目前无法用lisp生成动态块,只能先定义好再插入
如何用lisp插入呢,这个就是代码,我是搬运工。
 - [code=lisp](setq dwg "D:\\tested_dwg.dwg")
- (defun eea-3d-add-del ()
- (if (tblobjname "layer" "3D")
- (command "_.-laydel" "_Name" "3D" "" "_Yes")
- (command "_.-insert"
- (strcat (vl-filename-base dwg) "=" dwg)
- nil)
- (princ)
- (eea-3d-add-del)
[/code]
