROGN
   (setq pextend (list (+ interx (/ high 1)) (+ intery length2)))
   (SETQ P1 (LIST INTERX (+ INTERY length2)))
   (SETQ P2 (LIST (+ INTERX high) (+ INTERY length2)))
   (SETQ P3 (LIST (+ INTERX high) (- INTERY 0.2)))
   (SETQ P4 (LIST (+ INTERX (+ high 1)) (- INTERY 0.2)))
    (< (car point2) (car point1))
(PROGN
   (setq ptrim (list (- interx (/ high 1)) intery))
   (setq pextend (list (- interx (/ high 1)) (- intery length2)))
   (SETQ P2 (LIST (- INTERX high) (- INTERY length2)))
   (SETQ P3 (LIST (- INTERX high) (+ INTERY 0.2)))
   (SETQ P4 (LIST (- INTERX (+ high 1)) (+ INTERY 0.2)))
   (SETQ P5 (LIST (- INTERX (+ high 1)) INTERY))
(PROGN
   (setq pextend (list (- interx (/ high 1)) (+ intery length2)))
   (SETQ P2 (LIST (- INTERX high) (+ INTERY length2)))
   (SETQ P3 (LIST (- INTERX high) (- INTERY 0.2)))
   (SETQ P4 (LIST (- INTERX (+ high 1)) (- INTERY 0.2)))
  (SETQ HIGH1 HIGH)
  (setq length1 length2)
  (setq length2 nil)
  (command "_.UCS" "_P")
  (command "_.UNDO" "_E")
  (setvar "CMDECHO" scmde)
  (setvar "osmode" osnap_old)
  (PRINC)
发表于 2021-8-3 11:06:23 | 显示全部楼层
最後一行出錯了  (setvar "osmode" osnap)
               改為   (setvar "osmode" osnap_old )
发表于 2021-8-3 15:19:47 | 显示全部楼层
知道为什么没什么人回复吗?你这样标题不符合版规,没删已经不错了
看置顶帖,本版关于提问的一些注意事项:http://bbs.mjtd.com/thread-93736-1-1.html
 楼主| 发表于 2019-8-20 00:25:27 | 显示全部楼层
xinxirong 发表于 2019-8-16 07:20
写程序不留bug都不好意思说自己是程序员
高手,能帮忙修改一下吗?急用,谢谢!
 楼主| 发表于 2019-7-31 21:25:44 | 显示全部楼层
怎么没人理?
 楼主| 发表于 2019-7-31 21:26:04 | 显示全部楼层
怎么没人理?
 楼主| 发表于 2019-8-16 07:12:49 | 显示全部楼层
有没有高手帮忙看一下呀?
发表于 2019-8-16 07:20:49 来自手机 | 显示全部楼层
发表于 2019-8-26 00:59:48 | 显示全部楼层
I can't see any reason to make difference between 32&64 bit code
发表于 2021-8-3 00:35:28 | 显示全部楼层
command 尽量不要用   版本不一样 command  命令流 不太一样
GMT+8, 2026-1-17 05:18 , Processed in 0.176751 second(s), 26 queries , Gzip On.
