查看: 2403|回复: 0
南方CASS点号提取展点号坐标
发表于 2019-10-17 12:20:23 | 显示全部楼层 |阅读模式
原帖“根据南方CASS点号提取展点号坐标”中code代码另存为lsp文件,执行命令显示为字符串有缺陷。在此向大家请教有更好的方法谢谢分享
原code代码如下:
  1. (defun c:tt( / f ss lst ss m n e a ee b ptlst1  xx  bb)
  2.   (setq f(open(getfiled "打开(或建立)数据文件" "C:" "dat" 1)"w"))
  3.   (setq ss(ssget"X"'((8 . "ZDH")(0 . "POINT,INSERT")(-3 ("NAME,CODE")))))
  4.   (setq lst '())
  5.   (setq bb "NAME,CODE, Y坐标,X坐标,高程\n")
  6.   (if ss
  7.     (progn(setq m 0
  8.     n(sslength ss))
  9.       (while(< m n)
  10.   (setq e(entget(ssname ss m)'("*"))m(1+ m))
  11.   (if (setq a(cdr(assoc -3 e)))
  12.     (setq eE(cdr(assoc 10 e))
  13.                 b (LIST  (atof (cdr (car  (cdr (nth 0 a)))))   (read (cdr (car  (cdr (nth 1 a)))))  (CAR EE)  (CADR EE) (CADDR EE))
  14.
  15.        )
  16.     )  (SETQ LST (APPEND LST (LIST B)))
  17.   );;;;;;;;;;;;;;;;;;;;;;
  18.
  19. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  20. (setq ptlst (vl-sort LST
  21.                    ;以下根据点号对表排序
  22.    '(lambda (e1 e2)
  23.             (<= (car e1) (car e2) )
  24.          )   )    )
  25. ;;;;;;;;;;;;;;;;;-----------------------------------
  26. (foreach xx ptlst
  27. (setq bb(strcat bb(vl-princ-to-string  (nth 0 xx))","(vl-princ-to-string  (nth 1 xx))","(rtos (nth 2 xx) 2 3)"," (rtos (nth 3 xx) 2 3)","(rtos (nth 4 xx) 2 3)"\n"))
  28.
  29.   )
  30.
  31.       ))
  32.     (write-line bb f)
  33.     (close f)
  34.   )
GMT+8, 2025-12-10 10:27 , Processed in 0.389752 second(s), 27 queries , Gzip On.
