查看: 857|回复: 5
[讨论] 修改文件读写属性
发表于 2019-11-3 10:41:59 | 显示全部楼层 |阅读模式
我有自己写了一个文件Autoload.lsp,有时候会莫名被杀毒软件把文件属性修改成只读,是否有办法用写段代码把这个改成可以读写,谢谢!
发表于 2019-11-3 11:46:13 | 显示全部楼层
(defun SetRO (/ afile fso ofile ro)
   (cond
     ((and (setq aFile (getfiled "" "" "" 4))
           (setq fso (vlax-create-object "Scripting.FilesystemObject"))
           (setq oFile (vlax-invoke fso 'GetFile aFile))
      (vlax-put-property oFile 'Attributes (setq ro (- 1 (logand 1 (vlax-get-property oFile 'Attributes)))))
      (princ (strcat "File set to " (nth ro '("Read-write" "Read-only"))))
      (vlax-release-object oFile)
      (vlax-release-object fso)
 楼主| 发表于 2019-11-3 22:28:07 | 显示全部楼层
   (cond
您的办法试验成功,感谢!
发表于 2019-11-4 10:07:08 | 显示全部楼层
我也需要这个
发表于 2019-11-8 15:55:13 | 显示全部楼层
Thanks for sharing ^^
GMT+8, 2025-5-18 14:15 , Processed in 0.174762 second(s), 26 queries , Gzip On.
