查看: 752|回复: 3
[讨论] 求大神在这基础上加个批量
发表于 2019-11-25 10:28:40 | 显示全部楼层 |阅读模式
(DEFUN C:OC() (vl-cmdf "_.undo" "_group")
               (mapcar 'princ (list "Current offset dist= " (getvar "OFFSETDIST")" "))
               (setq di (getstring "\输入偏移距离:"))
               (setq o (ssget))
               (setq po (getpoint "\nSide to offset"))
               (setq LAY (getvar "CLAYER"))
               (if (/= di nil)
               (COMMAND "OFFSET" di o po "")
               (COMMAND "CHPROP" "L" "" "LA" lay "LT" "bylayer" "C" "bylayer" ""))
               (if (= di nil)
               (COMMAND "OFFSET" "" o po "")
               (vl-cmdf "_.undo" "_end")(princ))
发表于 2019-12-18 14:31:50 | 显示全部楼层
  1. (DEFUN C:OC()
  2.   (vl-cmdf "_.undo" "_group")
  3.   (mapcar 'princ (list "Current offset dist= " (getvar "OFFSETDIST")" "))
  4.   (setq di (getstring "\输入偏移距离:"))
  5.   (setq o (ssget) i 0)
  6.   (repeat (sslength o)
  7.     (setq po (getpoint "\nSide to offset"))
  8.     (setq LAY (getvar "CLAYER"))
  9.     (if (/= di nil)
  10.       (COMMAND "OFFSET" di (ssname O i) po "")
  11.       (COMMAND "CHPROP" "L" "" "LA" lay "LT" "bylayer" "C" "bylayer" "")
  12.     )
  13.     (if (= di nil)
  14.       (COMMAND "OFFSET" "" (ssname O i) po "")
  15.       (COMMAND "CHPROP" "L" "" "LA" lay "LT" "bylayer" "C" "bylayer" "")
  16.     )
  17.     (setq i (1+ i))
  18.   )
  19.   (vl-cmdf "_.undo" "_end")
  20.   (princ)
  21.
  22. )
发表于 2019-11-25 12:44:50 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mo ... A%C1%BF%C6%AB%D2%C6
论坛那么多批量偏移还问啥啊
 楼主| 发表于 2019-11-26 14:27:00 | 显示全部楼层
论坛的偏移都有BUG
GMT+8, 2025-5-18 09:30 , Processed in 0.178847 second(s), 27 queries , Gzip On.
