查看: 2258|回复: 7
[提问] 块统计,以下源码,怎么才可以达到下面效果?
发表于 2019-10-11 18:44:39 | 显示全部楼层 |阅读模式
(defun listFormatInputList (listInput             /                     listComponentAlias    listFormatedInput     listMemberOfInput
                            boolIsAlias           intDefinedAliasNumber k                     strInputComponentName strAlias
(setq listComponentAlias '(("bt" "button")
                            ("edit" "edit_box")
                            ("edit12" "edit12_box")
                            ("edit32" "edit32_box")
                            ("listbox" "list_box")
                            ("ComboBox" "popup_list")
                            ("btRadio" "radio_button")
                            ("tg" "toggle")
                            ("btOK" "ok_only")
                            ("btCancel" "cancel_button")
                            ("btErrer" "errtile")
                            ("btHelp" "help_button")
                            ("btInfo" "info_button")
                            ("btOC" "ok_cancel")
                            ("btOCH" "ok_cancel_help")
                            ("btOCHE" "ok_cancel_help_errtile")
                            ("btOCHI" "ok_cancel_help_info")
                            ("color17" "color_palette_1_7")
                            ("color19" "color_palette_1_9")
                            ("color09" "color_palette_0_9")
                            ("color250255" "color_palette_250_255")
                            ("stdColor" "std_rq_color")
(setq listFormatedInput nil)
(foreach listMemberOfInput listInput
  (setq k 0
        boolIsAlias "No"
  (setq strInputComponentName (strcase (car listMemberOfInput) T))
  (setq intDefinedAliasNumber (length listComponentAlias))
  (while (and (< k intDefinedAliasNumber) (= boolIsAlias "No"))
   (setq strAlias (strcase (car (nth k listComponentAlias)) T))
   (if (= strInputComponentName strAlias)
    (progn (setq boolIsAlias "Yes")
           (setq listFormatedInput (append listFormatedInput
                                           (list (cons (cadr (nth k listComponentAlias))
                                                       (cdr listMemberOfInput)
   (setq k (1+ k))
  (if (= boolIsAlias "No")
                                   (list (cons (strcase (car listMemberOfInput) T)
listFormatedInput
;;;把输入的参数表转换为字符串表
(defun listInputToString (listInput  /  listMemberOfInput   listCdrMemberOfInput
   listMemberOfComponentParameters   listComponentParameters  listCadrMemberOfComponentParameters
   listResult   k j   boolDefinementFound strTmp  test1   test2  )
;;;组件定义参数表,形式为 ( ( 组件名列表) ( 对应参数名列表) )
;;; 无属性控件,生成dcl文件时,在组件名后添加" ; “即可;如为“end”,在dcl文件里加上"}"字符即可
;;; 容器控件及带属性控件,需要在名前添加” : ",名后加 "{"
(setq listComponentParameters '((("容器控件" "dialog")
                                  ("label"               "key"                 "value"               "initial_focus"
                                   "height"              "width"               "children_alignment"  "children_fixed_height"
                                   "children_fixed_width"
                                 (("容器控件"          "boxed_column"      "boxed_row"         "boxed_radio_column"
                                   "boxed_radio_row"   "column"            "row"               "radio_row"         "radio_column"
                                   "concatenation"     "paragraph"
                                  ("label"               "key"                 "is_enabled"          "alignment"
                                   "height"              "width"               "fixed_height"        "fixed_width"
                                   "children_alignment"  "children_fixed_height"                     "children_fixed_width"
                                 (("带属性控件" "button")
                                  ("label"         "key"           "action"        "alignment"     "height"        "width" "horizontal_margin"
                                   "vertical_margin" "fixed_height"  "fixed_width"   "is_cancel"     "is_default"    "is_enabled"    "is_tab_stop"
                                   "mnemonic"
                                 (("带属性控件" "edit_box" "edit12_box" "edit32_box" "fcf_ebox" "fcf_ebox1")
                                  ("label"          "key"            "value"          "action"         "alignment"      "height"
                                   "width"          "fixed_height"   "fixed_width"    "allow_accept"   "edit_limit"     "edit_width"
                                   "is_enabled"     "is_tab_stop"    "mnemonic"       "password_char"
                                 (("带属性控件" "image" "image_block" "icon_image")
                                  ("key"           "value"         "action"        "alignment"     "height"        "width"
                                   "fixed_height"  "fixed_width"   "is_enabled"    "is_tab_stop"   "mnemonic"      "aspect_ratio"
                                   "color"
                                 (("带属性控件" "image_button" "swatch" "fcf_ibut" "fcf_ibut1")
                                  ("key"            "action"         "alignment"      "height"         "width"          "fixed_height"
                                   "fixed_width"    "is_enabled"     "is_tab_stop"    "mnemonic"       "allow_accept"   "aspect_ratio"
                                   "color"
                                 (("带属性控件" "list_box")
                                   "width"          "fixed_height"   "fixed_width"    "allow_accept"   "fixed_width_font"
                                   "is_enabled"     "is_tab_stop"    "list"           "mnemonic"       "multiple_select"
                                   "tabs"           "tab_truncate"
                                 (("带属性控件" "popup_list")
                                   "width"         "fixed_height"  "fixed_width"   "edit_width"    "fixed_width_font"
                                   "is_enabled"    "is_tab_stop"   "list"          "mnemonic"      "tabs"          "tab_truncate"
                                 (("带属性控件" "radio_button")
                                  ("label"         "key"           "value"         "action"        "is_enabled"    "is_tab_stop"
                                   "mnemonic"      "alignment"     "height"        "width"         "fixed_height"  "fixed_width"
                                 (("带属性控件" "slider")
                                   "width"         "fixed_height"  "fixed_width"   "big_increment" "layout"        "max_value"
                                   "min_value"     "mnemonic"      "small_increment"
                                 (("带属性控件" "spacer")
                                  ("value" "height" "width" "fixed_height" "fixed_width")
                                 (("带属性控件" "text" "text_part" "text_25")
                                  ("label" "key" "value" "alignment" "height" "width" "fixed_height" "fixed_width" "is_bold")
                                 (("带属性控件" "toggle")
                                  ("label" "key" "value" "action" "alignment" "height" "width" "fixed_height" "fixed_width" "is_enabled"
                                   "is_tab_stop")
                                 (("无属性控件"           "cancel_button"        "errtile"              "help_button"
                                   "info_button"          "ok_cancel"            "ok_cancel_help"       "ok_cancel_help_errtile"
                                   "ok_cancel_help_info"  "ok_only"              "spacer"               "spacer_0"
                                   "spacer_1"             "color_palette_1_7"    "color_palette_1_9"    "color_palette_0_9"
                                   "color_palette_250_255"                       "std_rq_color"
                                 (("无属性控件" "end")) ;以"end"作为单个组件定义的结束,生成dcl文件时,以“}“代替
(setq listResult nil)
(setvar "dimzin" 8)
  (setq k 0
        boolDefinementFound "NotYet"
  (while (and (= boolDefinementFound "NotYet")
              (< k (length listComponentParameters))
         ) ;未找到组件参数名列表且未搜索完组件预定义列表时循环
   (setq listMemberOfComponentParameters (nth k listComponentParameters))
   (if (and (member (car listMemberOfInput)
                    (car listMemberOfComponentParameters)
            (if (= "spacer" (car listMemberOfInput))
             (>= (length listMemberOfInput)
                 (length listMemberOfComponentParameters)
             T
            ) ;因spacer既可为无属性控件也可为带属性控件,故特别处理
    (progn (setq boolDefinementFound  "Found"
                 listCdrMemberOfInput (cdr listMemberOfInput)
           (cond ((or (= "容器控件" (car (car listMemberOfComponentParameters)))
                      (= "带属性控件" (car (car listMemberOfComponentParameters)))
                  listCdrMemberOfInput ;组件参数值有数据时
                  (setq listResult (append listResult
                                           (list (strcat ":" (car listMemberOfInput) "{\n"))
                  (setq j                                   0
                        listCadrMemberOfComponentParameters (cadr listMemberOfComponentParameters)
                  (while (< j (length listCdrMemberOfInput))
                   (if (not (= "" (nth j listCdrMemberOfInput)))
                    (progn ;参数值非空时
                     (if (numberp (nth j listCdrMemberOfInput))
                      (setq strTMP (strcat (nth j listCadrMemberOfComponentParameters)
                                           (rtos (nth j listCdrMemberOfInput) 2 3)
                                           ";\n"
                      ) ;参数为数值时
                                           "\";\n"
                      ) ;参数非数值时
                     (setq listResult (append listResult (list strTMP)))
                   (setq j (1+ j))
                  (if (= "带属性控件" (car (car listMemberOfComponentParameters)))
                   (setq listResult (append listResult (list "}\n")))
                  ) ;带属性控件时,在字符串末尾加上组件结束标志 "}"
                 ((= (car listMemberOfInput) "end")
                 (T ;(= "无属性控件" (car (car listMemberOfComponentParameters))) ,默认为无属性控件
                                           (list (strcat (car listMemberOfInput) ";\n"))
    (setq k (1+ k))
listResult
;;;生成并显示输入对话框
;;;调用形式 ( listGenerateDCL  DCL文件名(无路径及后缀)
;;;                 表( ( ( "组件名或别名")  ( 参数值表 )  )   ...)
;;;                 表( (  "组件编号"  "组件初始值"  )   ...)    ;组件显示值初始化
;;;                 表( (  "组件编号"  "动作代码"  )   ...)      ;需设置动作的组件及对应的动作
;;;                 表("组件编号"  ...)   )    ;用户点“确定”键时,需获取输入值的组件名
;;;注意,调用参数均为字符串形式
;;;返回值为表,形式为 ( 关闭对话框的整数代码       指定组件返回值列表)
(defun listGenerateDCL (strDCLFileName      listInputDefinements                    listKeysAndValues   listKeysAndActions
                        listKeysToGetValue  /                   listFormatedInput   intDialogCloseType  listKeysValue
                        listResult          fStream             strFileFullName     objectFile          fileStream
                        templist            i                   dclid
;;;按 ( ( “组件名”  显示"  ) ) 表,设置各组件的值
(defun SetDCLValues (listKeysAndValues / listEachKeyAndValue)
  (foreach listEachKeyAndValue listKeysAndValues
   (set_tile (car listEachKeyAndValue)
             (cadr listEachKeyAndValue)
;;;按 ( ( “组件名”  “动作"  ) ) 表,把组件与动作关联
(defun SetDCLActions (listKeysAndActions / listEachKeyAndAction)
  (foreach listEachKeyAndAction listKeysAndActions
   (action_tile (car listEachKeyAndAction)
                (cadr listEachKeyAndAction)
;;;按 ( “组件名” ) 表,查询各组件值并返回值表
(defun listGetDCLValues (listKeys / listEachKey listValues)
  (setq listValues nil)
  (foreach listEachKey listKeys
   (setq listValues (append listValues (list (get_tile listEachKey))))
  listValues
(setq strFileFullName (vl-filename-mktemp (strcat strDCLFileName ".dcl")))
(setq objectFile (open strFileFullName "w"))
(setq listFormatedInput (listFormatInputList listInputDefinements))
(setq fileStream (append (list strDCLFileName)
                          (listInputToString listFormatedInput)
(foreach fStream fileStream (princ fStream objectFile))
(close objectFile)
;;以上生成dcl文件,以下调用DCL,设置组件值、关联动作,获取返回值
(setq dclid (load_dialog strFileFullName))
(if (not (new_dialog strDCLFileName dclid ""))
  (progn (alert "对话框加载失败!") (exit))
(if listKeysAndValues
  (SetDCLValues listKeysAndValues)
(if listKeysAndActions
  (SetDCLActions listKeysAndActions)
(if listKeysToGetValue
  (action_tile "accept"  "(setq listKeysValue (listGetDCLValues listKeysToGetValue)) (done_dialog 1)" )
(setq intDialogCloseType (start_dialog))
(unload_dialog dclid)
(vl-file-delete strFileFullName)
(setq listResult (append (list intDialogCloseType) listKeysValue))
listResult
(defun strLength (str / sLength x1 x2 lst)
(setq lst (textbox (list (cons 1 str))))
(setq x1 (car (nth 0 lst))
       x2 (car (nth 1 lst))
(setq sLength (abs (- x2 x1)))
sLength
;;;以当前设置初始化文本高、宽
(defun initText (/ pt str eTextN)
(setq pt (list 0 0))
(setq str "初始化")
(command "text" pt #ZiGao# 0 str)
(setq eTextN (entlast))
(entdel eTextN)
;;; 返回polyline的点表
;;;调用参数形式 (  多义线图元名 )
(defun getplpts (pl / mark pts ver1 i ee pt)
(if (= "POLYLINE" (cdr (assoc 0 (entget pl))))
  (progn  ; read points of ployline
   (setq mark "VERTEX"
         i    0
         ver1 (entnext pl)
   (while (= "VERTEX" mark)
    (setq pts (append pts (list (cdr (assoc 10 (entget ver1))))))
    (setq ver1 (entnext ver1)
          i    (1+ i)
    (setq mark (cdr (assoc 0 (entget ver1))))
  (progn  ; read points of lwployline
   (setq ee (entget pl))
   (foreach pt ee
    (if (= 10 (car pt))
     (setq
      pts (append
           pts
           (list (append (cdr pt) (list (cdr (assoc 38 ee)))))
pts
(defun AddLineone (listStartPoint listEndPoint)
(setq clay (getvar "clayer"))    ; 原始图层状态赋值给oldlay
(if (null (tblsearch "LAYER" "4B-CH NOTES")) ; 如果还没有001图层
    (command "._layer" "m" "4B-CH NOTES" "c" "240" "" "lt" "continuous" "" "LW"
         "0.13" "" ""
    (setvar "clayer" "4B-CH NOTES")           ; 否则直接转换到001图层
(entmake (list '(0 . "LINE")
                (cons 10 listStartPoint)
                (cons 11 listEndPoint)
   (while (/= 0 (getvar "cmdactive"))   ; 没有它回不到原来图层
    (command pause)
  (SETVAR "CLAYER" CLAY)
(defun AddText_AlignmentMiddle  (listInsertPoint floatTextHigh floatRotateAngle strText floatScaleFactor  strStyleName)
(if (null (tblsearch "LAYER" "4B-CH NOTES")) ; 如果还没有003图层
    (command "._layer" "m" "4B-CH NOTES" "c" "100" "" "lt" "continuous" "" "LW"
         "0.13" "" ""
    (setvar "clayer" "4B-CH NOTES")           ; 否则直接转换到003图层
(entmake (list '(0 . "TEXT")
                '(10 0 0 0)
                (cons 11 listInsertPoint)
                (cons 40 floatTextHigh)
                (cons 1 strText)
                (cons 50 floatRotateAngle)
                (cons 41 floatScaleFactor)
                (cons 7 strStyleName)
                '(72 . 1)
                '(100 . "AcDbText")
    (command pause)
(defun AddText_AlignmentMiddleone  (listInsertPointone floatTextHighone floatRotateAngleone strTextone floatScaleFactorone  strStyleNameone)
(if (null (tblsearch "LAYER" "0")) ; 如果还没有0图层
    (command "._layer" "m" "0" "c" "255" "" "lt" "continuous" "" "LW"
         "0.13" "" ""
    (setvar "clayer" "0")           ; 否则直接转换到0图层
                '(10 0 0 0)
                (cons 11 listInsertPointone)
                (cons 40 floatTextHighone)
                (cons 1 strTextone)
                (cons 50 floatRotateAngleone)
                (cons 41 floatScaleFactorone)
                (cons 7 strStyleNameone)
                '(72 . 1)
                '(100 . "AcDbText")
    (command pause)
(defun AddText_AlignmentMiddletwo  (listInsertPointtwo floatTextHightwo floatRotateAngletwo strTexttwo floatScaleFactortwo  strStyleNametwo)
(if (null (tblsearch "LAYER" "4B-CH NOTES")) ; 如果还没有004图层
    (command "._layer" "m" "4B-CH NOTES" "c" "210" "" "lt" "continuous" "" "LW"
         "0.13" "" ""
    (setvar "clayer" "4B-CH NOTES")           ; 否则直接转换到004图层
                '(10 0 0 0)
                (cons 11 listInsertPointtwo)
                (cons 40 floatTextHightwo)
                (cons 1 strTexttwo)
                (cons 50 floatRotateAngletwo)
                (cons 41 floatScaleFactortwo)
                (cons 7 strStyleNametwo)
                '(72 . 1)
                '(100 . "AcDbText")
    (command pause)
(defun AddText_AlignmentMiddlethree  (listInsertPointthree floatTextHighthree floatRotateAnglethree strTextthree floatScaleFactorthree  strStyleNamethree)
(if (null (tblsearch "LAYER" "4B-CH NOTES")) ; 如果还没有005图层
    (command "._layer" "m" "4B-CH NOTES" "c" "41" "" "lt" "continuous" "" "LW"
         "0.13" "" ""
    (setvar "clayer" "4B-CH NOTES")           ; 否则直接转换到005图层
                '(10 0 0 0)
                (cons 11 listInsertPointthree)
                (cons 40 floatTextHighthree)
                (cons 1 strTextthree)
                (cons 50 floatRotateAnglethree)
                (cons 41 floatScaleFactorthree)
                (cons 7 strStyleNamethree)
                '(72 . 1)
                '(100 . "AcDbText")
    (command pause)
;;输出表头
;;;在当前图层、当前空间、按文本左对齐方式,写单行文本
;;;调用形式 (  AddText_AlignmentLeft  插入点坐标 显示 文本旋转角度(rad)  文本内容  宽高比例 字体样式名),如果成功,返回定义数据的图元表,否则返回 nil。
(defun AddText_AlignmentLeft  (listInsertPoint floatTextHigh floatRotateAngle strText floatScaleFactor  strStyleName)
                (cons 10 listInsertPoint)
                (cons 1 strText)
                '(100 . "AcDbText")
;;;在当前图层、当前空间插入块
;;;调用形式 ( InsertBlock  显示  插入点  旋转角度 )
;;;成功时,返回dxf组码,否则返回nil
(defun InsertBlock ( strBlockName listInsertPoint floatRotateAngle )
(entmake (list '(0 . "INSERT")
'(100 . "AcDbEntity")
'(100 . "AcDbBlockReference")
(cons 2 strBlockName)
(cons 50 floatRotateAngle)))
;;;标记undo编组开始点
(defun BeginUndoGroup()
(command "undo" "be")
;;;标记undo编组结束点
(defun EndUndoGroup()
(command "undo" "e")
;;块统计.LSP
;;;从块选择集中选择指定块名的对象,并返回结果选择集
(defun intCountSingleBlock (ssOriginal strTargetBlockName /
                  strEntityName listEntityDXF strBlockName intSingleBlockCount k)
(setq intSingleBlockCount 0
       k -1 )
(repeat (sslength ssOriginal) ; 循环与所选择的对象数量相等的次数
  (setq strEntityName (ssname ssOriginal (setq k (1+ k)))) ; strEntityName,取得第k个对象名
  (setq listEntityDXF (entget strEntityName))
  (setq strBlockName (cdr (assoc 2 listEntityDXF)))
  (if (= strBlockName strTargetBlockName)
   (setq intSingleBlockCount (1+ intSingleBlockCount))
intSingleBlockCount
;;;从块选择集中删除指定块名的对象,并返回结果选择集
(defun ssDelEntitysFromBlockSelectionSet (ssOriginal strTargetBlockName
                       / strEntityName listEntityDXF strBlockName ssResult k)
(setq ssResult (ssadd)
       k -1 )
  (if (/= strBlockName strTargetBlockName)
   (setq ssResult (ssadd strEntityName ssResult))
ssResult
;;;插入块缩略图
(defun PrintBlockMiniature (floatBasicPointX                  floatBasicPointY                  strBlockName
                            /                                 floatMaxBlockWidth                floatMaxBlockHigh
                            floatBlockOriginalWidth           floatBlockOriginalHigh            floatBlockWidthScale
                            floatBlockHighScale               floatBlockBoundingBoxTargetMinPointX
                            floatBlockBoundingBoxTargetMinPointY   floatBlockBoundingBoxTargetMaxPointX
                            floatBlockBoundingBoxTargetMaxPointY   listTargetBlockCenterPoint
                            listBlockBoundingBoxMinPoint      listBlockBoundingBoxMaxPoint      objectBlockEntity
                            strEntityName                     listInsertPoint                   floatBlockScale
                            listBlockEntityDXF                listBlockCenterPoint
;; floatBasicPointX floatBasicPointY 缩略图所在表格单元左下角点坐标
;;计算图块缩略图在图中允许放置范围的左下及右上角点坐标的X、Y数值
(setq floatMaxBlockWidth 21
       floatMaxBlockHigh 8
(setq floatBlockBoundingBoxTargetMinPointX (+ floatBasicPointX 2)
       floatBlockBoundingBoxTargetMinPointY (+ floatBasicPointY 1)
       floatBlockBoundingBoxTargetMaxPointX (+ floatBasicPointX floatMaxBlockWidth 2)
       floatBlockBoundingBoxTargetMaxPointY (+ floatBasicPointY floatMaxBlockHigh 1)
(setq listTargetBlockCenterPoint (list (/ (+ floatBlockBoundingBoxTargetMinPointX  floatBlockBoundingBoxTargetMaxPointX ) 2)
                                        (/ (+ floatBlockBoundingBoxTargetMinPointY floatBlockBoundingBoxTargetMaxPointY )  2 )
                                        0
(setq listInsertPoint (list floatBlockBoundingBoxTargetMinPointX  floatBlockBoundingBoxTargetMinPointY  ) )
(InsertBlock strBlockName listInsertPoint 0)
;;以块缩略图允许放置范围的左下角点为块缩略图的基点插入图块
(setq strEntityName (entlast))
(setq objectBlockEntity (vlax-ename->vla-object strEntityName))
(if  (vl-catch-all-error-p (vl-catch-all-apply 'vla-GetBoundingBox
                                                (list objectBlockEntity  'listBlockBoundingBoxMinPoint 'listBlockBoundingBoxMaxPoint ))
         ) ;判断块是否存在边框,若块含无限长直线等时,则不存在边框
    (AddText_AlignmentMiddle listBlockCenterPoint 3 0 "本块无缩略图" 0.8 "standard")
(setq listBlockBoundingBoxMinPoint (vlax-safearray->list listBlockBoundingBoxMinPoint) )
(setq listBlockBoundingBoxMaxPoint (vlax-safearray->list listBlockBoundingBoxMaxPoint) )
(if (> (car listBlockBoundingBoxMaxPoint)  (car listBlockBoundingBoxMinPoint) )
      (setq floatBlockWidthScale (/ floatMaxBlockWidth
                                     (- (car listBlockBoundingBoxMaxPoint) (car listBlockBoundingBoxMinPoint) )
       (setq  floatBlockWidthScale 0)
(if (> (cadr listBlockBoundingBoxMaxPoint) (cadr listBlockBoundingBoxMinPoint)  )
    (setq   floatBlockHighScale  (/ floatMaxBlockHigh
                                    (- (cadr listBlockBoundingBoxMaxPoint) (cadr listBlockBoundingBoxMinPoint) )
     (setq   floatBlockHighScale 0)
;计算块缩略图允许放置范围的边框长宽与块外框长宽的比值
(cond
  ((= (+ floatBlockWidthScale floatBlockHighScale) 0)  (setq floatBlockScale 1)) ;块为单点时,缩放比例取为1
  ((=  floatBlockWidthScale 0)  (setq floatBlockScale floatBlockHighScale) ) ;块为竖直短线时
  ((=  floatBlockHighScale 0)  (setq floatBlockScale floatBlockWidthScale) ) ;块为水平短线时
  ((> floatBlockWidthScale floatBlockHighScale )  (setq floatBlockScale floatBlockHighScale) ) ;数值较小者为块的控制缩放比例
  (T  (setq floatBlockScale floatBlockWidthScale) )
(setq listBlockEntityDXF (entget strEntityName))
(entmod (subst (cons 41 floatBlockScale) (assoc 41 listBlockEntityDXF) listBlockEntityDXF ) )
(entupd strEntityName)
(entmod (subst (cons 42 floatBlockScale) (assoc 42 listBlockEntityDXF) listBlockEntityDXF ) )
(entmod (subst (cons 43 floatBlockScale) (assoc 43 listBlockEntityDXF) listBlockEntityDXF ) )
;;缩放块
(vla-GetBoundingBox objectBlockEntity 'listBlockBoundingBoxMinPoint 'listBlockBoundingBoxMaxPoint)
(setq listBlockCenterPoint (list (* 0.5 (+ (car listBlockBoundingBoxMaxPoint) (car listBlockBoundingBoxMinPoint) ) )
                                  (* 0.5 (+ (cadr listBlockBoundingBoxMaxPoint) (cadr listBlockBoundingBoxMinPoint) ) )
                                  0
(vla-move objectBlockEntity (vlax-3d-point listBlockCenterPoint) (vlax-3d-point listTargetBlockCenterPoint))
;;;显示统计结果表
(defun PrintCountResultList (listResult  /  i  ListLength strBlockName
  intNumberOfSSSingleBlockName   strNumberOfSSSingleBlockName  pt pt1 pt2  pt3 pt4 pt5 pt6 pt7  x  y  x1  y1 y2
  x2  x3  floatTextHigh floatTextHighone  blocknumber blocknumbersum)
(setq pt (getpoint "\n点取要标注块统计结果信息的位置:"))
(setq x (car pt)
       y (cadr pt)
       i 1
       floatTextHigh 4
            floatTextHighone 7
                 floatTextHightwo 4.5
(setq ListLength (length listResult))
(setq y1 (- y (* (1+ (+ 1 ListLength)) 10))) ;行高取10
(while (<= i 2)
  (setq x1 (+ x (* i 25))) ;列宽取25
  (setq pt1 (list x1 y 0)
        pt2 (list x1 y1 0)
  (AddLineone pt1 pt2)
  (setq i (1+ i))
;;;画竖向表格线
(setq i 1)
(setq x1 (+ x (* 4 25)))
(while (<= i (1+ ListLength))
  (setq y1 (- y (* i 10)))
  (setq pt1 (list x y1 0)
        pt2 (list x1 y1 0)
  (setq i (1+ i))
;;;画横向表格线
(if (null (tblsearch "LAYER" "002")) ; 如果还没有002图层
    (command "._layer" "m" "002" "c" "41" "" "lt" "continuous" "" "LW"
         "0.5" "" ""
    (setvar "clayer" "002")           ; 否则直接转换到002图层
     y1 (- y (* 10 (+ 2 ListLength))))
  (setq pt1 (list x y 0)
       pt2 (list x1 y1 0)
                 pt3 (list x y1 0)
                 pt4 (list x1 y 0)
   (command "pline" pt1 pt4 pt2 pt3 "c")
    (command pause)
;;;画外围矩形
(setq x1 (+ x (* 0.5 25))
       x2 (+ x (* 1.5 25))
       x3 (+ x (* 2.5 25))
       y1 (- y 7)
           y2 (+ y 5)
(setq pt1 (list x1 y1 0)
       pt2 (list x2 y1 0)
       pt3 (list x3 y1 0)
           pt8 (list x2 y2 0)
(AddText_AlignmentMiddlethree pt1 floatTextHigh 0 "缩略图" 0.5 "standard")
(AddText_AlignmentMiddlethree pt2 floatTextHigh 0 "名称" 0.5 "standard")
(AddText_AlignmentMiddlethree pt3 floatTextHigh 0 "数量" 0.5 "standard")
(AddText_AlignmentMiddlethree pt4 floatTextHigh 0 "条码" 0.5 "standard")
(AddText_AlignmentMiddlethree pt8 floatTextHighone 0 "数量统计" 0.5 "standard")
;;输出表头
(setq i 0
       floatTextHigh 3
              blocknumber 0    )
(while (< i ListLength)
  (setq y1 (+ y (* -10 (+ i 2))))
  (setq ;pt1 (list x1 y1 0)
        pt2 (list x2 (+ y1 3) 0)
        pt3 (list x3 (+ y1 3) 0)
  (setq strBlockName (car (nth i listResult))
        intNumberOfSSSingleBlockName (cadr (nth i listResult))
  (setq blocknumber (+ blocknumber intNumberOfSSSingleBlockName))
  (setq strNumberOfSSSingleBlockName (itoa intNumberOfSSSingleBlockName))
  (AddText_AlignmentMiddle pt2 floatTextHigh 0 strBlockName 0.8 "standard")
  (AddText_AlignmentMiddle pt3 floatTextHigh 0 strNumberOfSSSingleBlockName 1.0 "standard")
  (if (vl-catch-all-error-p (vl-catch-all-apply 'PrintBlockMiniature (list x y1 strBlockName)))
     (AddText_AlignmentLeft (list (+ x 1) (+ y1 2)) 3 0 "生成灯缩略图时出错" 0.5 "standard")
  (setq i (1+ i))
;;;显示表内容
(setq i 0
      blocknumbersum 0 )
       (setq blocknumbersum (+ blocknumbersum intNumberOfSSSingleBlockName))
            (setq i (1+ i))
(setq intNumberOfSSSingleBlockName (itoa blocknumbersum))
(setq strNumberOfSSSingleBlockName (itoa blocknumber))
(setq   y1 (- (- y (* 10 (+ 1 ListLength))) 7 )
(setq pt5 (list x1 y1 0)
       pt6 (list x2 y1 0)
       pt7 (list x3 y1 0)
(AddText_AlignmentMiddletwo pt5 floatTextHightwo 0 intNumberOfSSSingleBlockName  0.5 "standard")
(AddText_AlignmentMiddle pt5 floatTextHightwo 0 "共      种"  0.5 "standard")
(AddText_AlignmentMiddlethree pt6 floatTextHightwo 0 "汇  总" 0.5 "standard")
(AddText_AlignmentMiddletwo pt7 floatTextHightwo 0 strNumberOfSSSingleBlockName 0.5 "standard")
(AddText_AlignmentMiddle pt7 floatTextHightwo 0 "共       个"  0.5 "standard")
;;输出表尾
(defun GetBlocksSelectionRange (/ strDCLFileName listInputDefinements listKeysAndValues listKeysAndActions listKeysToGetValue
                     listDCLReturn intButtonClick strSelectRange)
(setq strSelectRange  "UserSelection" )
(setq strDCLFileName "BlocksSelectionRange")
(setq listInputDefinements '(("dialog" "指定统计范围" "")
                               ("spacer")
                                ("radio_column" "进行块统计的范围:")
                                 ("btRadio" "手工选择" "brUserSelection")
                                 ("btRadio" "整个图形" "brDrawingFile")
                                ("end")
                                ("text" "注:不统计含无限长直线的块!")
                              ("spacer")
                              ("btOK")
                              ("end")
(setq listKeysAndValues '(("brUserSelection" "1")))
(setq listKeysAndActions '(("brUserSelection" "(setq strSelectRange \"UserSelection\")")
                            ("brDrawingFile" "(setq strSelectRange \"DrawingFile\")")) )
(setq listKeysToGetValue nil)
(setq listDCLReturn (listGenerateDCL strDCLFileName listInputDefinements listKeysAndValues listKeysAndActions listKeysToGetValue) )
(setq intButtonClick (car listDCLReturn )  )
strSelectRange
;;;块数量统计
(defun tktj (/ ssObjects  strEntityName  listEntityDXF  strBlockName
  listResult  intSingleBlockCount  listMinPoint listInsertPoint  floatBlockRotateAngle
                                             ;;listResult 用于记录统计结果,形式为((  显示  块数量  同名块中一个实体的对象名 )...)
; (initget "D S _DrawingFile UserSelection")
; (setq strSelectRange (getkword "\n统计块的范围[显示(D)/显示(S)]<S>:"))
(setq strSelectRange (GetBlocksSelectionRange))
(if (= strSelectRange "DrawingFile")
  (setq ssObjects  (ssget "X" '((0 . "insert")(100 . "AcDbBlockReference")))) ; 创建选择集 ssObjects
   (princ "\n请选择需要统计的块:\n")
   (setq ssObjects (ssget '((0 . "INSERT")(100 . "AcDbBlockReference")))) ; 创建选择集 ssObjects
(if ssObjects
   (while (> (sslength ssObjects) 0)
    (setq strEntityName (ssname ssObjects 0)) ; strEntityName,取得第1个对象名
    (setq intSingleBlockCount (intCountSingleBlock ssObjects strBlockName ) )
    (setq ssObjects (ssDelEntitysFromBlockSelectionSet ssObjects strBlockName))
                             (list (list strBlockName intSingleBlockCount))
   (setvar "dimzin" 8)
   (setvar "osmode" 0)
  (if  (tblsearch "style" "standard")
    ;;判断是否存在"standard"字体,有则设为当前,无则创建。
       (setvar "textstyle" "standard")
       (command "_style" "standard" "sceie.shx,sceic.shx" 0 0.5 0 "N" "N" "N")
   (PrintCountResultList listResult)
   (setvar "osmode" 16383)
(defun c:kp()(tktj));QY :596099781
发表于 2019-10-11 19:29:14 | 显示全部楼层
把下面的段落换掉吧
;;;显示统计结果表
(setq x (car pt)
       y (cadr pt)
       i 1
       floatTextHigh 4
            floatTextHighone 7
(while (<= i 4)
        pt2 (list x1 y1 0)
  (setq i (1+ i))
;;;画竖向表格线
(setq i 1)
(setq x1 (+ x (* 5 25)))
        pt2 (list x1 y1 0)
  (setq i (1+ i))
;;;画横向表格线
         "0.5" "" ""
       pt2 (list x1 y1 0)
                 pt3 (list x y1 0)
                 pt4 (list x1 y 0)
    (command pause)
;;;画外围矩形
       x2 (+ x (* 1.5 25))
       x3 (+ x (* 2.5 25))
        x4 (+ x (* 3.5 25))
        x5 (+ x (* 4.5 25))
       y1 (- y 7)
           y2 (+ y 5)
       pt2 (list x2 y1 0)
       pt3 (list x3 y1 0)
        pt4 (list x4 y1 0)
        pt5 (list x5 y1 0)
           pt8 (list x3 y2 0)
(AddText_AlignmentMiddlethree pt5 floatTextHigh 0 "备注" 0.5 "standard")
;;输出表头
如果列宽改为40后,缩略图不居中怎么办呢  发表于 2019-10-15 09:32
 楼主| 发表于 2019-10-12 22:04:22 | 显示全部楼层
start4444 发表于 2019-10-11 19:29
把下面的段落换掉吧
非常谢谢。
发表于 2019-10-13 08:45:13 | 显示全部楼层
有精简版的吗
发表于 2019-10-14 20:59:09 | 显示全部楼层
谢谢分享,支持
发表于 2019-12-4 13:53:31 | 显示全部楼层
这个好像统计种类有点问题,数目不对
发表于 2023-11-12 12:04:57 | 显示全部楼层
修改好的可以发一下吗
GMT+8, 2025-11-12 04:05 , Processed in 0.218565 second(s), 31 queries , Gzip On.
