查看: 1343|回复: 3
[VBA][VBA]请斑竹帮助调试
发表于 2004-3-18 08:45:00 | 显示全部楼层 |阅读模式
' 坐标点排序函数
' 语法:SortPoints(Points, SortMode)
' Points
为坐标点数组
' SortMode为排序方式:0=X向,1=Y向,2=Z
' 返回值为排序后的坐标点数组
Public function SortPoints(Points As Variant, SortMode As String) As Variant
Dim NewPoints() As Variant
ReDim NewPoints(UBound(Points))
Dim k As Long
For k = 0 To UBound(NewPoints)
NewPoints(k) = Points(k)
Next k
Dim BestPoint As Variant
Dim Pnt1 As Double
Dim Pnt2 As Double
Dim i As Long
Dim j As Long
Dim Best_Value As Double
Dim Best_j As Long
For i = 0 To UBound(NewPoints) - 1
Best_Value = NewPoints(i)(SortMode)
BestPoint = NewPoints(i)
Best_j = i
For j = i + 1 To UBound(NewPoints)
If NewPoints(j)(SortMode) < Best_Value Then
Best_Value = NewPoints(j)(SortMode)
BestPoint = NewPoints(j)
Best_j = j
End If
Next j
NewPoints(Best_j) = NewPoints(i)
NewPoints(i) = BestPoint
Next i
SortPoints = NewPoints
End Function '
示例
Sub FindLineStartPoint()
Dim Sel As AcadSelectionSet
On Error Resume Next
Set Sel = ThisDrawing.SelectionSets.Add("ssel")
If Err Then
Err.Clear
ThisDrawing.SelectionSets("ssel").Delete
End If
On Error GoTo 0
'选线
Sel.SelectOnScreen
'获取坐标点
Dim obj As AcadObject
Dim i As Integer
Dim pa(300) As Variant
Dim str As String
i = 0
str = "
未排序坐标"
For Each obj In Sel
If obj.ObjectName = "AcDbLine" Then
pa(i) = obj.StartPoint
str = str & Chr(13) & "
" & i + 1 & "点坐标为: ""( " & pa(i)(0) & "," & pa(i)(1) & _
"," & pa(i)(2) & ")" & Chr(13)
i = i + 1
End If
Next
MsgBox str
'排序
Dim pb As Variant
pb = SortPoints(pa, 0)
newtxt = X坐标点排序"
For i = 0 To UBound(pa)
newtxt = newtxt & vbCr &
" & i + 1 & "点坐标为:" & pb(i)(0) & _
" " & pb(i)(1) & " " & pb(i)(2)
Next
MsgBox oldtxt & vbCr & vbCr & newtxt, , "
明经通道VBA示例"
Sel.Delete
End Sub
[VBA]请斑竹帮助调试,屏幕选取直线获得起始点坐标数组,数组排序, If NewPoints(j)(SortMode) < Best_Value Then这一句有问题
发表于 2004-3-18 08:54:00 | 显示全部楼层
我把代码贴到vba编辑器中,红色的出错行很多啊。
楼主不是直接复制代码上来的?
发表于 2004-3-18 09:13:00 | 显示全部楼层
SortPoints函数没有问题,问题出在传递给函数的变量pa上,pa应该是一个点的数组,但你直接声明了pa(300),但你选择的对象一般少于300,假定是N,那么pa的下标在N+1~300之间都没有定义,这样就不存在pa(j)(sortmode)。在主过程中把Dim pa(300)           As Variant改为Dim pa()           As Variant
k = Sel.Count
ReDim pa(k - 1)下面是我修改后的主过程,测试没有问题。
  1. Sub FindLineStartPoint()Dim Sel   As AcadSelectionSetOn Error Resume Next
  2. Set Sel = ThisDrawing.SelectionSets.Add("ssel")
  3. If Err Then
  4.    Err.Clear
  5.    ThisDrawing.SelectionSets("ssel").Delete
  6.    Set Sel = ThisDrawing.SelectionSets.Add("ssel")
  7. End If
  8. On Error GoTo 0  '选线
  9. Sel.SelectOnScreen'获取坐标点
  10. Dim obj                       As AcadObject
  11. Dim i                               As Integer
  12. Dim pa()           As Variant
  13. k = Sel.Count
  14. ReDim pa(k - 1)
  15. Dim str                         As String
  16. Dim k As Integer
  17. i = 0
  18. str = "未排序坐标"
  19. For Each obj In Sel
  20.    If obj.ObjectName = "AcDbLine" Then
  21.          pa(i) = obj.StartPoint
  22.          str = str & Chr(13) & " 第" & i + 1 & "点坐标为: ""( " & pa(i)(0) & "," & pa(i)(1) & _
  23.          "," & pa(i)(2) & ")" & Chr(13)
  24.            i = i + 1
  25.          End If
  26. Next
  27. MsgBox str'排序
  28. Dim pb As Variant
  29. pb = SortPoints(pa, 0)newtxt = "按X坐标点排序"
  30.        For i = 0 To UBound(pa)
  31.                newtxt = newtxt & vbCr & "第" & i + 1 & "点坐标为:" & pb(i)(0) & _
  32.                                "   " & pb(i)(1) & "     " & pb(i)(2)
  33.        Next
  34.        MsgBox oldtxt & vbCr & vbCr & newtxt, , "明经通道VBA示例"
  35. Sel.Delete
  36. End Sub
 楼主| 发表于 2004-3-18 10:24:00 | 显示全部楼层
谢谢 subtlation 我编程没几天,又很多基本问题还没没搞清楚。 ------------ 学习、学习、再学习!
GMT+8, 2025-5-25 16:58 , Processed in 0.174046 second(s), 24 queries , Gzip On.
