查看: 1767|回复: 6
[提问] 怎样用lisp来控制绘图背景黑色与白色的切换
发表于 2019-8-16 16:44:38 | 显示全部楼层 |阅读模式
1明经币
发表于 2019-8-16 17:17:51 | 显示全部楼层
 楼主| 发表于 2019-8-16 17:44:59 | 显示全部楼层
如果是黑色就该改成白色,如果是黑色就该改成白色,进行切换,用一个命令控制。程序怎么改
(defun c:tt (/ VAR-COLOUR DISPLAY clno blue rde green)
  (setq clno (getint "\n=>输入颜色序号!"))
  (prompt "\n,1=红,2=黄,3=绿,4=青,5=蓝,6=紫,7=白,8=灰,9=灰白"
  (cond        ((= clno 1)
         (progn (setq rde 255) (setq green 0) (setq blue 0))
        ((= clno 2)
         (progn (setq rde 255) (setq green 255) (setq blue 0))
        ((= clno 3)
         (progn (setq rde 0) (setq green 255) (setq blue 0))
        ((= clno 4)
         (progn (setq rde 0) (setq green 255) (setq blue 255))
        ((= clno 5)
         (progn (setq rde 0) (setq green 0) (setq blue 255))
        ((= clno 6)
         (progn (setq rde 255) (setq green 0) (setq blue 255))
        ((= clno 7)
         (progn (setq rde 255) (setq green 255) (setq blue 255))
        ((= clno 8)
         (progn (setq rde 128) (setq green 128) (setq blue 128))
        ((= clno 9)
         (progn (setq rde 192) (setq green 192) (setq blue 192))
        (t (progn (setq rde 0) (setq green 0) (setq blue 0)))
  (setq
    VAR-COLOUR (vlax-make-variant
                 (+ rde (* green 256)(* blue 65536))
                 vlax-vblong
    DISPLAY    (vla-get-display
                 (vla-get-preferences
                   (vla-get-application (vlax-get-acad-object))
  (vla-put-graphicswinlayoutbackgrndcolor DISPLAY VAR-COLOUR)
  (vla-put-graphicswinmodelbackgrndcolor DISPLAY VAR-COLOUR)
发表于 2019-8-16 21:22:15 | 显示全部楼层
;执行两次程序,模型空间背景颜色在黑色与白色之间切换
(defun c:bjys()
    (vl-load-com)
    (setq yssz (variant-value
                    (vlax-variant-change-type
                          (vla-get-GraphicsWinModelBackgrndColor
                               (setq display (vla-get-display
                          vlax-vblong
    (setq yssz(vlax-make-variant (abs (- yssz 16777215)) vlax-vblong))
    (vla-put-GraphicsWinModelBackgrndColor display yssz)
    (vlax-release-object display)
发表于 2019-8-16 22:01:22 | 显示全部楼层
背景在黑与白之间转换
摘自明经通道
(defun c:ax (/ prefdisplay)
  (vl-load-com)
  (setq prefdisplay (vla-get-display (vla-get-preferences
        color (vlax-variant-value (vlax-variant-change-type
                                                            (vla-get-graphicswinmodelbackgrndcolor prefdisplay)
                                                            vlax-vblong
  (vla-put-graphicswinmodelbackgrndcolor prefdisplay
                                         (vlax-make-variant (if (= color 0)
                                                              16777215
                                                              0
                                                            ) vlax-vblong
发表于 2019-8-16 22:10:58 | 显示全部楼层
根据二楼修改的
(defun c:tt5(/ col DISPLAY)
        (setq    DISPLAY    (vla-get-display
        (if (= (getenv "Background") "0") (setq col 255) (setq col 0))
        (vla-put-graphicswinlayoutbackgrndcolor DISPLAY (vlax-make-variant
        (+ col (* col 256)(* col 65536))
        vlax-vblong
  (vla-put-graphicswinmodelbackgrndcolor DISPLAY (vlax-make-variant
        vlax-vblong
发表于 2019-8-29 02:43:19 | 显示全部楼层
GMT+8, 2025-5-18 16:36 , Processed in 0.169880 second(s), 22 queries , Gzip On.
