查看: 1580|回复: 4
[基础] 字符串转换列表的就问
发表于 2019-12-1 22:48:02 | 显示全部楼层 |阅读模式
通常字符串转列表直接用 (list str)就可以了,但像字符串:"T2-01,1269,30,30" 变成一个列表:("T2-01" "1269" "30" "30" ) 应该怎样操作呢?
发表于 2019-12-2 07:35:59 | 显示全部楼层
最简单方式加前后刮号“”  “”,但有缺点如多余逗号会被疏忽 (,,,T2-01,1269,,30,30,,)
  1. (setq lst (read
  2.            (strcat "("
  3.                    (vl-string-translate "," " " "T2-01,1269,30,30")
  4.                    ")"
  5.                    )
  6.            )
  7.       )
(listp lst) ;查询是否为表
;T
哥,你的头像好有个性!  发表于 2019-12-2 08:44
发表于 2019-12-2 08:18:25 | 显示全部楼层
(setq Lst (read (strcat "(" (vl-string-translate "," " " "T2-01,1269,30,30") ")")))
(setq Lst (mapcar 'vl-princ-to-string Lst))
看来思路很重要,还有函数,可以用vl-string-translate居然没想到  发表于 2019-12-2 08:45
GMT+8, 2025-5-18 11:14 , Processed in 0.184772 second(s), 26 queries , Gzip On.
