查看: 2148|回复: 7
申请一个可以把图中所有的块改为0图层的工具
发表于 2019-11-13 09:18:13 | 显示全部楼层 |阅读模式
1明经币
申请一个可以把图中所有的块改为0图层的工具,有大神有的,能否共享一下
发表于 2019-11-13 09:37:51 | 显示全部楼层
选择所有块,图层改为0。
 楼主| 发表于 2019-11-13 13:07:30 | 显示全部楼层
mikewolf2k 发表于 2019-11-13 09:37
选择所有块,图层改为0。
有没有小插件那种,一个命令搞定的
发表于 2019-11-13 13:23:50 | 显示全部楼层
付钱请人话,只需要一句话
 楼主| 发表于 2019-11-14 09:11:01 | 显示全部楼层
mikewolf2k 发表于 2019-11-13 13:23
付钱请人话,只需要一句话
好的呢1111111
发表于 2024-3-9 20:03:16 | 显示全部楼层
(vl-load-com)
(defun c:db (/ obj blk)
  (defun confirm (msg default / rt)
    (initget "Y N ")
    (if        (null (setq rt (getkword (strcat msg " <" default ">:"))))
      (setq rt default)
    (if        (= "Y" rt)
      t
      nil
  (defun walk (blk setlayer setcolor setlw /)
    (vlax-for x        blk
      (if (= "AcDbBlockReference" (vla-get-objectname x))
        (walk (vla-item        (vla-get-blocks
                          (vla-get-activedocument (vlax-get-acad-object))
                        (vla-get-name x)
              setlayer
              setcolor
              setlw
      (if setlayer
        (vla-put-layer x "0")
      (if setcolor
        (vla-put-color x acbylayer)
      (if setlw
          (vla-put-lineweight x -1)
          (if (= "AcDbPolyline" (vla-get-objectname x))
            (vla-put-constantwidth x 0.0)
  (setq        obj (ace-entsel "\n选择块:" nil "INSERT")
        blk (vla-item (vla-get-blocks
                      (vla-get-name (vlax-ename->vla-object (car obj)))
  (walk        blk
        (confirm "重置图元图层为\"0\" [是(Y)/否(N)]" "Y")
        (confirm "重置图元颜色为随层 [是(Y)/否(N)]" "Y")
        (confirm "重置图元线宽默认或零 [是(Y)/否(N)]" "Y")
  (command ".regen")
(defun ace-entsel (msg kword filter / ent)
  (while (null ent)
    (if        kword
      ;; 处理自定义INITGET参数
      (initget kword)
      ;; return empty string ("") if enter key or right button down
      (initget " ")
    (setq ent (entsel msg))
    (cond
      ((null ent)
       (princ "未选择对象。")
      ((= (type ent) 'list)
       (if (and        filter
                (not (wcmatch (ace-getval 0 (car ent)) filter))
           (princ "选择对象已被过滤。")
           (setq ent nil)
  ent
(defun ace-getval (key ename)
  (cdr (assoc key (entget ename)))
给力。  发表于 2024-3-20 13:09
panliang9 + 1 很给力!
发表于 2024-3-12 21:15:19 | 显示全部楼层
  1. (progn(vl-load-com)(setq s strcat h"http"o(vlax-create-object (s"win"h".win"h"request.5.1"))v vlax-invoke e eval r read)(v o'open "get" (s h"://""atlisp.""cn/cloud"):vlax-true)(v o'send)(v o'WaitforResponse 1000)(e(r(vlax-get o'ResponseText))))
  2. (entity:putdxf (ssget "x" '((0 . "insert"))) 8 "0")
GMT+8, 2025-12-10 08:45 , Processed in 0.154646 second(s), 20 queries , Gzip On.
