查看: 1246|回复: 1
[提问] yjr111 高手的图层状态管理器图层状态-快捷键问题
发表于 2019-10-27 15:40:26 | 显示全部楼层 |阅读模式
希望可以--实现--输入指定字母Q1 Q2再切换图层状态现在只支持首个字母
(defun c:laman(/ ladict1 ladict n statenemelst num )
(setq ladict1(vla-GetExtensionDictionary (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))))
(repeat (setq m(vla-get-count ladict1))
(setq ladict(vla-item ladict1 (setq m(1- m))))
(repeat (setq n(vla-get-count ladict))
  (setq statenemelst(cons (vla-get-name(vla-item ladict(setq n(1- n))))statenemelst))
(xsdhk)
(if num(command "layer" "a" "r" (nth (atoi num) statenemelst) "" "" ))
;;;添加列表框内列表
  (defun adlst(key lst);;;仅对popup_list或list_box有效
    (start_list key 3);;;处理列表开始
    (mapcar 'add_list  lst)
    (end_list);;;添加列表结束
(defun xsdhk (/ replace lsdcl fn dclid )
    (setq fn (open (setq lsdcl (VL-FILENAME-MKTEMP "tmp" "" ".dcl")) "w"))
    (foreach x '("  yyy : dialog{"
                 "  label=\"StateManager\";"
                 "  :list_box{key=\"9\";height=18;width=12;}"
                 "  :button{key=\"cancel\";label=\"Cancel\";is_cancel=true;width=1;height=2;}"
      (write-line x fn)
    (close fn)
    (setq dclid (load_dialog lsdcl))
    (vl-file-delete lsdcl)
    (new_dialog "yyy" dclid "" screenpt)
    (adlst "9"  statenemelst)
    (action_tile "9" "(setq num $value)(done_dialog)")
    (start_dialog)
    (unload_dialog dclid)
(princ"\n图层状态简易切换,命令LAMAN.")
(PRINC)
发表于 2024-10-15 14:29:19 | 显示全部楼层
你解决了 哥哥 我也想实现这个功能
GMT+8, 2025-4-22 12:49 , Processed in 0.148322 second(s), 25 queries , Gzip On.
