查看: 723|回复: 0
[提问] 怎么以下源码 转圆弧后,每个弧 PE合并在一起?
发表于 2019-10-17 20:31:01 | 显示全部楼层 |阅读模式
电梯直达[url=][/url]
楼主
(defun C:qa(/        HOLDECHO    OS          SSS        NUMPT N
                          ED        ED1   PTST  PTEND SS2        PT1   PT2
                          PT3        J     ENT   NNO          SS        SSL
  (defun VAL1 (N SS INDEX)
    (cdr (assoc N (entget (ssname SS INDEX))))
  (defun CH_IT (NOS)
    (if        (assoc NOS ED)
        (if (assoc NOS ENT)
          (setq ENT (subst (assoc NOS ED) (assoc NOS ENT) ENT))
          (setq ENT (append ENT (list (assoc NOS ED))))
        (entmod ENT)
  (setq HOLDECHO (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "_.undo" "group")
  (setq OS (getvar "osmode"))
  (setvar "osmode" 0)
  (prompt "\nPlease pick the spline: ")
  (setq SSS (ssget '((0 . "spline"))))
  (if SSS
      (initget (+ 1 2 4))
      (setq NUMPT
             (getint
               "\nPlease specify the accuracy of conversion: "
      (setq N 0)
      (setq SSL (sslength SSS))
      (repeat SSL
        (prompt (strcat "\r余 " (itoa (- SSL N)) " 个物件     "))
        (setq ED1 (ssname SSS N))
        (setq ED (entget ED1))
        (setq PTST  (cdr (assoc 10 ED))
              PTEND (cdr (assoc 10 (reverse ED)))
        (command "_.divide" ED1 (* 2 NUMPT))
        (setq SS2 (ssget "p"))
        (if (= (logand (cdr (assoc 70 ED)) 1) 1)
          (setq J 1)
          (setq J 0)
        (setq PT3 PTST)
        (setq SS (ssadd))
        (repeat        NUMPT
          (setq PT2 (VAL1 10 SS2 J))
          (if (/= NUMPT (/ (+ J 2) 2))
            (setq PT1 (VAL1 10 SS2 (+ 1 J)))
            (setq PT1 PTEND)
          (command "_.arc" PT3 PT2 PT1)
          (ssadd (entlast) SS)
          (setq PT3 PT1)
          (setq J (+ 2 J))
        (command "_.pedit" (ssname SS 1) "" "j" SS "" "")
        (setq ENT (entget (entlast)))
        (foreach NNO '(6 8 62 48)
          (CH_IT NNO)
        (command "_.erase" SS2 ED1 "")
        (setq N (1+ N))
      (prompt (strcat "\r完成转换                               ")
    (alert "Nothing selected!!")
  (setvar "osmode" OS)
  (command "_.undo" "end")
  (setvar "cmdecho" HOLDECHO)
GMT+8, 2025-8-26 04:15 , Processed in 0.173249 second(s), 26 queries , Gzip On.
